PQIA Kirkland 5W-30 synthetic
by kstanf150 - 02/27/20 07:43 PM
401 K took a beating!
by P10crew - 02/27/20 07:30 PM
Coolant Level
by rrretiree7 - 02/27/20 07:21 PM
Techron BOGO at O'Reilly
by TheLawnRanger - 02/27/20 06:26 PM
"Follow Thread" not working anymore?
by atikovi - 02/27/20 06:25 PM
What happened at Hyundai dealers
by WhyMe - 02/27/20 06:23 PM
Using ramps for oil change?
by superfat_dad - 02/27/20 06:03 PM
Ford to reduce warranty costs ?
by marine65 - 02/27/20 06:02 PM
Sony MEX-GS820BT, good AM/FM?
by sasilverbullet - 02/27/20 05:59 PM
What Is This ?
by Propflux01 - 02/27/20 03:39 PM
Million parts struts
by ram_man - 02/27/20 03:10 PM
New Hyundai recall
by WhyMe - 02/27/20 02:16 PM
Equinox/terrain burning oil.. 2015 or later?
by sh40674 - 02/27/20 02:13 PM
Liquid Wrench Penetrating Oil: B-Farnesene
by Brian553 - 02/27/20 01:55 PM
Corona virus and parts availability
by bdcardinal - 02/27/20 01:53 PM
Spotify to garage reciever.
by Malo83 - 02/27/20 01:49 PM
LG Biotech Engine Protectant
by demarpaint - 02/27/20 01:14 PM
Fuchs Titan ATF 6400
by Chuckh - 02/27/20 12:52 PM
Sabbag77, RpR, jameswilliam, Agraz400, superfat_dad
70818 Registered Users
118 registered members (alcyon, AC1DD, Aero540T, 14Accent, 55hambone, 2009Edge, 10 invisible), 1,959 guests, and 21 spiders.
Topics302,009
Posts5,207,230
Members70,818
2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue #5272008 11/19/19 04:58 PM
BeerCan Offline OP
Valvoline Premium Blue 15w40 8600es otherwise known as Heavy Duty
Trying to see if I can extend my interval. ~15% towing this round. Truck computer predicted 4% fuel dilution so right on target
Same oil back in
[Linked Image]
2020 Porsche Cayenne
2017 Ford F250 6.7 PS
2016 Ford F150 3.5 EB
2016 Porsche 981 GTS
2015 Ford Mustang 2.3 EB
My car list is getting long smile
1994 Porsche 968 Coupe
1987 Porsche 944 Turbo
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: BeerCan] #5272013 11/19/19 05:04 PM
M
mbacfp Offline
M
Thanks for posting up. My UOAs have been put on hold due to 2 upper oil pan leak repairs under warranty. I've been running 5w-40 Delvac and Valvoline 5w-40. Going to also get UOA from someone other than Blackstone as I suspect fuel dilution myself, but isn't showing up.
2014 F-550 PSD..........M1 Delvac ESP 5w-40 + OEM
2018 Dodge Charger SRT Hellcat
2012 Toyota Sienna LTD 3.5L V6
2003 Dodge Durango R/T 4x4 5.9L V8
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: mbacfp] #5272045 11/19/19 05:52 PM
BeerCan Offline OP
It might be the fuel dilution that limits how far I can go. I personally don't worry about it until it's 5% or more. So looks like 15k or maybe 20k might be doable but dilution will probably stop me there.
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: BeerCan] #5272152 11/19/19 08:54 PM
M
mattd Offline
M
Curious, how often does your truck regen? The 2017+ 6.7s seem to have more fuel dilution than previous generations. There are several ECM software updates available if you haven’t been to the dealer latey FWIW. The iron and fuel dilution would be my only hesitations but it’s still a little over 3 ppm/1k while it’s higher than I would like for my truck its not absolutely terrible for the nature of this engine. 4% fuel is about as much as I’d personally like to see.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1, L2
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: BeerCan] #5272289 11/20/19 05:02 AM
dnewton3 Offline
Global Moderator
Global Moderator
Fe wear rate is very good. All other wear metals are very low. No Si or coolant contamination to speak of. Fuel is tracking a bit higher, but at this point, there's no correlation of fuel to wear; it's having no effect.
