508.00-509.00 oil for Honda K24Z3?
by allepunta - 12/08/19 01:36 AM
2020 Toyota Sequoia TRD Pro
by john_pifer - 12/08/19 01:26 AM
Liqui moly viscoplus
by Toh1 - 12/07/19 10:14 PM
Bought me a lemon 15 focus
by gabriel9766 - 12/07/19 10:12 PM
New axle fixed steering pull?
by Chris142 - 12/07/19 09:52 PM
E-core super tech vs Fram orange can 10k
by Doublehaul - 12/07/19 09:01 PM
Interesting trend at my local walmarts
by N Heat - 12/07/19 08:39 PM
Stp S2 oil filter come with silicone ADBV for $4.99
by MetalSlug - 12/07/19 07:50 PM
RATS
by MrQuackers - 12/07/19 07:46 PM
First Day of Summer in New Zealand.
by Silk - 12/07/19 07:02 PM
Gumout Regane Complete 6pk for $22.79
by volk06 - 12/07/19 06:15 PM
Basement sewer smell/Plumbers info req'd.
by irv - 12/07/19 06:03 PM
Project Farm tests car batteries
by cwilliamsws6 - 12/07/19 05:59 PM
Is this normal?
by TurboLuver - 12/07/19 05:12 PM
Any Scooter Riders?
by Passport1 - 12/07/19 03:20 PM
High Performance Lubricants
by wwillson - 12/07/19 02:27 PM
Student laptop needed.
by irv - 12/07/19 01:13 PM
4 unifi AP
by BeerCan - 12/07/19 12:25 PM
Another OCD battery ?
by Gebo - 12/07/19 11:45 AM
smlobx, bithebay87, Keelin, professor229, MxTale
70063 Registered Users
29 registered members (allepunta, BBDartCA, BLND1, 4WD, BlakeB, 2 invisible), 928 guests, and 53 spiders.
Topics298,430
Posts5,135,273
Members70,063
Most Online3,589
Nov 2nd, 2019
2003 Ranger Radiator Replacement: Which Coolant? #5269485 11/16/19 08:55 PM
chucky2 Offline OP
So I have to replace the radiator in my 2003 Ford Ranger 4.0L V-6 - it made it 235k before starting to leak, pretty good run. According to the Motorcraft coolant chart (Google it), I should be using: Y = Yellow-colored engine coolant approved to Ford specification WSS-M97B51-A1 (Motorcraft® Gold Antifreeze/Coolant)
Probably 30-50k into ownership, first 2.5 years maybe I owned it, I got a coolant service and they put green in at the Ford stealership, never noticed it until many miles later. Next service at 100k or more they put green in again. While I've had the leak, I've been filling for a long while now with Prestone Cor-Guard 50/50 pre-mix.
So my question is: What the heck at this point should I run? I'm willing to, before putting the new radiator in, drain all the Prestone out, run distilled water through it, drain that and put in 50/50 Motorcraft Gold so it's in the block and heads (it's of course Winter here in Chicago area, so freezing temps can't leave the water in there), then do the radiator replacement and fill with Motorcraft Gold.
But, at this point, is Motorcraft Gold the best coolant I can run, or is there better stuff on the market?
Thanks for any help and/or opinions here!
Chuck
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5269489 11/16/19 08:58 PM
GumbyJarvis Offline
2018 RAM 1500 SLT 5.7L
Formula Shell Conventional 5w20 - Fram Tough Guard
Disabled US Army Vet
OEF 2013-2014
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5269490 11/16/19 08:59 PM
simple_gifts Offline
The "yellow stuff" is G05; you can get Zerex G05
2004 Prius; 126K; ALM
2007 Yaris 103K ATM
2006 B2300;137K;ALM
Was driving an ox cart; Now on the USS Enterprise
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5269503 11/16/19 09:13 PM
A
austinlunsford Offline
A
^what they said. I just changed the coolant in my 03 Taurus, used Zerex G05 from O’Reilly’s
1997 F250 HD 7.3: Delvac 5W-40
2002 F150: M1HM 0W-20
2016 Renegade: Valvoline Modern Engine 0W-20
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5269520 11/16/19 09:55 PM
slacktide_bitog Offline
Motorcraft Yellow/Gold, Zerex G05, or Peak Global Lifetime
The good news is that Ford still sells the OE Motorcraft Radiator for your Ranger at a fair price and US-made smile
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5269524 11/16/19 09:59 PM
B
Black_Thunder Offline
B
whichever you plan on doing I would mix it stronger then 50/50 when you refill it, because if you run water through it to flush it out you won't get all of that water back out of it so if you put 50/50 in it the water that is still remaining in the block etc will weaken the strength of the coolant.
when refilling it I would maybe go a half a gallon of full strength coolant and 50/50 mix to fill it the rest of the way up.
