Hand Sanitizer 1gallon $36 after code
by Touring5 - 03/31/20 08:49 AM
Trailblazer tire pressures
by zrxkawboy - 03/31/20 06:01 AM
Lincoln MKZ hybrid / Sitting for 6+ weeks
by Ammofirst - 03/31/20 04:01 AM
Megapulse VEE System
by toyota62 - 03/31/20 01:35 AM
If only I had more time...
by 14Accent - 03/31/20 12:34 AM
Pennzoil Ultra Platinum 0W-40 availability.
by LTZ10 - 03/30/20 11:01 PM
Brake Fluid testing - moisture & copper
by DIY4quality - 03/30/20 10:49 PM
My E46 with BMW Style 225M wheels
by SLO_Town - 03/30/20 10:49 PM
2019/2020 VW Jetta GLI
by TCU_Adam - 03/30/20 10:00 PM
Inner Core Oil Filter
by QuangTeo - 03/30/20 09:56 PM
245/65/R17
by KE7JFF - 03/30/20 09:42 PM
Replace fuel sending unit or just roll with it?
by cwilliamsws6 - 03/30/20 09:37 PM
lawn sprinkler troubleshooting
by Burt - 03/30/20 07:44 PM
Air conditioner in a toyota avalon
by ChrisSnowden - 03/30/20 06:11 PM
CV axle shaft vertical play?
by JHZR2 - 03/30/20 05:29 PM
This is how it's done!
by Mad_Hatter - 03/30/20 04:56 PM
Android to PC pictures?
by Eddie - 03/30/20 04:30 PM
Crazy fixes that worked
by IMSA_Racing_Fan - 03/30/20 01:39 PM
SantiagoT, cabriopeugeot, Z08969, TCU_Adam, deaner1979
71063 Registered Users
113 registered members (2015_PSD, 55hambone, ANokesPDX, 10ecfarmer, 1978elcamino, 928, 16 invisible), 2,133 guests, and 20 spiders.
Topics303,501
Posts5,235,304
Members71,063
Page 2 of 3 1 2 3
Re: Two Fram Ultras for our application? Machinists help.... [Re: JLTD] #5271421 11/19/19 01:03 AM
M
mattwithcats Offline
M
2008 Jeep Liberty’s use a Fram 3600 or equivalent, 3/4-16 thread...
2009 and up Jeep Liberty’s use a Fram 10060, M22 X 1.5...
The question is, when did they make the change?
End of year, or mid year?
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: Two Fram Ultras for our application? Machinists help.... [Re: JLTD] #5271487 11/19/19 06:39 AM
demarpaint Offline
I have an 08 Liberty and don't have any issues changing the oil filter. A cap wrench and a long 3/8" extension makes it an easy job. Loosen the filter and let the oil drain from the mounting area into the funnel that's mounted there and you're GTG. Having said that the Ultra XG3600 is a great choice, that's what I'm using.
God Bless Our Troops
Re: Two Fram Ultras for our application? Machinists help.... [Re: 92saturnsl2] #5271584 11/19/19 09:10 AM
L
Linctex Offline
L
Originally Posted by 92saturnsl2
Only vehicles I've ever come across that use a 22mm thread filter were Fords.
Guess what?
Dodge Hemis and LS-engines in Chevys are all 22mm now!!!
Re: Two Fram Ultras for our application? Machinists help.... [Re: oldhp] #5271609 11/19/19 09:41 AM
R
RyanY Offline
R
Originally Posted by oldhp
What's the filter number that's on it now??? Take it off and go to your favorite auto parts store. Done.
^this
Or buy both sizes and return the one that doesn't fit.
2007 Cadillac CTS 3.6L >130k miles; mix of PUP/Magnatec 5W-30 + ACDelco PF2129G
2012 Honda Odyssey EX-L >107k miles; STP (Amalie) 0W20 + ACDelco PF2057
Re: Two Fram Ultras for our application? Machinists help.... [Re: 92saturnsl2] #5271635 11/19/19 10:24 AM
SHOZ Offline
Chrysler has used 3/4-16 filters for eons. That's the correct thread size for your application. Only vehicles I've ever come across that use a 22mm thread filter were Fords.
I ran into this back int he 90's with Taurus and then replacing them with Hyundais. But a 22mm filter will screw onto a 3/4-16 mount. Fits loose though.. The 3/4-16 will not thread onto the 22mm mount.
I put a Ford oil filter/heat exchanger on my Hyundai. The center mounting tube were both 22mm so it fit right on. Too thick though for the OE sized filter which hung too low. But the Ford oil mount was 3/4-16 thread.
2008 Hyundai Accent 1.6L 5 sp manual hatchback
2010 Hyundai Genesis Coupe Track 2L Turbo 6sp manual
Re: Two Fram Ultras for our application? Machinists help.... [Re: SHOZ] #5271864 11/19/19 02:45 PM
Z
ZeeOSix Offline
Z
There's a 0.116 inch (nearly 1/8 inch) difference between those two thread sizes. I could see a 20 mm threading onto a 3/4 spud, but a 22 mm on a 3/4 spud seems like there wouldn't be any thread engagement. If there's enough thread engagement then it's probably why using the wrong filter can cause the wrong filter to blow off the mount.