15k miles is worth trying for sure. Run one or two at that distance; see how the wear rates are. Then consider extending out based on the wear data.
Fuel contamination is nothing to ignore; it's important to track. But it's ONLY important if it shows a propensity to affect wear rates. As long as that's not happening, the fuel level is OK. It may not be desirable, but it's tolerable.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: BeerCan] #5272664 11/20/19 01:19 PM
BeerCan Offline OP
Honestly I think the fuel dilution is up because my wife is using the truck as a commuter until she gets her new car. Work is not far enough to complete a regen so it's probably done more than usual. I'm past worrying about regens completing and just let the truck do it's thing.
Dilution is going to be a side effect of that attitude but I am not worried about dilution like some others are. So far I have not seen any issues with my vehicles that dilute, and that's all of them 😁
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: BeerCan] #5309991 01/01/20 11:08 AM
daved5150 Offline
Hey Beer Can, I see that changes #2 and #4 were at least 9K plus miles. Is that when the truck told you to change it? I heard the 17+s ECMs take the OCIs out further than the 11 to 16s. Why was change #3 below that? I'm going to imagine that #5 and #6 are further out as you find a happy medium to extend it out and stay safe. I am very curious about this. From what I see with the attitudes about extending oil changes on a stock 6.7, I'm sure a lot of folks think you're nuts. But if the UOAs are coming back good, no need to worry. Thanks.
I change mine when it tells me to which is about 7.2k miles or so, give or take. I'm just over half way through my last oil change and it will be my 4th UOA done by Blackstone. I run MC10w30. All prior UOAs have come back great. This current oil run I added LubeGard's Heavy Duty Engine Protectant additive in the proper amount. I am curious to see what the next UOA will reveal. I also run an FS2500 bypass.
Trying to get here more often and participate more than I have. Looking forward to your input.
2016 F350 Lariat CC/SB 6.7PSD 3.55s FS2500 iDash1.8
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: daved5150] #5310007 01/01/20 11:20 AM
M
mattd Offline
M
Originally Posted by daved5150
Hey Beer Can, I see that changes #2 and #4 were at least 9K plus miles. Is that when the truck told you to change it? [/b]I heard the 17+s ECMs take the OCIs out further than the 11 to 16s.[b] Why was change #3 below that? I'm going to imagine that #5 and #6 are further out as you find a happy medium to extend it out and stay safe. I am very curious about this. From what I see with the attitudes about extending oil changes on a stock 6.7, I'm sure a lot of folks think you're nuts. But if the UOAs are coming back good, no need to worry. Thanks.
I find it is quite the opposite
ASE Master, L1, L2
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: daved5150] #5310698 01/02/20 06:14 AM
dnewton3 Offline
Global Moderator
Global Moderator
.... I change mine when it tells me to which is about 7.2k miles or so, give or take. I'm just over half way through my last oil change and it will be my 4th UOA done by Blackstone. I run MC10w30. All prior UOAs have come back great. This current oil run I added LubeGard's Heavy Duty Engine Protectant additive in the proper amount. I am curious to see what the next UOA will reveal. I also run an FS2500 bypass.
For your 7.2k mile OCIs, you're wasting money on the additive and the bypass filter. For such a short OCI, those things won't affect the wear rates at all.
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: BeerCan] #5310719 01/02/20 06:45 AM
4WD Offline
How can you dilute that 13 gallon sump, LoL … (maybe they need a proof reader)
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: 4WD] #5310763 01/02/20 07:43 AM
2015_PSD Offline
It is not hard, especially in the winter and short commutes.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Mahle]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: 2015_PSD] #5310771 01/02/20 07:56 AM
4WD Offline
13 gallon?
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: dnewton3] #5311121 01/02/20 02:00 PM
daved5150 Offline
Oh, we had that conversation over at FTE (I'm Overkill2 there). Remember? I'm gonna have to post my next UOA.
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: mattd] #5311126 01/02/20 02:01 PM
daved5150 Offline
What do you mean Matt?
Re: 2017 Ford 6.7PS ~12.5K miles Valvoline Premium Blue [Re: daved5150] #5311169 01/02/20 02:45 PM
M
mattd Offline
M
In our fleet our 2017 and 2018 trucks the OLM pops up every 2k miles. Never see the other ones come up (services are every 3k or so due to hours)
ASE Master, L1, L2
