Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
Engagement Ring Photos
by The Critic - 12/05/19 04:55 PM
Black Friday Oculus Go review
by PandaBear - 12/05/19 04:41 PM
Goodyear Wrangler buy-and a chuckle
by Lapham3 - 12/05/19 04:02 PM
2015 Mazda 3 2.0 - Intake Valve Pics
by buster - 12/05/19 03:54 PM
Timemaster had to get fixed...
by dareo - 12/05/19 03:44 PM
msf1344, Tank99, Ronparise, DrPcFix, benny88
70043 Registered Users
67 registered members (ArrestMeRedZ, Aero540T, apollo18, 14Accent, 69Torino, AC1DD, 3 invisible), 1,563 guests, and 47 spiders.
Topics298,351
Posts5,133,556
Members70,043
Most Online3,589
Nov 2nd, 2019
Page 1 of 3 1 2 3
Kendall GT-1 Max vs PP #5271690 11/19/19 10:25 AM
c5z06 Offline OP
Curious if there is any real difference between Kendall GT-1 Max 5w20 and Pennzoil Platinum 5w20? Vehicle is a 2019 Subaru Ascent and is my wife's daily driver. Mainly my curiosity about GT-1 Max having titanium is leading to me asking the question. Difference in cost is about +$1 / qt for Kendall with an OCI of 5000 miles. Thoughts?
Re: Kendall GT-1 Max vs PP [Re: c5z06] #5271734 11/19/19 11:18 AM
P
paoester Offline
P
Platinum wins, specifically for your DI turbo engine.
Not a lot of difference. Platinum has the slight advantage in base oil, being GTL group3+, somewhat better.
A google search on Kendal GT-1 Max https://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1700629 says it has performed very well in wear tests, at least in the original Titanium-enhanced formula back in 2009, now slightly revised for SN+ LSPI tests.
Both are LSPI-resistant, great for your turbocharged engine. Platinum does LSPI tests in both Ecoboost and Ecotec turbos, doubling down on the tests.
Platinum also passes the GM oxidation test and the Turbocharger Coking Test, very nice to have.
Basically the dexos1 Platinum will have the advantage in most or all of the new dexos1 Generation 2 tests:
---- General Motors Oxidation & Deposit Test (GMOD) verifies the improved oxidation and deposit control characteristics.
----Stochastic Pre-ignition Test verifies the added protection for turbocharged engines and pre-ignition concerns.
----Turbocharger Deposit Test verifies the added protection for turbocharged engines and minimizes deposit formation, which ensures optimal performance during engine life.
--- Aeration Test (bubble control) ensures the air bubbles in the oil dissipate quickly to improve oil performance.
2019 VW Tiguan S 4Motion, Pennzoil Platinum 0w-20, VW Mann oil filter
Re: Kendall GT-1 Max vs PP [Re: paoester] #5271846 11/19/19 01:22 PM
c5z06 Offline OP
Thank you paoester! Great information banana
Re: Kendall GT-1 Max vs PP [Re: c5z06] #5271949 11/19/19 03:17 PM
P
paoester Offline
P
Fun subject. Right now I'm looking at all the high performance new German 0w20 testing protocols, and they have the toughest set. I don't always recommend people use them (VW 508 or Mercedes 229.71) in direct injected turbos made in Korea, U.S., or Japan since they don't design them against LSPI like GM's dexos1, SN+, and the upcoming SP/GF6 will. (That said, they are low ash anyway, so likely not a problem. I'm not sure.)
Right now the cheap good oil to get is Shell Rotella Gas Truck 5w20 (other weights too) since Shell has a $10 rebate they will mail you. Higher moly in that one, probably very good dexos1 qualified oil. Same parent company, Shell, as Pennzoil is. https://rotella.shell.com/en_us/cou...s/save-up-to-10-dollar-per-5-quarts.html
Re: Kendall GT-1 Max vs PP [Re: c5z06] #5271964 11/19/19 03:30 PM
I
Imp4 Offline
I
I always find posts like this interesting.
If there were fact based real world usage differences in D1G2 oils, the comparisons would be all over BITOG.
Somebody would have already started a shareable document that cataloged the optimal oils for particular usage situations and it would be pasted up in a sticky.
