Valvoline eye candy
by Snagglefoot - 12/06/19 07:41 AM
Air crash of the past
by Exhaustgases - 12/06/19 06:34 AM
Menards Splash Windshield Fluid
by Duffyjr - 12/06/19 06:31 AM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
Engagement Ring Photos
by The Critic - 12/05/19 04:55 PM
Black Friday Oculus Go review
by PandaBear - 12/05/19 04:41 PM
Goodyear Wrangler buy-and a chuckle
by Lapham3 - 12/05/19 04:02 PM
OilStasher, Cranemanl1EMR, Cooline_Radiator, Sveina, msf1344
70047 Registered Users
99 registered members (38Chevy454, 1960Elco, 2015_PSD, 2012AccentSE, Al, 10 invisible), 1,760 guests, and 60 spiders.
Topics298,359
Posts5,133,742
Members70,047
Most Online3,589
Nov 2nd, 2019
Best Garage Door Seals #5270241 11/17/19 07:18 PM
G
Gebo Offline OP
G
It's getting cold here and I need to replace my Garage door seals. I have the Clopay double groove doors. I just saw some on Amazon with what looks like a tube on the inside and they look very nice. Any recommendations?
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: Best Garage Door Seals [Re: Gebo] #5270289 11/17/19 08:19 PM
Donald Offline
Go here and find what you need. If garage floor is 100% level it should be a snap.
I bought some rodent proof garage door seal and. The rat chewed but did not get through.
https://www.northshorecommercialdoor.com
2015 Ford F250 w/Powerstroke
Re: Best Garage Door Seals [Re: Gebo] #5270344 11/17/19 09:34 PM
P
P10crew Offline
P
Lowe’s should have clopay replacements .
Donald.... you have rat that will eat it’s way into your garage? 410 time or rat trap time. Just one?
Re: Best Garage Door Seals [Re: Gebo] #5270367 11/17/19 10:14 PM
G
Gebo Offline OP
G
Well, I have learned the big difference between rubber and vinyl thanks to you Donald. I’m going with rubber this time.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Re: Best Garage Door Seals [Re: Gebo] #5270494 11/18/19 05:45 AM
A
Amkeer Offline
A
Make sure its the correct type of seal on the bottom so you will need to double check it. I had to order mine as the dry rotted after 14 years.
2014 Toyota Tacoma D Cab 4.0 M1 5-30 96000
2008 Toyota Tundra D Cab 5.7 M1 5-20 95000 miles
2003 Toyota Tacoma Ex Cab 2.7 M1 5-30 211000 miles
2014.5 Toyota Camry SE 2.5 70,000
Re: Best Garage Door Seals [Re: Gebo] #5270512 11/18/19 06:27 AM
G
Gebo Offline OP
G
I have the double T style.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Re: Best Garage Door Seals [Re: P10crew] #5270533 11/18/19 07:06 AM
Donald Offline
I installed garage door seal but during the install process I unknowingly stretched the seal. Over time it shrunk back to its unstretched length and left a gap at each end of garage door. I should have done something but procrastinated. So a single rat made his way in and then I realized I had a rat problem so I installed some rodent proof garage door seal. It got chewed somewhat but I think in this case the rat was trying to go out for a walk, and was already in my garage. I got a camera and finally saw him. He also got into Crosstrek and chewed a bunch of stuff in the WW reservoir and hoses. I got many rat traps. He chewed the felt on battery felt washer next to ultrasonic Mouse Blocker. Finally caught him in a Havahart live catch trap and relocated him out of state on way to work. It appears to have been a single rat. That was last winter and nothing since. Except mice.
Lesson learned, used a lube on garage door seal install, soap and water is probably enough.
Re: Best Garage Door Seals [Re: Donald] #5270556 11/18/19 07:33 AM
G
Gebo Offline OP
G
I'll bet you that is why both of mine fit at first but somehow got shorter. Now I got gaps. Thanks a bunch for the insight. I just muscled mine through with no soap or lube.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Re: Best Garage Door Seals [Re: Gebo] #5271314 11/18/19 09:10 PM
P
P10crew Offline
P
Well I have never seen a rat in my life except on tv. In my world they would be on level playing field as snakes. Kill the quicker the better. We don’t have rats here as far as I know.
Re: Best Garage Door Seals [Re: Amkeer] #5271782 11/19/19 12:07 PM
N
nthach Offline
N
Yep - some doors use some weird proprietary seals. My parent's Genie door(really a rebranded Overhead Door with a Genie label) uses a bulb-type bottom seal with a non-standard retainer and integral plastic snap hinges. Meaning I have to order a new seal from Amazon or a Overhead Door dealer and if a hinge breaks, it's new door time. I'm looking at a Clopay from Home Depot or CHI from the local garage door installer.
Re: Best Garage Door Seals [Re: Gebo] #5271986 11/19/19 04:04 PM
G
Gebo Offline OP
G
I need the T style 5/16 for Clopay
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
