"Snake Oil" brand, snake oil!
by daves66nova - 12/05/19 11:58 PM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
Engagement Ring Photos
by The Critic - 12/05/19 04:55 PM
Black Friday Oculus Go review
by PandaBear - 12/05/19 04:41 PM
Goodyear Wrangler buy-and a chuckle
by Lapham3 - 12/05/19 04:02 PM
2015 Mazda 3 2.0 - Intake Valve Pics
by buster - 12/05/19 03:54 PM
Timemaster had to get fixed...
by dareo - 12/05/19 03:44 PM
msf1344, Tank99, Ronparise, DrPcFix, benny88
70043 Registered Users
49 registered members (alcyon, 4WD, 14Accent, 928, adams355, 3 invisible), 1,474 guests, and 63 spiders.
Topics298,352
Posts5,133,576
Members70,043
Most Online3,589
Nov 2nd, 2019
Mustang 4r70w atf recommendation #5271794 11/19/19 12:18 PM
H
Hansvoytek Offline OP
H
So, my 2004 Mustang GT shifts fine, a little rough sometimes, but after braking, the trans takes a couple of seconds to re engage. The level looks fine, but I'm going to do a fluid and filter change just to start with, (cause who knows when the previous owner changed it) I'm wondering what brand you guys reccomend? I know it takes Mercon V, I'd like to use Amsoil, but it's going to run me 200+ and I'm not sure it's worth it. What do you guys reccomend?
Re: Mustang 4r70w atf recommendation [Re: Hansvoytek] #5271804 11/19/19 12:33 PM
G
getawheel Offline
G
Mercon V is the safe choice. There are substitutes out there but none have any measurable benefit and most cost considerably more.
SuperTech Mercon V is $4.82/quart at Walmart, if it isn't in stock they will ship it to the store for free. Dropping the pan on a 4R70W will drain 4.5 quarts, maybe 5. Any sealed bottle that says Mercon V and has a Ford license number is fine, the specification is strict. Buy the cheapest you can find.
Using AMSOIL as you suggest would not hurt anything but in that application it would certainly not have any benefit. Waste of money.
Re: Mustang 4r70w atf recommendation [Re: Hansvoytek] #5271816 11/19/19 12:50 PM
K
kschachn Offline
K
Walmart sells Supertech Mercon V for under $5 a quart. According to Warren it is a licensed product.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 428K
2000 Toyota ECHO, 284K
Re: Mustang 4r70w atf recommendation [Re: Hansvoytek] #5271876 11/19/19 02:00 PM
69GTX Offline
All my daily drivers for the past 18 yrs have required Mercon V. And Super Tech is the best choice imo.
2001 Lincoln Cont 4.6L DOHC/ 50K mi / QS HM 5w30 / FUG XG2
1969 Ply GTX/RRs
Re: Mustang 4r70w atf recommendation [Re: Hansvoytek] #5271884 11/19/19 02:10 PM
J
Jetsfan421 Offline
J
Sounds like the solenoids could be dirty causing delayed engagement. If there is evidence of varnish I recommend a bottle of lubegard red or green in this case. I use it in every transmission I service and have never had a bad experience with it.
Re: Mustang 4r70w atf recommendation [Re: Hansvoytek] #5271890 11/19/19 02:19 PM
N
nthach Offline
N
InB4 MaxLife.
Merc V of any brand is a safe choice and that's what I would use. Some approved fluids are semi-synthetic(Castrol IMV, Mobil multi-vehicle ATF and Kendall VersaTrans).
Re: Mustang 4r70w atf recommendation [Re: Hansvoytek] #5271907 11/19/19 02:30 PM
slacktide_bitog Offline
welcome
Castrol Full Synthetic is an excellent choice. The popular Maxlife is also good stuff. You might also like Redline D4 or D6
Does your transmission have a drain plug? If not, get an aftermarket pan that has one. This will make future ATF changes much easier smile
Re: Mustang 4r70w atf recommendation [Re: Hansvoytek] #5272096 11/19/19 07:38 PM
69GTX Offline
Maxlife is certainly good stuff and well liked. However, it's not the correct, higher viscosity requirement for the Mercon V job. (7.4 cSt vs. 5.8 cSt). Must have been a reason why Ford chose the higher viscosity.
1969 Ply GTX/RRs
Re: Mustang 4r70w atf recommendation [Re: Hansvoytek] #5272183 11/19/19 09:18 PM
blupupher Offline
I have used Supertech Merc V and Castrol Synthetic in the past, but use Maxlife now. Cheaper, readily available and works fine.
While I agree that Maxlife starts at a lower viscosity, it is supposed to be much more sheer stable vs reports of Merc V thinning out to lower than Maxlife ATF rather quickly.
I would rather a fluid that starts at 5.9 and stays at 5.9 than a fluid that starts at 7.4 and drops to 5.5.
And no, I have no proof other than what Valvoline had responded to me via e-mail a few years ago when I e-mailed them about Merc V recommendation being removed from the bottle (Merc LV was placed on the bottle, but Merc V has always been on the Maxlife ATF product info sheet)..
6mo:'18 Santa Fe:PP 10W-30/OEM, '18 Soul:Synpower 5W-30/PG, '10 Santa Fe:Synpower5w-30/D+, '04 F150/Magnatec 10w-30/ST
1yr: '12 xB:M1EP 0W-20/CQB, '02 F150:Magnatec 5W-20/D+, '94 VT1100:Peak 15W-40/D+
Re: Mustang 4r70w atf recommendation [Re: 69GTX] #5272245 11/19/19 11:47 PM
the lower-visc ATF didn't exist at the time smile
Re: Mustang 4r70w atf recommendation [Re: 69GTX] #5272431 11/20/19 09:10 AM
dave1251 Online Happy
Online Happy
No MERCON V was a basestock improvement over MERCON the viscosity for both products was the same. MERCON V was more shear stable.
Back to the OP I used Valvoline Maxlife with this transmission without issue and actually the transmission shifted a bit firmer but it stopped the harsh shift.
don't use.
Re: Mustang 4r70w atf recommendation [Re: nthach] #5272624 11/20/19 12:40 PM
H
H
Castrol imv is mercon V?
Re: Mustang 4r70w atf recommendation [Re: getawheel] #5272627 11/20/19 12:43 PM
H
H
Would I see any benefit using a name brand fluid? Like motorcraft or mobil. Also, would you reccomend draining the torque converter as well and doing a whole fluid and filter change? I have a mercedes fluid vacume pump, would I be able to put that down the dipstick tube and pump the fluid out like I do for mercedes oil changes? I'm not sure where the dipstick enters.
Re: Mustang 4r70w atf recommendation [Re: Hansvoytek] #5272646 11/20/19 01:04 PM
Online Happy
I don't see any benefit of using one quality fluid over an another. Also below should help.
https://youtu.be/ATRwt32FkSY
don't use.
Re: Mustang 4r70w atf recommendation [Re: Hansvoytek] #5272712 11/20/19 02:03 PM
2
2strokeNorthstar Offline
2
I have the 4r70w in my F150. Drained the TC 1 time. It’s a mess and high risk. If you cross thread those threads you are pulling the trans possibly. The vacuum change will only get you maybe 3 quarts. You can do that multiple times. I vacuum it out then drop the pan to minimize the mess. Filter always looks fine but more fluid comes out when you take it off and it’s only like $12 online sometimes. No need to over think it. Many small changes is fine. More than most people will do.
2001 F150 5.4L
2013 Nissan Juke Nismo
2000 Honda S2000
1998 BMW 328i