Re: Two Fram Ultras for our application? Machinists help.... [Re: ZeeOSix] #5271867 11/19/19 02:49 PM
K
kschachn Online Content
Online Content
K
I can't even imagine knowingly using an oil filter with the wrong thread crzy
1994 BMW 530i, 252K
1996 Honda Accord, 288K
1999 Toyota Sienna, 434K
2000 Toyota ECHO, 284K
Re: Two Fram Ultras for our application? Machinists help.... [Re: JLTD] #5271992 11/19/19 05:32 PM
9
92saturnsl2 Offline
9
There is no way the threads would engage at all between a 22mm and 3/4. It would be so sloppy you'd immediately know something was wrong. There are a couple filter sizes that can be mixed up, I think it's 18mm and 3/4 is one, but I can't recall for sure. Some guys at work used to do it all the time on our gas welders, you could tell the wrong filter was installed because it would rock back and forth on the threads just a bit as you were (un)screwing it in, but otherwise it would tighten up and appear to work just fine. It felt loose enough that I was always concerned that oil could make its way through the threads (in essence, oil bypassing the filter.)
96 Grand Prix SE (project car)
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Mobil1 EP 0w-20
Re: Two Fram Ultras for our application? Machinists help.... [Re: JLTD] #5272194 11/19/19 10:30 PM
9
92saturnsl2 Offline
9
I can't imagine someone mixing up a 22mm and 3/4 oil filter, the difference is huge. I just tried putting a 3/4-10 bolt in the 22mm and it falls right in. Admittedly not the same thread pitch as a 3/4-16 but the diameter of the thread should be similar. If someone happened to get one to thread somehow, it would be immediately obvious that something is wrong.
[Linked Image from cdn1.imggmi.com]
Re: Two Fram Ultras for our application? Machinists help.... [Re: JLTD] #5272222 11/19/19 11:21 PM
I
Imp4 Offline
I
There are no sizes of inch and metric threads that are interchangeable. None.
It's like comparing apples and bowling balls.
The notion that it would be used in a pressure containing application is even more worrying. duh
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Two Fram Ultras for our application? Machinists help.... [Re: JLTD] #5272689 11/20/19 02:37 PM
BlueOvalFitter Offline
Originally Posted by JLTD
A bit of a dilemma -- planning to go with the Ultra as it is an absolute BEAR to reach the oil filter on our 2008 Jeep Liberty and changing less frequently will be a happy situation.
Note on the page linked below that there's two different Ultra filters.... A metric 22mm thread and an English 3/4" thread. Any machinists here that can say if they are interchangeable or not? From some (admittedly brief) reading online it appears not, so I'm thinking of taking a filter that fits to the hardware store, and find a "template bolt" that I can test on an Ultra to make sure to get the right one.
Any other smart ideas for making sure it's the right fit? Test fitting it on the vehicle is NOT an option due to the difficult location. (and the YouTube videos show the wrong vehicle, the configuration was changed sometime during the model year)
https://www.fram.com/parts-search/?...T1IDUA2AAgGYAdAHZademAAWLXgBF07UgCoQAXSA
Commentary/speculation/expertise/criticism appreciated--
Oh no, he's gone to the DARK SIDE! shocked2
2007 F150, 4.2 V6
Havoline PRO DS 5W20, M1-209A
"One Filter, One OCI!"
"One Box, One OCI!"
Re: Two Fram Ultras for our application? Machinists help.... [Re: BlueOvalFitter] #5273232 11/21/19 01:35 AM
Z
ZeeOSix Offline
Z
Maybe it's the light side now, lol.
Re: Two Fram Ultras for our application? Machinists help.... [Re: BlueOvalFitter] #5274005 11/21/19 09:42 PM
J
JLTD Offline OP
J
Originally Posted by mattwithcats
2008 Jeep Liberties use a Fram 3600 or equivalent, 3/4-16 thread...
You guys have the right of it....3/4" thread and the 3600 is what I'm after. Finally had the chance to go have a look and compare to a filter that fits. Thanks much!
Mattwithcats, don't know when they changed it...after ours was built though. LOL
Uh oh....haha perhaps. At the last change I started running an Amsoil filter for 1 year or 25k....the Fram is $8 compared to $15.40 for the Amsoil....almost twice as much for 5,000 more miles is not worth it.
I'm also moving away from $9.01 per quart Amsoil, which costs ~$108 for a year's change on both our vehicles, not including top offs in the Jeep. Some may say the difference in cost is negligible, but ST Syn at around 7,500 miles twice a year comes out to ~$83.00. Trying Schaeffer first, to see if I can get the 9000 to go a full year; that's only $80/ year if it has the endurance.
Wow now that I posted all that up, it does look like a trivial difference. duh Perhaps I need to do less BITOG overthinking! beer
Lates.
Re: Two Fram Ultras for our application? Machinists help.... [Re: JLTD] #5274642 11/22/19 03:27 PM
O
OLEJOE Offline
O
22-1.5 metric threads are 16.9 threads per inch. 3/4-16 are 16 threads per inch.I use the XG10575 Ultra on my 08' 4.8 GM. It is also 22-1.5.
Jack of All Trades. Master of some.
Re: Two Fram Ultras for our application? Machinists help.... [Re: JLTD] #5275244 11/23/19 09:47 AM
E
Eddie Offline
E
Just use the correct filter and you will not loose any sleep. JMO. Ed
2014 CX5 Touring 2.5L :-)
Page 2 of 3 1 2 3
