m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
Engagement Ring Photos
by The Critic - 12/05/19 04:55 PM
Black Friday Oculus Go review
by PandaBear - 12/05/19 04:41 PM
Goodyear Wrangler buy-and a chuckle
by Lapham3 - 12/05/19 04:02 PM
2015 Mazda 3 2.0 - Intake Valve Pics
by buster - 12/05/19 03:54 PM
Timemaster had to get fixed...
by dareo - 12/05/19 03:44 PM
msf1344, Tank99, Ronparise, DrPcFix, benny88
70043 Registered Users
51 registered members (adams355, 4WD, 14Accent, angryorc, alcyon, 3 invisible), 1,402 guests, and 51 spiders.
Topics298,354
Posts5,133,585
Members70,043
Most Online3,589
Nov 2nd, 2019
2012 GMC Terrain 3.0L V6 P0300 #5271817 11/19/19 12:51 PM
B
benjamming Offline OP
B
2012 GMC Terrain 3.0L V6 VIN 5 (flex fuel)
Throwing a P0300 code about once/week. New spark plugs do not fix the issue which is not surprising since it was a multiple misfire code. Coils look good. Anyway, I would expect a P0301, etc. if a particular cylinder had an issue but this is the general misfire code.
Thoughts?
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: benjamming] #5271821 11/19/19 12:58 PM
J
JustN89 Offline
J
Spark plugs were common for causing this, but fuel delivery issues can also cause this code to pop on Terrains. If your under 120k miles, check with your dealer. GM Special Order #10250 covers this code up until 10 years/120k miles, if I'm not mistaken.
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: benjamming] #5271822 11/19/19 01:00 PM
Danno Offline
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: benjamming] #5272136 11/19/19 08:32 PM
clinebarger Offline
GM does not support individual/specific cylinder misfire DTC's on their gasoline engines, You need to monitor Misfire Data via a scan tool to identify the cylinder/s that are misfiring.
Doesn't matter if One or Multiple cylinders are misfiring.......P0300 will be the only DTC. The Generic Descriptor is misleading!
2001 Chevy Camaro L92/4L80E
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: JustN89] #5272161 11/19/19 09:02 PM
B
B
GM Special Order #10250 was for replacing spark plug wires it appears. This engine does not have wires but rather coil on plug. Also, it has ~206k miles. Thanks for the mention though.
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: JustN89] #5272188 11/19/19 09:23 PM
B
B
I found service bulletin 03-06-04-030F Various Driveability ..., P0172, P0300, P1174, P1175 2007-Dec-10. Of course, this is a flex fuel vehicle with direct injection.
I also need to look at the fuel filter perhaps. It doesn't appear to have a serviceable one though.
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: clinebarger] #5272208 11/19/19 09:56 PM
G
GMBoy Offline
G
NOT TRUE! They do use codes P0301,2,3,4,5,6,7,8 etc.
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: GMBoy] #5272230 11/19/19 10:41 PM
clinebarger Offline
GM does not, Respectfully........As you work at Arlington Assembly IIRC?
I have thousands of GM gasoline calibration files, Not one of them supports P0301 through P0308 in the Master DTC list, Nor have I ever seen a GM gas vehicle set a specific cylinder misfire code.
Because the PCM/ECM doesn't need to.....GM has one of the best live Misfire Monitors in the industry!
The Duramax on the other hand which used a Bosch Controller up until the LP5 CAN set specific cylinder misfire codes, Haven't cracked a LP5 yet.
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: clinebarger] #5272248 11/19/19 11:55 PM
slacktide_bitog Offline
What? shocked2
I thought the P0xxx codes were supposed to be universal, not mfr-specific
Quote
not if it can't set a misfire code for a single cylinder smirk2
A good misfire monitor should be able to see only one cylinder misfiring and set the code for that cylinder only!
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: clinebarger] #5272257 11/20/19 12:36 AM
G
GMBoy Offline
G
GM supports these codes. Period. I've seen it on them including my own vechicles and have seen it at work on brand new 2020 models. These are generic codes required by governement OBD2 requirements. The GM DTC charts shows them too.
All due respect my friend but GM supports these codes. Period. I've seen it on them including my own vechicles and have seen it at work on brand new 2020 models. Just saw an Equinox with the code P0303 last month. These are generic codes required by governement OBD2 requirements. The GM DTC charts shows them too.
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: benjamming] #5272258 11/20/19 12:41 AM
G
GMBoy Offline
G
Here is a screen shot of the GM DTC list showing P0301-P0308
*** I CANNOT UPLOAD IT TO HERE FOR SOME REASON - how do I?
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: benjamming] #5272263 11/20/19 01:04 AM
clinebarger Offline
Didn't realize this was a big deal, GM has been this way since OBD-II came out.
Re: 2012 GMC Terrain 3.0L V6 P0300 [Re: GMBoy] #5273200 11/20/19 10:41 PM
clinebarger Offline
I'm fully capable of being wrong, If GM has implemented specific cylinder misfire DTC's in the last few years....Okay!
Ford, Chrysler, Toyota, & Honda set specific cylinder misfire DTC's which is a VERY unreliable diagnostic tool because of sympathy misfires among companion cylinders. GM sets a P0300 & you know to use the Misfire Monitor for diagnostics.
