1964 Cub Cadet 100
by Phishin - 12/06/19 11:40 AM
2001 Volvo V70XC 6140 Miles Mobil1 10w-30 HM
by Astro_Guy - 12/06/19 11:22 AM
Blend door motor reset
by otis24 - 12/06/19 11:08 AM
My 68 L36
by JeffKeryk - 12/06/19 10:45 AM
2016 Accord 11,513 Miles Mobil1 5w-30 EP
by Astro_Guy - 12/06/19 10:15 AM
Leaf springs last how long?
by supton - 12/06/19 09:27 AM
Valvoline eye candy
by Snagglefoot - 12/06/19 07:41 AM
Air crash of the past
by Exhaustgases - 12/06/19 06:34 AM
Menards Splash Windshield Fluid
by Duffyjr - 12/06/19 06:31 AM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
OilStasher, Cranemanl1EMR, Cooline_Radiator, Sveina, msf1344
70047 Registered Users
109 registered members (aba4430, Alfred_B, 2012AccentSE, Ag76, 94astro, Anduril, 9 invisible), 2,263 guests, and 52 spiders.
Topics298,366
Posts5,133,870
Members70,047
Most Online3,589
Nov 2nd, 2019
Fuel in cylinders #5270576 11/18/19 08:07 AM
Smittyzzz Offline OP
I was having issues with my 98 GMC k1500 z71 with 5,7 vortec sputtering and running weaker than it had been. So I bought new plugs and wires and came home and changed the plugs that night. Auto Zone have me the wrong wires. The next day it's running worse. So I decide to do a complete tune-up on it...
Plugs, wires, coil, distributer cap and rotor. Only to see that the outer edge of the plenum on my intake manifold is cracked... Bad. So I go to the junkyard and by another. Mind you, I've never been into an engine solo this far before, but I go for it. With the you tube videos I manage to get it apart and I decide that the bottom of the intake looks ok and to just change out the plenum, and the injectors. I put in the injectors that came in the intake from the junkyard and put it all back together to find that my battery is bad... Left the key turned forward after checking compression on motor before pulling intake accidently. Put my battery charger on it and pulled the key and let it charge for a couple of hours. Went back out and it started right up. Sputtered and died. Wouldn't re-start. Chalked it up to dead battery. Bought new battery and installed it. Tried to crank and only heard a locked up jarring sound that sounded as a locked up motor. I smelled gas and decided to pull plugs. Number 8 cylinder full of fuel.
Today I pulled all of the plugs and changed the oil. All but 3 cylinders had fuel either holding in the cylinder or the plugs were wet with fuel. I left plugs out for a few hours and I squirt some oil in the plug holes, and put the plugs back in. I take out the fuel pump relay and turn the key, still the same sound.
Any advice
Re: Fuel in cylinders [Re: Smittyzzz] #5270579 11/18/19 08:11 AM
M
mk378 Offline
M
Engine should spin freely with the plugs out (disconnect the fuel pump and the ignition coil when you do that). Once you have the cylinders clear, put the plugs back in, do not add oil.
Injectors can leak. Swap back to original injectors.
Re: Fuel in cylinders [Re: Smittyzzz] #5270614 11/18/19 08:47 AM
T
Trav Offline
T
This was your mistake..
Quote
Never use junkyard are even used injectors without cleaning and leak testing them first.
Re: Fuel in cylinders [Re: Trav] #5270621 11/18/19 08:54 AM
4WD Offline
Quote
^^^There he is, I found him^^^ 👀
Re: Fuel in cylinders [Re: Smittyzzz] #5270623 11/18/19 08:59 AM
1
1978elcamino Offline
1
Lets all take a moment and say a prayer for the connecting rods.
2018 F150 5.0
2016 Ford Fusion 2.5
Re: Fuel in cylinders [Re: Smittyzzz] #5270641 11/18/19 09:17 AM
M
Mad_Hatter Offline
M
Could it have hydrolocked? If so, does taking the plugs out and cranking it clear it?.. and yeah, gotta wonder about the state of the rods on those 3cyls.
Re: Fuel in cylinders [Re: Smittyzzz] #5270670 11/18/19 09:55 AM
K
kc8adu Offline
K
this has the spider type injector module?
its more likely the fuel pressure regulator is leaking.
i have seen those bad enough to hydrolock the engine.
Re: Fuel in cylinders [Re: Smittyzzz] #5270679 11/18/19 10:04 AM
M
mattd Online Content
Online Content
M
What year Truck did you dig that plenum out of? You just might have some stuck poppets.
2007 Ford F-350 4x4 6.0 PSD
ASE Master, L1
Re: Fuel in cylinders [Re: mattd] #5270715 11/18/19 10:45 AM
They Said it was another 98. They looked great compared to mine. I'm going to take the plugs out and try to turn her over by hand when I get home.
Re: Fuel in cylinders [Re: mk378] #5270718 11/18/19 10:47 AM
I'm going to give this a go when I get home. I'll let you guys know. Thanks
Re: Fuel in cylinders [Re: Smittyzzz] #5270820 11/18/19 12:40 PM
T
Trav Offline
T
Disable the ignition by removing a fuse, connector, etc then turn the key on with the plugs out, do not crank the engine you just want fuel pressure. if fuel comes out of the plug hole the injector is stuck open.
Looks mean nothing at all, I have seen some horrible looking injectors that run and test out perfect while some that look new but have dried out flow poorly, stick open or closed and have other problems.
Re: Fuel in cylinders [Re: Trav] #5271176 11/18/19 06:54 PM
M
Mad_Hatter Offline
M
Gonna have to remember that one.👍
Re: Fuel in cylinders [Re: Smittyzzz] #5271307 11/18/19 09:02 PM
Well I got home and pulled the plugs and grabbed the flywheel... To my total disbelief and and relief, the motor turned. So I then unhooked the coil and got the ignition, there was still some fuel in 3 of the cylinders so I left the all of the plugs out and I'll pull the plenum and the devil injectors tomorrow and get some NEW ones ordered. I'm also going to order a new PCM. Any advice on that would be appreciated. I am disabled so money is very limited. I need reliability. That's the reason I used the junkyard parts... That and ignorance. I feel lucky and blessed I'm not buying a new motor.
Re: Fuel in cylinders [Re: Smittyzzz] #5271308 11/18/19 09:02 PM
Thanks for the help guys. Keep it coming please. It's very appreciated.
Re: Fuel in cylinders [Re: Smittyzzz] #5271323 11/18/19 09:24 PM
clinebarger Offline
Why do you need a new PCM?
Either take your 2 Spider assemblies to a good mechanic the that can clean & flow them or buy a Updated MPI conversion Spider! DO NOT bother with changing individual Injector/Poppet assemblies.....GM tried having us do that when these first came out, Didn't work well then & it doesn't work any better 24 years later!
Don't overlook the possibility of the Fuel Pressure Regulator leaking badly!!! You can remove the upper plenum, Hook back up the fuel lines, Pressurize the system & check the FPR.
2001 Chevy Camaro L92/4L80E
