Another reminder why I always change my own oil
by DreamerGT - 01/25/20 04:52 PM
Oil for my 65 mustang.
by old1 - 01/25/20 04:12 PM
Carburetor Tuning with Wide Band O2 Sensor
by Oldswagon - 01/25/20 03:16 PM
Software fix for blown headgasket?
by CaptainHazelwood - 01/25/20 02:01 PM
EB Oil Drain Plug
by BlueOvalFitter - 01/25/20 01:59 PM
Grease for Blend Door Actuator
by TheLawnRanger - 01/25/20 01:05 PM
waterpump fan clutch and thermostat now overheating
by HyundaiAbuser - 01/25/20 12:43 PM
2020 Ford F250 w/Tremor package and 7.3 L
by tenderloin - 01/25/20 12:34 PM
Genesis GV80 SUV
by tenderloin - 01/25/20 12:33 PM
What kind of mixed drink do you like?
by 53' Stude - 01/25/20 12:11 PM
F150s with the 6.2L
by ford46guy - 01/25/20 12:09 PM
Generator - Gas or Not
by coopns - 01/25/20 11:18 AM
Oil Recommendations For Leaks?
by shurguywutt - 01/25/20 10:59 AM
'12 Odyssey EX-L trans filter
by shortlid - 01/25/20 10:57 AM
06 Explorer v8
by ford46guy - 01/25/20 10:31 AM
Heard this today 🤣
by JLTD - 01/25/20 10:18 AM
Has anyone tinted a dash cluster?
by Vern_in_IL - 01/25/20 08:40 AM
Coolant flush machines
by Donald - 01/25/20 08:24 AM
M635_Guy, ame299, Whoop, coondog, steelbeams
70523 Registered Users
103 registered members (53' Stude, 2EHA, 2010Civic, 69Torino, 4WD, 10 invisible), 3,282 guests, and 22 spiders.
Topics300,545
Posts5,178,121
Members70,523
2003 Ford 4.6L CVPI, 96kmi, 10kmi on Pennz HM 5W30 #5264495 11/11/19 07:24 PM
Colt45ws Offline OP
Conventional Pennzoil HM 5W30.
Oil was in service about 11 months. Took 2 quarts of top up over the course of the 10k miles. Does look like it was about the right time to do a change.
Im not surprised about the fuel. My daily drive to work is about 5 miles one way. This is why I am using 5W30 as opposed to the Ford specified 5W20.
As we are coming into winter, Im starting to use my block heater again. That helps a lot; Its up to a coolant temperature of about 100F when I start it up.
Code
Iron		33
Chromium	1
Nickel		2
Aluminum	4
Copper		4
Lead		2
Tin		0
Silicon		15
Sodium		10
Potassium	2
Titanium	3
Molybdenum	176
Boron		33
Magnesium	561
Calcium		1635
Phosphorous	778
Zinc		936
Fuel		2.0 - GC
Soot		<.1
Water		<.1 - FTIR
Visc		[email protected]
TBN		2.49
Oxid		15
Nitr		12
Previous UOA
-Colton
2002 Ford Crown Vic PI 207k, Ex-Kootenai County, ID Unit #42
Down for engine swap
2003 Ford Crown Vic PI 86k
Pennzoil Conv HM 5W30, Fram XG2
Re: 2003 Ford CVPI, 96kmi, 10kmi on Pennz HM 5W30 [Re: Colt45ws] #5264759 11/12/19 06:46 AM
A
aquariuscsm Offline
A
I notice they cut the moly in half. The copper bottle was between 250-300ppm. Looks like all the SOPUS oils now have in the 170ppm range.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: 2003 Ford CVPI, 96kmi, 10kmi on Pennz HM 5W30 [Re: Colt45ws] #5265713 11/13/19 06:23 AM
dnewton3 Offline
Global Moderator
Global Moderator
I would advocate for using a 5w-20 in this case. It's possible that your shorter drives are not warming the engine up fully, and a thinner lube might do a bit better. Each engine has it's own wear rate, but the species as a whole runs fairly well on most lubes. You might try 5w-20, although your short drive may not be overcome by any lube selection.
For reference, here are my two 4.6L MGMs. I've run both syn and inexpensive dino oil, and get around 1ppm/1k miles of Fe or less.
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4969624/5
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: 2003 Ford CVPI, 96kmi, 10kmi on Pennz HM 5W30 [Re: Colt45ws] #5267693 11/14/19 11:07 PM
Colt45ws Offline OP
Oh, I know its not being warmed up fully. My scanguage doesnt show the cylinder head temperature reaching 190F until Im turning onto the street my work is on.
So I dug back into my reports for my other Vics, 3 total, and Ive never really gotten better than about 3ppm/1k of Fe with a variety of OCIs and oil choice. Usually its worse. I have a habit of leaving tubes disconnected or air box clamp loose. Ive done that on both of my other Vics, and of course wear skyrockets to 10ppm/1kmi Fe, and doesnt normalize from that for 10s of thousands of miles.
Thankfully, I havent had such an incident with this one, yet.
I suspect my duty cycle and use profile is just not very good for them. I could try 5W20 just to see, but it I also think any difference would be lost in the noise.
I probably will just have to live with poor wear until I move or get another job farther away. But, I love my job, so we will see on the first option. I would like to have some place I can put an antenna tower up.
-Colton
Re: 2003 Ford CVPI, 96kmi, 10kmi on Pennz HM 5W30 [Re: Colt45ws] #5269230 11/16/19 02:37 PM
J
JunkdrawerDog Offline
J
Ham radio operator?
Re: 2003 Ford CVPI, 96kmi, 10kmi on Pennz HM 5W30 [Re: JunkdrawerDog] #5270218 11/17/19 06:48 PM
Colt45ws Offline OP
Originally Posted by JunkdrawerDog
Ham radio operator?
Yes
-Colton