Reality is, any oil with current reputable approvals in combination with a common sense preventative maintenance schedule is the best recipe for success.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Kendall GT-1 Max vs PP [Re: c5z06] #5272014 11/19/19 05:06 PM
dave1251 Offline
You are aware Kendall GT-1 DEXOS passes the same tests and Pennzoil uses key terms such as "up to 50% cleaner", "unsurpassed". Not it always is 50% or even it always cleans anything superior each use and unsurpassed means no company can claim superior but all can claim just as well.
don't use.
Re: Kendall GT-1 Max vs PP [Re: dave1251] #5272023 11/19/19 05:18 PM
O
OilReport99 Offline
O
Thought about that type-of-answer earlier today but, honestly, the OP asked about GT-1 MAX. Not that I think it's inferior to dexos in practical performance - currently running GT-1 MAX in my truck - but it's not relevant to his question.
2018 Ram 1500 5.7 17k - VME 5W-20
2018 Camry 2.5 13K - TGMO 0W-16
2007 Impala 3.5 145k - M1EP 5W-30
Re: Kendall GT-1 Max vs PP [Re: c5z06] #5272412 11/20/19 08:49 AM
dave1251 Offline
The only difference between the GT-1 Max and GT-1 DEXOS is the non DEXOS has a .6% sulfated ash difference. I doubt it's even a different motor oil.
don't use.
Re: Kendall GT-1 Max vs PP [Re: dave1251] #5272458 11/20/19 09:35 AM
P
paoester Offline
P
No titanium in the dexos1 generic add package Kendall version. Its a different formula. It appears Kendall ConocoPhillips bought a proven qualified commodity add package from one of the big suppliers (Afton, Lubrizol, Oronite likely) and blended with normal group3 base oil like Warren does on their dexos1 oils, and like so many blenders do.
When comparing two oils, the only real facts we have are what tests one oil passes, & were never done on the other oil.
That is the difference between any dexos1 oil and non-dexos1 oil typically:
--------One oil passes all the extra wear, deposits, and turbocharger stuff, and the other oil is very unknown in how it might do. You can guess. Unreliable guessing.
Hang your hat on real evidence, not speculation on what might be.
Re: Kendall GT-1 Max vs PP [Re: paoester] #5272477 11/20/19 10:00 AM
dave1251 Offline
There isn't might be. There is no "evidence" you posted on this thread other than DEXOS requirements and how this can be used to spin marketing.
The OP can use either or both for the lifetime of his/her vehicle and there will be no better choice out of the two.
don't use.
Re: Kendall GT-1 Max vs PP [Re: c5z06] #5272512 11/20/19 10:34 AM
P
paoester Offline
P
Real engine tests are evidence.
Plain and simple. Real engines, real measurements, not marketing.
One oil has the extra tests, the other oil is a big unknown.
This is just common sense.
Re: Kendall GT-1 Max vs PP [Re: c5z06] #5272777 11/20/19 03:02 PM
R
RazorsEdge Offline
R
Kendall oil has been around for years. I used it in a Ford Explorer that went an easy 200,000 miles.
If it was my choice, I'd use Kendall
2015 Ford Escape Ecoboost 1.6
Schaeffers 9000 5w20
1987 Mustang GT
Vortech Supercharged
Schaeffers 7000 10w30
Re: Kendall GT-1 Max vs PP [Re: paoester] #5272795 11/20/19 03:32 PM
dave1251 Offline
You provided marketing statements not data not real measurements and test engines. The only common sense is real world testing and following the factory recommended OCI either oil is providing nearly identical performance. That is common sense. The differences you seek are nearly immeasurable.
don't use.
Re: Kendall GT-1 Max vs PP [Re: c5z06] #5272849 11/20/19 04:26 PM
P
paoester Offline
P
dave1251, dexos1 has extra engine tests that Kendall GT-1 Max has never passed. It is a big unknown for Kendall about whether it would or not pass the actual tests I listed above. Speculate all you want.
Its crazy for you crzy to keep referring to real engine tests as "marketing" as you do.
Who else here thinks all the tests in SN, GF-5, dexos1, 508, 229.71, etc., are all just "marketing"? I guess its a good time to learn about engine tests the engineers design & execute, and tearing apart engines to examine them for performance.
Re: Kendall GT-1 Max vs PP [Re: dave1251] #5272881 11/20/19 04:56 PM
O
OilReport99 Offline
O
fence
Page 1 of 3 1 2 3
