Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
Oreilly Select complete fuel system cleaner
by keantoken - 01/21/20 12:19 AM
Local Costco Has all Oils and Viscosities $10 Off
by SteveG4 - 01/21/20 12:14 AM
EBC Rotor Pictures
by BBDartCA - 01/20/20 11:28 PM
Origami99, reylafo, PastPresMike, RedBeard83, dfrybeck
70496 Registered Users
93 registered members (28oz, 4WD, 1WildPig, 01rangerxl, 11 invisible), 2,375 guests, and 23 spiders.
Topics300,393
Posts5,174,857
Members70,496
Slow initial response to loading web pages #5269312 11/16/19 04:06 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Not just BITOG. And not any one specific device.
I have FiOS, 25/25. Generally have been happy with it. Ours is setup so that we have CAT 5e or 6 copper straight from the network box to our router. Not coax to a modem in the router.
The issue is this. Try to reach out to a site, and it’s very sluggish to respond, but once it has connected, it loads instantly. The browser loading bar stops between 25-35% across. See below.
Switch off my WiFi on a phone, over to 5Ge AT&T, which inside my home is generally 5/2 up/down and ~38ms, loads instant.
Streaming 4K and multiple streams is not an issue, nor is downloading. I’ve seen generally 2.1-2.4 MB/s, but as high as 2.9 when downloading big files like OS updates.
Using Speedtest I can confirm 25/25mbps, and 8-9ms ping.
Any ideas or suggestions?
Same issue on iPhone, iPad, multiple Macs and W10 pc.
Thanks!
Re: Slow initial response to loading web pages [Re: JHZR2] #5269315 11/16/19 04:08 PM
dogememe Offline
Try changing your DNS servers in your router to 1.1.1.1 and 1.0.0.1. Probably your ISPs DNS servers are garbage.
2010 Ford Escape 2.5 ~102K Miles: Castrol Magnatec 5W-20, Wix Filter.
2001 Chevy Suburban 5.3 ~290K Miles: Valvoline Maxlife 10W-30, ACDelco Filter.
Re: Slow initial response to loading web pages [Re: JHZR2] #5269326 11/16/19 04:33 PM
R
rubberchicken Offline
R
Do you have something that does a check on the website before allowing it to proceed ? Something like Norton Internet Security enabled at the browser level ? This sounds like a local PC problem, or DNS issue.
There are 3 main web browser products: IE (and Edge), Chrome, and Firefox, plus a ton of niche products. If you use Chrome, try installing Firefox but do not let it add any extensions: keep it vanilla . If the performance seems much better, then you have narrowed it down to some security product or plug-in / extension.
Re: Slow initial response to loading web pages [Re: rubberchicken] #5269360 11/16/19 05:36 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Behaves the same with safari on iOS devices, safari and Firefox on Mac computers, and IE and chrome on the W10 machine.
Re: Slow initial response to loading web pages [Re: dogememe] #5269364 11/16/19 05:43 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Ok, so my router is set to automatically get DNS from the ISP.
Primary is some 71.x.x.x; secondary is 68.x.x.x
Re: Slow initial response to loading web pages [Re: JHZR2] #5269368 11/16/19 05:50 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
I think that fixed it.
Re: Slow initial response to loading web pages [Re: JHZR2] #5269389 11/16/19 06:42 PM
O
OVERKILL Online Content
Online Content
O
Excellent. I generally use OpenDNS (owned by Cisco, and you can configure it to block a lot of malware and adware) which is 208.67.222.222 and 208.67.220.220.
Re: Slow initial response to loading web pages [Re: OVERKILL] #5269396 11/16/19 06:53 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
I have much to learn in this area. Where can I learn to configure this?
I assume that different DNS servers are owned by different people?
Re: Slow initial response to loading web pages [Re: JHZR2] #5269403 11/16/19 07:04 PM
Mr Nice Offline
Great info.
Re: Slow initial response to loading web pages [Re: JHZR2] #5269408 11/16/19 07:09 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Btw, just downloaded the 1.1.1.1 app, which installs a vpn on your phone. So now I’m using 1.1.1.1 there as well...
Re: Slow initial response to loading web pages [Re: JHZR2] #5269411 11/16/19 07:14 PM
N
NYSteve Offline
N
Re: Slow initial response to loading web pages [Re: JHZR2] #5269475 11/16/19 08:40 PM
J
JHZR2 Offline OP
Global Moderator
Global Moderator
J
Hmmmm.... does Cloudflare block competing DNS?
I was trying to look into the family safe dns setting on Cisco OpenDNS.
Everything else is working great, but that is sluggish. Acts the same as before...
Re: Slow initial response to loading web pages [Re: JHZR2] #5269523 11/16/19 09:57 PM
O
Online Content
O
Just go to opendns.com and create an account. It will allow you to associate your home network with the service and then you can create categories block certain types of sites and the like. It's now part of Cisco's Umbrella solution.
Re: Slow initial response to loading web pages [Re: JHZR2] #5269634 11/17/19 06:14 AM
shanneba Offline
Slow DNS?
I use this utility to configure my DNS on Windoze smile
https://www.grc.com/dns/benchmark.htm
Only works for IPV4 addresses so far.
This may help you change your DNS on Macs:
https://www.cnet.com/how-to/how-to-change-dns-windows-mac-osx/
2003 BMW 330Ci
2013 HD Sportster XL1200C
Re: Slow initial response to loading web pages [Re: JHZR2] #5270413 11/18/19 12:34 AM
dogememe Offline
Cloudflare is a great company with good ethics, a track record of respecting their customers, and I've used their core product (website services [WAF/CDN/DNS]) for my personal, business, and client's websites ever since it came out and I have nothing but great things to say about them. And I have no issue accessing the OpenDNS website and I'm using Cloudflare DNS. OpenDNS might just have been having a website issue at that time.
Anyway, if you don't want to use Cloudflare (1.1.1.1 and 1.0.0.1) you can also use Google Public DNS (8.8.8.8 and 8.8.4.4) and it works pretty well, although Google's track record when it comes to privacy is LOL, what's that!?
