2016 Accord 11,513 Miles Mobil1 5w-30 EP
by Astro_Guy - 12/06/19 10:15 AM
Leaf springs last how long?
by supton - 12/06/19 09:27 AM
Valvoline eye candy
by Snagglefoot - 12/06/19 07:41 AM
Air crash of the past
by Exhaustgases - 12/06/19 06:34 AM
Menards Splash Windshield Fluid
by Duffyjr - 12/06/19 06:31 AM
m1 TDT vs Rotella t6?
by Stickygreen - 12/05/19 11:09 PM
Not to beat a dead horse but...
by MoPowa - 12/05/19 10:22 PM
Mitsubishi J4 CVT Fluid-Valvoline CVT Fluid
by FloridaTime - 12/05/19 09:55 PM
3 HP on a 15 Amp 120 v circuit
by Snagglefoot - 12/05/19 09:53 PM
SRT part 3 - 2020 Grand Cherokee SRT
by OVERKILL - 12/05/19 09:14 PM
My first new vehicle - first oil change
by Kurtatron - 12/05/19 09:02 PM
My wife made peanut butter fudge today(PIC)
by tig1 - 12/05/19 08:34 PM
07 Saturn Ion 2.0 L clutch replacement
by Nitronoise - 12/05/19 07:23 PM
Do You Prefer A 2 Cycle Or 4 Cycle Engine
by Warstud - 12/05/19 06:45 PM
Help with gift idea - Vacuum Sealer
by 92saturnsl2 - 12/05/19 05:49 PM
More news on the Ford Transmission Issues
by domer10 - 12/05/19 05:48 PM
Drain plug with nut welder to it. PIC
by tig1 - 12/05/19 05:29 PM
5 in 1 Rental Review
by panthermike - 12/05/19 05:25 PM
OilStasher, Cranemanl1EMR, Cooline_Radiator, Sveina, msf1344
70047 Registered Users
83 registered members (94astro, aquariuscsm, 4WD, 2012AccentSE, anonobomber, Aero540T, 9 invisible), 2,106 guests, and 65 spiders.
Topics298,362
Posts5,133,816
Members70,047
Most Online3,589
Nov 2nd, 2019
Bar oil as fogging oil #5270216 11/17/19 06:47 PM
W
WA1DH Offline OP
W
My chainsaw calls for about 1 tsp of oil poured into the plug hole when storing for extended periods of time, to lubricate the cylinder walls and rings. I have a giant container of bar oil and was wondering if using bar oil for this purpose would be wise? Per the MSDS the bar oil is 95% 30W oil with 5% tackifier added. I figure the tackifier will help maintain the oil in place on the cylinder walls in storage, like a fogging oil. The oil and tackifier would then burn up when the saw is started.
If the tackifier is harmless to the engine, I may but a bit in a squirt bottle and do the same with my other outdoor equipment engines (4 stroke) for storage. I wouldn't feed it into the carburetor as I expect the tackifier may attract dirt. Any thoughts or drawbacks to this?
1995 GMC K1500 5.0 V8 149k mi
1999 Ford Escort 2.0 I4 249k mi
Re: Bar oil as fogging oil [Re: WA1DH] #5270221 11/17/19 06:52 PM
MolaKule Offline
Global Moderator
Global Moderator
I wouldn't do that.
Tackifier forms a gummy residue upon combustion.
Remove the spark plug and add an ounce of XW30 motor oil as it has rust preventatives and metal inhibitors. Pull the rope slowly a couple of time to coat the cylinder walls.
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: Bar oil as fogging oil [Re: WA1DH] #5270242 11/17/19 07:18 PM
4WD Online Confused
Online Confused
You could use marine fogging oil … stored properly an aerosol can would last for years
Re: Bar oil as fogging oil [Re: 4WD] #5270250 11/17/19 07:32 PM
demarpaint Offline
+1
God Bless Our Troops
Re: Bar oil as fogging oil [Re: WA1DH] #5270405 11/18/19 12:06 AM
R
rubberchicken Offline
R
Add a can of marine fogging oil to your next online purchase. Starbrite, CRC, Stabil, Quicksilver, Mercury- any brand in an aerosol can with the red tube will work fine. I would not use bar oil !! But some engine oil would also work ok.
Fogging oil is a bit thinner, specifically designed for corrosion protection, and made to burn off. Besides my boat I also use it for lawn mowers, boat generator, home generator, chainsaw, pretty much anything with an engine.
Re: Bar oil as fogging oil [Re: WA1DH] #5270443 11/18/19 02:53 AM
K
Kamele0N Offline
K
You are all funny....and now he will have to visit local store and buy that "fogging oil"....if they will have it...
But but but I am sure that he has plenty of 2stroke oil laying around in his garage smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Bar oil as fogging oil [Re: WA1DH] #5270572 11/18/19 08:00 AM
M
mk378 Offline
M
Fogging oil in a spray can isn't a really exotic product -- looks like Walmart usually has it.
Re: Bar oil as fogging oil [Re: WA1DH] #5270585 11/18/19 08:18 AM
K
krismoriah72 Offline
K
My 2 stroke oil has fuel stabilizers.
What i usually do is before i store them, add a couple of ounces of oil to the tank, shake vigorously..run the machine and see the heavy smoke then dump the fuel..start it again..run it out of gas then store it.
Re: Bar oil as fogging oil [Re: krismoriah72] #5270587 11/18/19 08:22 AM
4WD Online Confused
Online Confused
I probably need to do that to my Stihl this week … my wood pile is just 12’ from a GFCI plug, and really enjoying my new electric chainsaw
Re: Bar oil as fogging oil [Re: WA1DH] #5270728 11/18/19 11:05 AM
L
Linctex Offline
L
The best fogging oil is a gas (ethanol free) & 2-stroke oil mix of 10:1
Use for any engine (2 stroke or 4 cycle, no matter)
Run the engine with a small amount of this fuel, until the carb runs dry. Put it away for the winter. Done.
You can use "canned fuel" (like True Fuel) with a lot of extra oil added, and then you don't even need to drain the carb at all.
Re: Bar oil as fogging oil [Re: WA1DH] #5271702 11/19/19 10:37 AM
W
WA1DH Offline OP
W
I tried an experiment and heated a small amount of bar oil in a steel can until it ignited. When the fire burned out I was left with a small amount of black oily substance that won’t ignite. This must be what the tackifier breaks down into. I don’t want that in my exhaust.
I will run the rich 2 stroke mix as was suggested. Thanks for all the input.
