TPMS problem
by rrretiree7 - 05/30/20 02:17 AM
I need your help picking out fireworks for a show.
by joegreen - 05/30/20 12:13 AM
Best off the shelf oil for the price
by samiamz - 05/30/20 12:09 AM
I upgrade my car
by miden851 - 05/30/20 12:00 AM
Ford PVD Wheels Defects
by kstanf150 - 05/29/20 07:48 PM
General thoughts on high milage oils.
by tblt44 - 05/29/20 07:09 PM
Jeep Wrangler JL
by dishdude - 05/29/20 06:43 PM
Valvoline MaxLife 5W-20
by Jackson_Slugger - 05/29/20 06:33 PM
Yamaha dry sump PWC and oil level sensitivity.
by ledslinger - 05/29/20 06:30 PM
WSS-M2C946-B1 vs WSS-M2C961-A1
by W9HDG - 05/29/20 06:16 PM
Waterfall Eco Dynamic tires
by Saabist - 05/29/20 05:55 PM
O’reilly clearance
by Gonz - 05/29/20 04:56 PM
2016 Overland Jeep Wrangler Oil/Filter
by Since1941 - 05/29/20 04:24 PM
Next Pistol Opinions
by Gebo - 05/29/20 03:28 PM
Briggs and Stratton valve clearance
by supton - 05/29/20 02:38 PM
50 cal. shell
by Donald - 05/29/20 01:52 PM
Fleet Farm Rotella T6 Sale + Shell Rebate
by shibby6600 - 05/29/20 01:26 PM
QS Ultimate Durability 5W-30
by js1956 - 05/29/20 12:51 PM
dieselworks, suburbandoom, alltogether, Vig03, dstocker
71566 Registered Users
22 registered members (berlyn, dave1251, blufeb95, ArrestMeRedZ, clinebarger, 2 invisible), 1,139 guests, and 24 spiders.
Topics306,033
Posts5,285,245
Members71,566
Page 2 of 2 1 2
Re: Should I run an AC Delco Ultraguard gold? [Re: Farnsworth] #5270078 11/17/19 04:52 PM
Z
ZeeOSix Offline
Z
Originally Posted by Farnsworth
That's very high efficiency, single pass at 8-10 microns. Must be the best ever. It's easier to understand single pass I think than multi. Essentially it become 100% at 8-10 very quickly. The one big inlet hole identifies it as Champ Labs.
The multi-pass test is basically a continuous single past test repeated over and over since they use a particle counter bith up stream and down stream to monitor instantaneous efficiency across the filter. So at any given time during the multi-pass efficiency test they can essentially get "snap-shot" data of the single pass efficiency through the media.
The advantage of the multi-pass test is that it also measures holding capacity and defines the delta-p curve as the filter loads up, and also gives data that shows if the filter's efficiency changes with loading. It's a more valuable test compared to a single pass test.
When someome advertisers a single pass efficiency It's most likely at a test point shortly after the test starts, ie, the efficiency of a new unloaded filter. As seen, loading of oil filters with debris does not necessarily mean they get more efficient, because increased delra-p can cause trapped particles to dislodge and decrease down stream efficiency.
Re: Should I run an AC Delco Ultraguard gold? [Re: SatinSilver] #5270111 11/17/19 05:37 PM
53' Stude Offline
Originally Posted by SatinSilver
Yes, I'd use them. Too bad they weren't wrapped in plastic then the bottom would prob look better. Be on the lookout for any weird noises esp on start up. If anything like that happens I'd switch it out immediately. Going forward even an ST filter from Walmart will be fine.
What oil is in the truck now? Magnatec is very good.
Agree 100%. Made Jnuary 2003. Use with confidence smile
Magnatec is indeed a good, serviceable oil also
2009 Toyota Camry LE
Re: Should I run an AC Delco Ultraguard gold? [Re: JHZR2] #5270156 11/17/19 06:35 PM
spasm3 Offline
If there is no evidence of rust on the baseplate, i'd run it.
13 elantra 84k 5w30 synpwr
17 mazda cx-5 19000 miles m1 0w30
Re: Should I run an AC Delco Ultraguard gold? [Re: JC1] #5270157 11/17/19 06:37 PM
CharlieBauer Offline
Originally Posted by JC1
I would be temped to open up an unused filter and post the pics here if you have more than 2 filters.
Yes especially if the stock is more than will be used. At 1000 miles a year, a single synthetic filter could go 5 years in total so long as rust isn't an issue.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Should I run an AC Delco Ultraguard gold? [Re: JHZR2] #5270175 11/17/19 06:58 PM
9
92saturnsl2 Offline
9
I have a case of PH8A-sized Ultraguard golds that I still use. I bought a couple dozen of them in 2014 from a RA closeout. I cut one open at that time and the filter looked good throughout. The media is 100% synthetic and didn't look like it would be affected by age at all. I did a C&P of an unused one, but sadly the image links are broken after all this time. The thread is here if you want to read the comments about it.