I'd buy Callahan autoparts if I could.
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5269537 11/16/19 10:32 PM
Snagglefoot Online Content
Online Content
The Prestone Cor Guard would be fine as well. smile
If you want the job done right......do it yourself.
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5269575 11/16/19 11:45 PM
M
mattwithcats Offline
M
Rock Auto has Motorcraft Gold, in concentrated and pre-diluted...
Coolant, Rock Auto
2009 Smart Pure
Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5269602 11/17/19 02:00 AM
F
FordCapriDriver Offline
F
Zerex G-05 or Motorcraft Gold
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50
1988 Ford Escort XR3i Cabrio - Shell Rimula R4X 15W-40 HDEO
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5269622 11/17/19 05:12 AM
K
ka9mnx Offline
K
In 2008 I changed the yellow garbage out of my 2005 Ranger with SuperTech Universal (I guess green). Been using that coolant since. No leaks, no parts replacements and running fine.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: FordCapriDriver] #5269625 11/17/19 05:35 AM
Sayjac Offline
This, whichever costs less. It's what the vehicle specs, it's readily available and relatively inexpensive. However, go with the 'full strength' G-05 and distilled water. That way after you do the distilled flush you mention, then you can fill with G-05 to half cooling system capacity and top with distilled. That would give you protection to ~-34F. I wouldn't think you would need more than that. Eazy Peazy.
While I agree with 'some' of the other AF options listed too, using G-05 keeps it simple and vehicle spec.
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5269768 11/17/19 09:43 AM
B
bullwinkle Offline
B
G-05 IS MC Premium Gold! If you ask your local Ford dealer, they may make you a deal on the PG, that's where most of mine comes from. Using in the Ram, GMC, & Mercury Grand Marquis in my sig.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5269866 11/17/19 11:08 AM
T
Tdbo Offline
T
Peak Global Lifetime is what I use in my 2003.
It meets the specification and is frequently on sale for a good price at Menards.
2012 Honda Accord LX-P 100K
2008 Ford Mustang Pony Package Convertible 17K
2006 Honda Odyssey EX-L 77K
2003 Ford Ranger 3.0 Supercab 123K
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: slacktide_bitog] #5270385 11/17/19 10:40 PM
chucky2 Offline OP
Bunch or recommendations for these...what it is about this Peak Global Lifetime, or this new 10x that maybe replaces it?, that would make it better than the Motorcraft? (if Zerex G05 is same as the Motorcraft, I get 15% off FordParts.com dealer pricing with my dads retiree discount...mine as well get that if I get G05 based unless the Peak G05 is somehow better than the Motorcraft)
Quote
I traded some questions with Summit Racing (they have a large amount of options) a while back looking for radiators. When I was looking, all they had were $500 Motorcraft (not happening on an '03 Ranger that has a body starting to rust out) and some lower cost others. Turns out the only one made in North America was the Spectra Premium, made in Canada, for $116 to the door. There are now a couple Motorcraft options on their site for like $250, but I know Motorcraft has cheep Chinese parts in it's line now. No idea if these are them or not, but, the deed has been done and the Spectra will arrive later this week.
Noted folks on using concentrate after the distilled flush...
Thank you All for the replies and help!
Re: 2003 Ranger Radiator Replacement: Which Coolant? [Re: chucky2] #5270391 11/17/19 11:01 PM
Quote
The Peak Global Lifetime is actually fairly similar to G05 and often available at a good price. The PGL is the closest thing to a truly universal coolant, and the 10x might be even better in that regard. The only widely-available coolant labeled as universal that doesn't have 2-EHA
If the Spectra really is from Canada, then that would be a great choice Canada
