Price jacked up on Chevron Supreme at WM?
by Whammo - 12/12/19 11:23 PM
valvoline durablend 5w-30 in yaris, ok?
by jstert - 12/12/19 11:02 PM
Outsmarting RA’s Shipping Lunacy
by The_Nuke - 12/12/19 11:00 PM
Odd Ball!??
by miden851 - 12/12/19 09:40 PM
fedex lost package . how does it work?
by WhyMe - 12/12/19 09:39 PM
RTG 5W-20
by kstanf150 - 12/12/19 09:12 PM
First time running synthetic in my truck
by leeaspell - 12/12/19 09:05 PM
2007 Honda Accord Transmission
by maverickfhs - 12/12/19 07:59 PM
Detriot Axle brake kit review
by 14Accent - 12/12/19 07:51 PM
PQIA Issues An Alert!
by Jackson_Slugger - 12/12/19 06:36 PM
Late night commotion outside.
by LeakySeals - 12/12/19 06:27 PM
Help with Dewalt tools
by henni - 12/12/19 06:19 PM
Educate me on USB drives, devices
by 53' Stude - 12/12/19 05:55 PM
9012 bulb lasted 2 yrs... good?
by mclasser - 12/12/19 05:43 PM
2020 YUGO
by Malo83 - 12/12/19 04:53 PM
Ice on inside of windshield
by JLawrence08648 - 12/12/19 04:41 PM
AC DELCO PF 63E CUT OPEN
by 53' Stude - 12/12/19 04:10 PM
Does old adhesive need to be removed for vinyl planking?
by JLawrence08648 - 12/12/19 04:06 PM
mb20music, Jaglenn, kalima, Powertool1994, lutvi20
70115 Registered Users
51 registered members (carviewsonic, carlprop, Blaze, boulderdentist, alchargo, 1WildPig, 2 invisible), 1,134 guests, and 31 spiders.
Topics298,666
Posts5,140,038
Members70,115
Most Online3,589
Nov 2nd, 2019
2018 Nissan Rogue CVT @ 30k #5269646 11/17/19 06:44 AM
J
jcwhidby Offline OP
J
Looking for some feedback on the suitability of the CVT fluid in my 2018 Nissan Rogue for continued use. I don’t have any experience with CVTs. Thanks in advance.
Re: 2018 Nissan Rogue CVT @ 30k [Re: jcwhidby] #5269654 11/17/19 06:59 AM
A
atikovi Offline
A
CVT fluid is suitable in your CVT. Don't use regular transmission fluid.
Re: 2018 Nissan Rogue CVT @ 30k [Re: atikovi] #5269686 11/17/19 07:58 AM
J
JLTD Offline
J
That's not what he asked.
Jcwhidby, although unfamiliar to me also, it does appear the CVT fluid is doing ok. I know several folks on here that are familiar, hopefully they'll comment shortly. I DO know that CVTs can be rough on fluid so if I had one I'd be changing it on an accelerated schedule. If automatics are any reference, fresh fluid is a good thing to have in your transmission.
I use the overseas manual to choose my viscosity.
Hers: 2008 Jeep Liberty 154k, SS 5w30/Amsoil
Looking at options.
His: 2015 4Runner 60k, SS 5w20/Amsoil
Re: 2018 Nissan Rogue CVT @ 30k [Re: jcwhidby] #5269707 11/17/19 08:23 AM
A
ARCOgraphite Offline
A
Regardless of report I would do a pan drain and refill. But you have gone too far already at 30K. Biggest issue is sludging up hydraulic logic components with belt and pulley wear material. I don't recall reading of failures for those who have been doing regular pan drain and fills..Also, Valvoline or Castrol CVT fluid is just fine for use No need for 'Nissan" fluid. I had a '14 Rogue select, drove the vehicle and trans excessively hard and had no transmission issues doing a pan drain in the mid 20K range. What prompted me was I was seeing "mud" on the tip of the trans dipstick. You model likely doesn't have a DS.
2019 VW Jetta S 6MT OCI#2 7378mi-MOTUL Specific VW508.00+VW Service Filter; '17 Subaru Crosstrek CVT OC#8 60864mi-Subaru Idemitsu 0W20 + SOA Filter
Re: 2018 Nissan Rogue CVT @ 30k [Re: ARCOgraphite] #5269714 11/17/19 08:27 AM
A
atikovi Offline
A
That's just asking for trouble if a warranty issue comes up.
Re: 2018 Nissan Rogue CVT @ 30k [Re: jcwhidby] #5269722 11/17/19 08:35 AM
M
Mainia Offline
M
Technically he is in America, so he has the law behind him that he can use other oil, as long as it speced for that vehicle by that oil company in their documentation. It is law, it should technically shut up the dealer right on the spot, BUT [censored] dealers who think they are the arbitrator or the warranty, when really Nissan is. Just getting break-in materials and new oil in is 3/4 of the battle on keeping a healthy transmission. I agree, dump the trans fluid ASAP and use OEM to be safe if you like.
