Originally Posted by paoester
Some stupid questions:
1. Use the Blaster before the Polish Angel Engine Detailer spray? To get out some debris first you know.
2. Wouldn't a warm or hot engine evaporate the light oils in the spray?
Not stupid at all.
I hit the engine first with the Blaster. It removes a good amount of loose debris. You can use PA Engine two ways - 1. hit the entire engine with it and let it dwell for a few minutes, then wipe down. 2. Spray areas and towel and clean as you go. For a real dirty engine you'd need brushes. PA Engine contains shampoos and oils that clean and restore plastic trim.
The easiest and fastest way is the way most of us have always done - 1. Spray an APC over the engine, hose it down carefully and dry with a leaf blower. Then apply dressing of choice.
As I mentioned earlier, PA engine is designed for those that don't want to use any water at all. However, you can still use it after you use water as a touch up. The 200ml is $14.95. I'm not sure it's worth it when 303 is readily available and also leaves a fantastic finish. PA Engine cleans and protects. Different design and purpose in mind.
I give the edge to 303 and Hyper-Dressing though as they leave an awesome finish and are a spray and walk away product.
PA Engine
PA Engine 2
