92 registered members (Aero540T, 4WD, aquariuscsm, alcyon, 2015_PSD, andreigbs, 9 invisible),
2,013
guests, and 50
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,361
Posts5,133,797
Members70,047
Most Online3,589 Nov 2nd, 2019
Cuts on tire sidewall
#5270055
11/17/19 03:19 PM
mclasser
OP
OP
Posts: 2,822 |
I noticed 2 cuts on a tire in my Elantra. These are the factory Kumho Solus' w/around 19k. Do you guys think I need to replace it? It holds air fine; no odd noises or funny business. ![[Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2019/11/full-55943-38277-img.jpg)
2018 Hyundai Elantra VE 2013 Honda Pilot EX-L 4WD 2002 Honda Accord EX-L
Re: Cuts on tire sidewall
[Re: mclasser]
#5270059
11/17/19 03:22 PM
SatinSilver
Posts: 11,784 |
Yes replace, hopefully it's a rear tire. You can see an indent right below the bigger gash. Prob bring it to DTD if you have one close by. You can send a pm to "CapriRacer" since he's our resident tire expert(retired tire engineer).
edit: you can always have get a Douglas tire at WM and move it to the rear if you don't want new tires yet.
[Re: mclasser]
#5270061
11/17/19 03:25 PM
old1
Posts: 1,170 |
I could be wrong, but that doesn't look good. looks like the cords are cut. I have been known to run some pretty crappy tires, but that would worry me.
2017 Nissan Frontier 4.0 5w30 1965 Mustang 200 c/4 10w30 QS defy 1964 Ford Ranchero 302 c/4 15/40 Delo 1929 ford model A No filters, and 15/40 oil
[Re: mclasser]
#5270070
11/17/19 03:45 PM
dareo
Posts: 1,894 |
Probably fine unless you hit a bump or something on that spot again then its much more likely to pop.
2018 Regal TourX, 2016 Golf Wagon 5MT, 2016 GMC 1500 SLT 6.2
[Re: mclasser]
#5270088
11/17/19 04:05 PM
Astro14
Posts: 10,094 |
If it were mine, I would replace it. Actually, I would replace the pair on the axle...
My rationale: it's deep, and the uneven shape of the carcase adjacent to the lager cut makes me suspect belt damage.
If CapriRacer weighs in, I would absolutely follow his advice, as he KNOWS tires...
32 Packard 15W40 01 Volvo V70 T5 0W30 AMSOIL SS 02 Volvo V70 T5 0W30 Edge 02 Volvo V70 XC 0W40 Edge 05 MB S600 0W40 M1 16 Tundra 1794 5W30 Pennzoil Ultra
[Re: mclasser]
#5270093
11/17/19 04:14 PM
atikovi
Posts: 3,284 |
If it was mine, I'd leave it. If it forms a bubble or spreads, then replace it. Small cuts don't bother me.
[Re: mclasser]
#5270105
11/17/19 04:31 PM
Propflux01
Posts: 3,785 |
Do those happen to be TA31's?
2014 Hyundai Elantra 2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
[Re: mclasser]
#5270107
11/17/19 04:33 PM
Rolla07
Posts: 5,341 |
I think the indentation worries me more than the cut. Replace it.
2007 Corolla Red Pearl 155k miles PP 0w20 & ST 4967 2015 Toyota Venza Parisian Blue Pearl 25k miles TGMO 0W20 & OEM filter
[Re: atikovi]
#5270109
11/17/19 04:34 PM
53' Stude
Posts: 13,997 |
If it was mine, I'd leave it. If it forms a bubble or spreads, then replace it. Small cuts don't bother me. I'm so glad you don't work with me. These types of cuts aren't worth someone's life. At my work we replace tires that look like the OP's. Aside from the obvious; you have NO idea how deep into the tire this cut is.
[Re: mclasser]
#5270113
11/17/19 04:39 PM
Eric Smith
Posts: 3,255 |
Just replaced a Firestone tire on the Focus after she hit a palette and cut the sidewall, flat in seconds. Very similar and the sidewalk isn't very thick. If it's on the back maybe but not on anything she drives. Road hazard?
05 Chevy 3500 (Class C RV) 66k 04 Escape 166k 02 Focus 145k 00 Dakota 93k 91 Festiva 257k .. Rust bucket
[Re: Eric Smith]
#5270119
11/17/19 04:42 PM
53' Stude
Posts: 13,997 |
Just replaced a Firestone tire on the Focus after she hit a palette and cut the sidewall, flat in seconds. Very similar and the sidewalk isn't very thick. If it's on the back maybe but not on anything she drives. Road hazard? Good point. Sidewall has least amount of "meat" or material compared to threaded area.
[Re: mclasser]
#5270151
11/17/19 05:31 PM
spk2000
Posts: 1,517 |
The indentation is likely a broken belt. Some of it depends on your driving situation. If you drive around college 35mph or less might be ok but on highway doing 70+ mph probably best to change it.
96 Grand Marquis 203,000 mi 01 Sable LS Wagon 163,000 mi 02 Montero 191,000 mi 03 Sable LS Sedan 73,000 mi
[Re: mclasser]
#5270154
11/17/19 05:33 PM
spasm3
Posts: 10,659 |
I'd replace, hard to tell how deep it is. Looks like a bit of polyester cord sticking out. Imagine in blowing out right when you are in the apex of a hard corner.
13 elantra 78k 5w30 synpwr 03 chevy avalanche 83k synpwr 5w30 17 mazda cx-5 16400 miles synpwr 5w30
[Re: mclasser]
#5270200
11/17/19 06:24 PM
Fawteen
Posts: 542 |
If that were on a vehicle of mine, I'd replace it without question.
2014 Silverado 2014 Equinox 1972 Olds 442 Convertible 1918 Model T