96 Grand Prix SE (project car)
04 Odyssey EX 205k Shell Rotella T5 10w-30
96 Maxima GLE 275k Mobil Super HM 5w-30
07 Chrysler Pacifica Limited 4.0L 151k Mobil1 EP 0w-20
Re: Should I run an AC Delco Ultraguard gold? [Re: JHZR2] #5270185 11/17/19 07:11 PM
B
Bettez88 Offline
B
Interesting that the ADBV is nitrile, and the gasket is silicone. Probably doesn't make one bit of difference though.
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, PP 0W20 with Toyota filters
Re: Should I run an AC Delco Ultraguard gold? [Re: Sayjac] #5270190 11/17/19 07:16 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Originally Posted by Sayjac
These are the older ACD Ultraguard Gold and they use synthetic media. They are better than the current UPF Gold filters and with any kind of decent storage environment they should be fine. Run em.
As I read the date code, made January of 03. Excellent filters. Only odd thing about them, they use/d nitrile adbv. But no biggie.
Don't know if this is when you purchased them but a google search of topic shows your 03 post about UPF filters.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/314438/AC_Delco_Ultraguard_Gold_UPF-5
I installed one. I could have sworn that I bought the case of these while in college, which was before 2003, though not by much.
I may cut one open for the forum, but I think I’ll probably just run them and cut them when I remove them.
I had a Fram Ultra in there last. It almost wouldn’t come off. Using removal tools effectively crushed the can it took so much force. I don’t recall ever having that much trouble.
Re: Should I run an AC Delco Ultraguard gold? [Re: Bettez88] #5270193 11/17/19 07:18 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Once in service, at temperature, I can imagine it makes a difference, but sitting in a box in a cool basement, likely not...
Re: Should I run an AC Delco Ultraguard gold? [Re: JHZR2] #5270283 11/17/19 09:09 PM
V
VQ35DE Offline
V
Use them. I used a bunch of them for as long as I could find them.
2017 Mazda CX-5 GS AWD
2018 Mazda 3 GT
2020 Toyota 4Runner Limited Nightshade AWD
2007 Chevrolet Colorado ZQ8
Re: Should I run an AC Delco Ultraguard gold? [Re: JHZR2] #5270345 11/17/19 10:36 PM
A
A_User55555 Offline
A
When did AC Delco stop selling different tiers of filters and instead went with just one kind?
2011 Cadillac DTS. No the headgaskets have not blown.....
5W-30 Valvoline Full Synthetic with a Purloator Boss PBL25288 Filter
Re: Should I run an AC Delco Ultraguard gold? [Re: JHZR2] #5270384 11/17/19 11:38 PM
J
jongies3 Offline
J
Originally Posted by JHZR2
Circa 2000?
I drive my truck around 1000mi/yr, maybe less. Did last oil change around 2000 miles back in 2016 or 17. Going to do one today.
Have a bunch of filters, but still have a stash of these from long ago. Thoughts?
Going to use GTX Magnatec since the truck sits so much.
What's with the one large inlet hole over the rest I wonder?
2004 Toyota Tacoma 3.4 V6: Mobil 1 AFE 0W-30, FRAM PH3614 filter
2003 Buick Park Avenue Ultra S/C 3.8 V6: QSGB 5W-30, FRAM PH3387 filter
2013 Honda 400EX ATV: Mobil 1 Racing 4t 10W-40, OEM filter
Re: Should I run an AC Delco Ultraguard gold? [Re: jongies3] #5270470 11/18/19 05:49 AM
Sayjac Offline
Quote
…..What's with the one large inlet hole over the rest I wonder?
That's a unique Champ Labs baseplate characteristic found on 'some' of their filter applications. I once dissected an AZ STP S2808 then made by Champ and it had one larger inlet hole. I know of no functional purpose, just something they do. Also many have a stamped letter(s) on the plate. Topic looks like TT, I've also seen Y and W iirc.
Re: Should I run an AC Delco Ultraguard gold? [Re: JHZR2] #5270496 11/18/19 06:49 AM
Char Baby Offline
Hmm!
Views weren't mixed that way I thought they'd be. smile
Retired 6 yrs now & lovin' it
'15 Nissan Altima 2.5 SV
'15 Honda Civic 1.8 LX
Re: Should I run an AC Delco Ultraguard gold? [Re: JHZR2] #5270513 11/18/19 07:27 AM
M
mpack88 Offline
M
I got a case of Purolator filters made in 2001, and I cut one open and it look just fine inside so I'm using them on all my Chrysler vehicles until the case is depleted.
Page 2 of 2 1 2
