My 68 Ghetto ride
by JeffKeryk - 12/06/19 10:45 AM
2016 Accord 11,513 Miles Mobil1 5w-30 EP
by Astro_Guy - 12/06/19 10:15 AM
Leaf springs last how long?
by supton - 12/06/19 09:27 AM
Valvoline eye candy
by Snagglefoot - 12/06/19 07:41 AM
Air crash of the past
by Exhaustgases - 12/06/19 06:34 AM
Menards Splash Windshield Fluid
by Duffyjr - 12/06/19 06:31 AM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
OilStasher, Cranemanl1EMR, Cooline_Radiator, Sveina, msf1344
70047 Registered Users
86 registered members (14Accent, Aero540T, 94astro, apollo18, 4WD, 2012AccentSE, 9 invisible), 2,164 guests, and 44 spiders.
Topics298,362
Posts5,133,821
Members70,047
Most Online3,589
Nov 2nd, 2019
Walker mower Oil #5270322 11/17/19 09:03 PM
J
Joey737 Offline OP
J
I have walker mowers and been running 5/30 Mobil 1. I’m hearing that a 15/40 may be better for a small engine? I live in Maine so temp varies from 50-95 degrees outside when I use the mowers. Any help and advice on engine oil would be greatly appreciated, Thank you.
Re: Walker mower Oil [Re: Joey737] #5270353 11/17/19 09:47 PM
4WD Online Confused
Online Confused
Howdy … you will hear that some here … but B&S Synthetic is 5w30 … conventional is 10w30
Same with Yamalube for my boat
You could change twice a year if you want to try a 40 …
Re: Walker mower Oil [Re: Joey737] #5270361 11/17/19 10:04 PM
E
Eddie Offline
E
or 10w30 synthetic. ed
2014 CX5 Touring 2.5L :-)
Re: Walker mower Oil [Re: Joey737] #5270435 11/18/19 02:03 AM
L
Lou_Boyle Offline
L
It's going to be hard to find anything "better" than Mobil1 for any gas engine application. 15W40 will reduce oil consumption if the engine consumes oil between changes, and may make it run quieter if it has some piston slap noise. The trade off will be that a really strong tug will be required to get the engine started at lower end of your temp range.
My experience is that just keeping the air filter clean and changing the oil twice a year will make the engine last way longer than the frame. The Briggs engine on my 10 year old Toro Personal Pace runs like new and has never seen anything but whatever conventional oil was on sale. The rest of the mower, however .......
Think carefully about what you are doing, but be decisive. The road of life is paved with flat squirrels who couldn't make a decision.
Re: Walker mower Oil [Re: Joey737] #5270484 11/18/19 05:26 AM
skyactiv Offline
Depends on the engine. My 2 year old Ferris stand on mower has a Kawasaki engine and specs 10W40 or 20W50 .
Look at the tune up kit for it.
[Linked Image]
Sold: 13' VW GTI 3 door 6 speed manual
Me: 18' Elantra Sport 6 speed manual
Re: Walker mower Oil [Re: Joey737] #5270594 11/18/19 08:27 AM
Propflux01 Online Crying
Online Crying
I use 5w-30 in the blistering summer heat of Arkansastan. Never an issue of longevity or overheat in 40 years.
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Re: Walker mower Oil [Re: Joey737] #5270603 11/18/19 08:34 AM
A
ARCOgraphite Offline
A
Mobil 1 5w30 is ILSAC passenger car oil NOT outdoor power equipment oil.
But as you know its hard to find a HD 10W30 for a reasonable price and most "lawnmower oils" in those under a quart bottles at the big box store are just rebranded ILSAC motor oil now. The "go-to" 10w30 rotella triple protect dino used to everywhere and I don't see it anywhere now. Its supposed to be available.
look here:
https://rotella.shell.com/en_us/pro...c37c30ccd59eff9f869a06e1df/t4-10w-30.pdf
Low power walk behind mowers do well on most anything, but if you want the engine to outlast the deck x2, then a 4T motorcycle oil or ATV oil May do the trick if you wanted something "more" than an oil for water cooled motorcars.
Actually walk behind mowers are easy to lube, it's the splash lubed Snowthrowers that can be a challenge as the oil must be thin enough to splash lube in sub-zero starts but viscous enough at high temps to maintain a "cushion"
I had found Yardman/ MTD 5w30 synthetic snowthrower oil blended in louisianna at Lowe's years ago but haven't seen it lately.
This is a API SH high-ash additised Winter multigrade oil made with premium basestocks.
A VERY rare bird.
2019 VW Jetta S 6MT OCI#1 5885mi-Castrol Edge Prof? VW508+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: Walker mower Oil [Re: Joey737] #5270767 11/18/19 11:47 AM
J
Joey737 Offline OP
J
Thank you for all the help! Like I said I have been running 5/30 Mobil 1. I think I may switch to Rotella. I run Mobil 1 synthetic in all my vehicles and change oil every 5,000 miles. I change my oil in my mowers every 50hrs.
These are my first walkers I have had so I was unsure. Side I saw some running 15/50, 15/40, 10/30, 5/30, 20/50 and I was like wow I wonder if I’m doing it right.
Thanks for all the advice!!
Re: Walker mower Oil [Re: Joey737] #5271647 11/19/19 09:36 AM
J
Joey737 Offline OP
J
Sounds like Rotella or Mobil 1 are good choices. I been using 5/30. Engine is new and has used no oil on either one and sound fine. Is the 5/30 good weight oil in a commercial mower for 50-95 degrees outside?
Re: Walker mower Oil [Re: Joey737] #5271668 11/19/19 09:55 AM
K
kschachn Offline
K
What does your owner's manual say?
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 428K
2000 Toyota ECHO, 284K
Re: Walker mower Oil [Re: kschachn] #5271680 11/19/19 10:11 AM
J
Joey737 Offline OP
J
Don’t have one
Re: Walker mower Oil [Re: Joey737] #5271695 11/19/19 10:32 AM
K
kschachn Offline
K
1994 BMW 530i, 251K
Re: Walker mower Oil [Re: kschachn] #5271712 11/19/19 10:45 AM
J
Joey737 Offline OP
J
Thank you!!
Re: Walker mower Oil [Re: Joey737] #5272307 11/20/19 05:42 AM
L
Lubener Offline
L
I use Supertech SAE 30 in all my machines, I can't justify a synthetic oil for my small engines..
The "thinking" man's friend.
Re: Walker mower Oil [Re: Lubener] #5272316 11/20/19 05:57 AM
caprice_2nv Offline
How many do you have and how much money have you calculated that it would cost? For my lawnmower it's $1.83 a year extra for synthetic.
84 Olds Cutlass - 350 Olds
83 Chevy Caprice - 305 Sbc
79 Honda CX500
