Cost to rebuild a Ford 4R75E vs. new or used.
by atikovi - 01/27/20 05:26 PM
Autozone Clearance 85w140 gear oil 5 gal
by GON - 01/27/20 04:31 PM
Resonating Noise at 3000rpm
by tookien - 01/27/20 04:28 PM
Looking for Purolator Tech oil filter pics.
by Black_Thunder - 01/27/20 04:02 PM
2019 Mini Cooper Clubman S ALL4 Review
by oilpsi2high - 01/27/20 02:51 PM
The "Penny Challenge"
by ZeeOSix - 01/27/20 02:32 PM
2008 Highlander Battery Post Bolt Snapped
by maverickfhs - 01/27/20 02:31 PM
conventional wisdom rebuild axle or replace?
by NissanMaxima - 01/27/20 01:22 PM
will a thermostat gasket leak coolant into the engine?
by motor_oil_madman - 01/27/20 12:55 PM
Swiss F/A-18C Demo
by Malo83 - 01/27/20 12:43 PM
Technical Service Bulletin Availability
by SubLGT - 01/27/20 12:40 PM
GM Goes All In on EVs: Pickups & SUVs
by SubLGT - 01/27/20 12:11 PM
2019 Jetta 1.4t Rental Review
by javacontour - 01/27/20 11:55 AM
JLR 0w-20w standard Huh????
by Local Color - 01/27/20 11:44 AM
Effects of increasing engine RPM?
by Avery4 - 01/27/20 11:09 AM
New C8-R Vettes at Rolex 24
by racin4ds - 01/27/20 10:39 AM
Thoughts on redline?
by BTLew81 - 01/27/20 10:15 AM
Yak trax
by John_Conrad - 01/27/20 10:00 AM
H20ham, Meletz, yagciogullari, roadrnnr, Burner718
70541 Registered Users
109 registered members (53' Stude, 1978elcamino, 65convertible, 2010Civic, AC1DD, 12 invisible), 2,483 guests, and 21 spiders.
Topics300,644
Posts5,180,104
Members70,541
Page 2 of 5 1 2 3 5
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5271299 11/18/19 08:47 PM
B
BrianF Offline
B
I run PetroCanada Duron SHP 10w30 semi synthetic in my 2017 ISB 6.7 powered Ram 3500. I run it all year, for the full 24,000km index.
2006 Trailblazer LT. QSUD, Fram Ultra.
2017 Ram 3500 SLT Megacab. Duron SHP 10w30, Baldwin BT7349.
1993 GMC 1500. QSAD, Fram PH5
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5271390 11/18/19 11:05 PM
K
kebabaluba Offline
K
Mobil Delvac MX ESP 10W-30 in my 2003 Volvo S60, but its not a truck LOL
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5271611 11/19/19 08:43 AM
B
bbslider001 Offline
B
Supertech or Tractor Supply 15w-40
Byron
1999 F-350 CCLB SRW 7.3, Supertech 15w-40 protected, 300k miles
Various other 7.3s bought, sold, or wrecked
2020 Kia Soul S
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5271705 11/19/19 10:39 AM
dustyroads Offline
Delo XLE 10W-30 year round in a Detroit DD13
2013 F150 XLT 5.0 4X4 122k miles
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5272343 11/20/19 07:26 AM
B
BoiseRob Offline
B
Schaeffer's SynShield® Ultra Performance 10W-30. Been using Schaeffer 10w30 for 11 years in my '07 Classic LBZ
https://www.schaefferoil.com/documents/298-722-td.pdf
2007 Chevrolet Silverado 2500HD LBZ Duramax
2016 Jeep Grand Cherokee Ecodiesel
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5273352 11/21/19 07:15 AM
R
Rglossip Offline
R
Originally Posted by 53' Stude
Good afternoon Bitogers smile
Before I hack another used filter open; thought I'd ask what you diesel vehicle owners are using for HDEO oil. My friends with the f250 and ram 2500 truck run 10w30 rotella or HK All Fleet 10w30 HDEO
The only diesal engine I own is in our Kubota l3560.I have put in Mobil delvac 10w30 extreme synthetic.I will run that till spring then back to a synthetic 15w40 of some kind in May.
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5273495 11/21/19 10:19 AM
O
ofelas Offline
O
15w40 year round, in AME flavor.
R12 in the summer, Webasto in the winter, and cassette tapes all year.
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5273594 11/21/19 12:03 PM
R
rileyc Offline
R
Mobil Delvac 1300 Super 15W40 conventional HDEO in 2017 L5P Duramax - my last no charge dealer oil change.
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5273826 11/21/19 04:54 PM
Dak27 Offline
I’m back to using Mobil Delvac Super 1300 in my semi truck with a Detroit Series 60 motor. Presently I have 15W40 in the sump, but I’ll be switching over to 10W30 in a week or two. I use the 10W30 during the winter months for easier cold startups. I’ll switch back over to 15W40 in late March or early April.
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5274282 11/22/19 08:01 AM
R
racin4ds Offline
R
On a current OCI of Delo HD30WT in my 05 6.0 and love it. Truck seems to really like it as well. Prior flavors were T5 10W30 and Motorcraft 10W30. Since using 10W30 in my 6.0 a few years ago I've learned to love it over any other weight.
Just say NO to thin oils and M1!
05 F350 Powerstroke
05 Hyundai Tucson
08 Legacy GT
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5274779 11/22/19 05:09 PM
T
TiredTrucker Offline
T
I use Schaeffer Synshield syn blend 10w30 in winter and 15w40 in summer in my Detroit 60 12.7L pre-emissions. 1,046,230 miles and still going strong. Uses approximately 1 qt per 11-12,000 miles. Oil changes at around 22,000 miles... almost 50% longer than the OEM recommended drain of 15,000 miles. Standard Donaldson oil filters.
Freedom is not about having the choice to do what you want, but the choice to do what you ought.
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5274919 11/22/19 07:49 PM
J
johan4 Offline
J
I like Rotella T6 5W-40. I've used it in most my diesel vehicles over the last 10 years or so. 04 Jetta TDI, 09 Dodge Cummins and my 04 6.0 Powerstroke. I've even used it in my Can-Am side-by-side, which isn't a diesel though. My 6.0 has some sticky injectors so I also use Archoil.
2013 VW Sportwagen TDI - 40K
2004 E350 6.0 4X4 - 250K
1984 Jeep Scrambler - 180k
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5275179 11/23/19 07:20 AM
U
Usman Offline
U
I’m using Delo 400MGX 15w40 year round, because Karachi hits 40C in the summers and doesn’t drop below 15C in the winters.
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5275293 11/23/19 09:40 AM
ddown Offline
2019 Ford 6.7 Spec'ed for 10-30 Motocraft that's what I'll use until warranty is up
Re: 10w30 HDEO or 15w40, others. What's in your engine? [Re: 53' Stude] #5276745 11/25/19 01:58 AM
F
FordCapriDriver Offline
F
Shell Rimula R4X 15W-40 in my 1988 Escort XR3i
It's an API SL/CI-4 , ACEA E7 oil
Factory spec'd viscosity is 10W-40
I use it because the Ford CVH engine is notorious for valvetrain wear, it's a flat tappet engine where the lifters ride on top of the cam just like on a pushrod engine, but the lifters push directly on the rocker arms.
Around 1200ppm of ZDDP should keep it happy and it so far has for the past 9000 miles since i bought it.
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Repsol Elite Super 20W-50
Page 2 of 5 1 2 3 5