Re: 2018 Nissan Rogue CVT @ 30k [Re: jcwhidby] #5269728 11/17/19 08:42 AM
4WD Offline
I own only FWD and 4WD vehicles and see the difference in rapid ATF abuse in FWD. However, these cars don’t have a pan to look in like this one with only 31k on FF … and no towing
That magnet sits elevated and both sides were loaded … the blotchy stuff in pan is also metallic
IMO, This fluid sees easy duty compared to our Cruze …
Re: 2018 Nissan Rogue CVT @ 30k [Re: atikovi] #5269735 11/17/19 08:52 AM
A
A
You could talk to the service manager and get his blessing.
Or spend $360.00+ for a $50 dollar DIY job.If it make you feel better. I did and the Nissan dealer messed it up by overfilling AND they reprogrammed the trans to an earlier state which was poor programming compared to factory flash.
They also messed up my transaxle and rear hypoid using poor spec mobilube HD 85W90. stuff doesnt flow in the cold.
So they are careless idiots just making the $$.
Also I've read Most folks had BETTER luck with the aftermarket fluid.
Re: 2018 Nissan Rogue CVT @ 30k [Re: ARCOgraphite] #5269738 11/17/19 08:56 AM
A
atikovi Offline
A
Never said you have to take it to a dealer to do it. You can DIY with Nissan fluid and keep the receipt as evidence.
Re: 2018 Nissan Rogue CVT @ 30k [Re: jcwhidby] #5269747 11/17/19 09:14 AM
P
paoester Offline
P
To interpret the numbers in the report, you need Universal Averages for that same CVT model. Without that, you have no idea, for example, if Fe is too high at 96 ppm (it is fuzzy in the picture, I think it says 96 ppm?).
With transmission fluid, its probably best to just let it go to the exact Owner's Manual maintenance schedule, which is maybe somewhere between the Severe Service schedule and the "Easy-Life" (lower temperatures, no towing, no racing, etc.) schedule.
I don't see the value in fluid analysis here.
What these CVT's really need is a temperature sensor, along with the computer keeping track of temperature history (integrate temperature over time, the calculus meaning of the word "integrate" here).
GM's oil life monitor for the engine sump, for example, will trigger the oil change light if temperature gets to 260F, and will reduce oil life for high temps under that over time.
2019 VW Tiguan S 4Motion, Pennzoil Platinum 0w-20, VW Mann oil filter
Re: 2018 Nissan Rogue CVT @ 30k [Re: jcwhidby] #5269757 11/17/19 09:24 AM
J
jcwhidby Offline OP
J
Thanks for the feedback everyone. The recommended CVT fluid replacement interval is 60k miles, I plan to run it until then, sample and replace and will repost the results then.
Re: 2018 Nissan Rogue CVT @ 30k [Re: jcwhidby] #5269761 11/17/19 09:28 AM
J
jcwhidby Offline OP
J
Also, does anyone have universal averages for CVTs? I haven’t been able to find any online.
Re: 2018 Nissan Rogue CVT @ 30k [Re: jcwhidby] #5269767 11/17/19 09:39 AM
A
A
I would ABSOLUTELY NOT go to 60K if you plan on keeping the car past 60K miles.
A former Manufacturing Manager colleague lost three CVT in two lease Altimas over the past 4 years by " following" the book.
DO NOT go to 60k. I've spend many hours in the Nissan Service bays. You do not want to leave that paticulate mud in the transmission fouling the hydraulic logic circuits.
Forget your Fluid analysis - its doesn't matter in this scenario. It woulnt point to a failure mechanism. Its not a "safety blankey"
Re: 2018 Nissan Rogue CVT @ 30k [Re: ARCOgraphite] #5269773 11/17/19 09:51 AM
4WD Offline
That was the point I tried to make posting the magnet and pan at only 31k on a 6L80e
FWD? ATF was recommended for 40k on the Cruze so I did. That Dex VI was so black that I thought I pulled the wrong plug. So at what mileage had it flipped ?
I have gone back to 30k as FF target.
Re: 2018 Nissan Rogue CVT @ 30k [Re: jcwhidby] #5269775 11/17/19 09:52 AM
T
tomcat27 Offline
T
Change it and use Nissan NS3 fluid this vehicle, and many Jatco CVTs before it, are under a class action lawsuit that may result in a warranty extension. Don't give them any reason to deny coverage
2019 Cherokee, 2018 Jetta, 2014 Sentra, 2001 Camry, 1995 Escort, 1970 Cougar, 2013 XT250, 2010 Vstar, 2014 CTX1300
