115 registered members (AC1DD, alchargo, 94astro, apollo18, Anduril, 10 invisible),
2,403
guests, and 33
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,325
Posts5,133,020
Members70,041
Most Online3,589 Nov 2nd, 2019
Shell Rotella Gas Truck 0W-20, 9349 miles FCA 2.4
#5272075
11/19/19 06:53 PM
austinlunsford
OP
OP
Posts: 359 |
*2016* Jeep Renegade in sig (they probably had a hard time reading my hand writing on the slipš). Chrysler 2.4 Multi-Air engine. Roughly 70/30 highway/city. Fairly heavy stop and go during AM commute, but rarely gets short tripped. The oil was in service for 8 months, and I only had to add 1/2 quart make-up oil. Kind of weird about the silicone being so high, I did change the air filter a few thousand miles ago, but the air box is sealed up tight, no leaks I can see. Thoughts?
1997 F250 HD 7.3: Delvac 5W-40 2002 F150: M1HM 0W-20 2016 Renegade: Valvoline Modern Engine 0W-20
Re: Shell Rotella Gas Truck 0W-20, 9349 miles FCA 2.4
[Re: austinlunsford]
#5272107
11/19/19 07:53 PM
LotI
Posts: 1,854 |
The stoners TBN limit is a bit too low for my comfort, I wouldn't extend the interval.
#5272134
11/19/19 08:30 PM
Railrust
Posts: 567 |
Pretty solid results. And you can't beat the Rotella rebates right now.
#5272227
11/19/19 10:35 PM
domer10
Posts: 426 |
cant wait to see the results in my wrangler as Iām running it now. Is your year renegade and engine one of the years where it was it or miss with engine issues....such as oil consumption etc? Also did you notice a mpg gain with this run?
2013Jeep Wrangler Sahara Unlimited 2001 Toyota 4Runner 20010 Harley Davidson Rocker
#5272414
11/20/19 08:50 AM
Koncrete_Cam
Posts: 17 |
Iām running this in my Lancer 2.4 currently. Will be doing UOA. Canāt beat $9/5qt after rebate.
2018 Toyota 4Runner TRD Pro 4.0 2017 Mitsubishi Lancer ES 2.4 2015 BMW 328XI. 2.0 2014 Mazda 2. 1.5
#5272447
11/20/19 09:23 AM
paoester
Posts: 527 |
If you have sealed up your air path into the engine, then there is nothing else you can do except make sure you have the best-filtering oil filter you can get, which is a Fram Ultra XG10575 (if you have the room for 2/3 inch more than the OE size XG10060). It actually could be some persistent piece of silicone rubber seal material kinda hanging out in a spot or two exposed to the oil. Wonder if some air filters can let in more very fine silica dust as a normal occurence too. Wear ppm numbers are good, meaning the silica isn't hurting much. Perfect ending viscosity. Rotella Gas T is good oil. https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5269709/1 says its fine too.
2019 VW Tiguan S 4Motion, Pennzoil Platinum 0w-20, VW Mann oil filter
#5272461
11/20/19 09:39 AM
PimTac
Posts: 11,639 |
Something to add to the discussion regarding the silicon. There is a VOA in that sub forum of this oil that shows 11ppm of silicon. Silicon is used as a anti-foaming agent. That should be considered with your analysis which in turn makes that silicon number a bit less worrying. https://www.bobistheoilguy.com/foru...t-rotella-gas-truck-5w20-voa#Post5035460Itās always a good idea to check the engine bay anyway while performing the oil change. Analysis reports are most useful when comparing trends. Obviously, one report wonāt give us a trend.
2017 Mazda CX5 Havoline Pro DS 0w20 Roki OEM filter.
[Re: Railrust]
#5272970
11/20/19 06:28 PM
c5z06
Posts: 50 |
Pretty solid results. And you can't beat the Rotella rebates right now. I looked on the Shell site and couldn't find rebates for buying 5qt jugs, can someone link me please?
[Re: c5z06]
#5273005
11/20/19 06:50 PM
PimTac
Posts: 11,639 |
Pretty solid results. And you can't beat the Rotella rebates right now. I looked on the Shell site and couldn't find rebates for buying 5qt jugs, can someone link me please? Took about 15 seconds on DuckDuck Go. https://rotella.shell.com/en_us/coupons-rebates-and-sweepstakes.html
[Re: LotI]
#5273080
11/20/19 07:58 PM
austinlunsford
OP
OP
Posts: 359 |
The stoners TBN limit is a bit too low for my comfort, I wouldn't extend the interval. Yeah, I wonāt be going over 10k OCIs on it, since itās still under warranty.
[Re: domer10]
#5273098
11/20/19 08:16 PM
austinlunsford
OP
OP
Posts: 359 |
cant wait to see the results in my wrangler as Iām running it now. Is your year renegade and engine one of the years where it was it or miss with engine issues....such as oil consumption etc? Also did you notice a mpg gain with this run? Thankfully this 2.4 doesnāt have consumption issues. Have had a few warranty claims though: thermostat and housing, passenger side axle, electric fan, sway bar and end links, window seals. No real MPG increase to note. During OCI, lowest tank mpg of 19.4, highest of 31.7 on trip to Charlotte (I use the Fuelly app).
[Re: PimTac]
#5273102
11/20/19 08:18 PM
austinlunsford
OP
OP
Posts: 359 |
Something to add to the discussion regarding the silicon. There is a VOA in that sub forum of this oil that shows 11ppm of silicon. Silicon is used as a anti-foaming agent. That should be considered with your analysis which in turn makes that silicon number a bit less worrying. https://www.bobistheoilguy.com/foru...t-rotella-gas-truck-5w20-voa#Post5035460Itās always a good idea to check the engine bay anyway while performing the oil change. Analysis reports are most useful when comparing trends. Obviously, one report wonāt give us a trend. Thanks for link, I donāt think I have ever seen a VOA for the Gas Truck before. Interesting on the silicon
[Re: paoester]
#5273109
11/20/19 08:26 PM
austinlunsford
OP
OP
Posts: 359 |
If you have sealed up your air path into the engine, then there is nothing else you can do except make sure you have the best-filtering oil filter you can get, which is a Fram Ultra XG10575 (if you have the room for 2/3 inch more than the OE size XG10060). It actually could be some persistent piece of silicone rubber seal material kinda hanging out in a spot or two exposed to the oil. Wonder if some air filters can let in more very fine silica dust as a normal occurence too. Wear ppm numbers are good, meaning the silica isn't hurting much. Perfect ending viscosity. Rotella Gas T is good oil. https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5269709/1 says its fine too. I could use a longer filter, so I will keep that in mind! An XG10060 is what I put on it. This run I used a NAPA Gold 7060 I believe
[Re: PimTac]
#5273119
11/20/19 08:34 PM
c5z06
Posts: 50 |
Wow thanks for timing it!
