RATS
by MrQuackers - 12/07/19 07:46 PM
37 registered members (carlprop, bdcardinal, brages, 264mag, clinebarger, allepunta, 3 invisible),
985
guests, and 53
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,428
Posts5,135,246
Members70,063
Most Online3,589 Nov 2nd, 2019
Green coolant, future availability ?
#5269377
11/16/19 06:11 PM
rubberchicken
OP
OP
Posts: 1,228 |
I am concerned about the future availability of green coolant. I have a 2000 Kohler 5e marine generator , powered by a liquid cooled Kawasaki FD501D twin cylinder OHV engine, 16 hp of 437 cc displacement. I have always used green coolant, and it is the only machine I own still using green. Marine generators are expensive, and I do not want to do anything that may damage the engine. Should I worry about the future availability of green coolant and consider switching to something else ? Or is there a newer coolant that is completely compatible with the green stuff ?
Re: Green coolant, future availability ?
[Re: rubberchicken]
#5269380
11/16/19 06:17 PM
pitzel
Posts: 1,757 |
I don't see why it wouldn't be available indefinitely. I'd be more concerned about the proprietary coolant of an obscure manufacturer no longer being made, and having to find an alternative. Although with a complete and proper flush before substitution, most coolants will do the job just fine in any application.
So don't worry... You'll probably have a more difficult time finding petrol dispensed into a jerry can as it could possibly be used as part of a terrorist weapon, than finding a suitable ethylene glycol based coolant for your generator.
Change your thinking...not your oil! Turn your mind....not your rotors!
[Re: rubberchicken]
#5269384
11/16/19 06:28 PM
Snagglefoot
Posts: 5,281 |
This. Prestone with Cor Guard. I’ve been using it and it’s predecessor for 15 years in a Ford green coolant situation. Still the original radiator and water pump. There is still green coolant around but I don’t bother looking for it. I poured some into a jar (50% coolant and 50 % water). In fact it has a green tinge to it.
If you want the job done right......do it yourself.
[Re: rubberchicken]
#5269392
11/16/19 06:46 PM
Quest
Posts: 7,418 |
I understand the worries RE: old school silicate antifreeze. Fact is, I've moved on now RE: automotive or small application coolant, either go with factory antifreeze or for Japanese automobiles: I have opted for complete flush + HOAT varieties (i.e. Toyota LL pink).
Never look back.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
[Re: rubberchicken]
#5269401
11/16/19 07:02 PM
Warstud
Posts: 6,819 |
Dont know it's future availabilty but you can get at almost every place that sells AF. And it lasts longer than the old green stuff
[Re: rubberchicken]
#5269423
11/16/19 07:30 PM
bullwinkle
Posts: 9,687 |
G-05/Premium Gold is a great green substitute, too-I have retrofitted several engines that were originally green to use it.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
[Re: rubberchicken]
#5269577
11/16/19 11:47 PM
mattwithcats
Posts: 2,009 |
Second the Xerex G-05... Rock Auto, coolant
2009 Smart Pure Pennzoil Platinum Euro 0W-40, Wix XP 51356 filter, 45 mpg... 185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
[Re: Warstud]
#5269589
11/17/19 12:31 AM
rubberchicken
OP
OP
Posts: 1,228 |
Dont know it's future availabilty but you can get at almost every place that sells AF. And it lasts longer than the old green stuff I am not sure what product you are referencing (Prestone Corguard ?) - but this is one of the reasons I am asking. Two recent visits to two different Autozone's showed that they were out of classic IAT / green coolant. They only stocked 2 variants, 1 of which was 50/50 mix. I was buying Dexcool-type products but happened to note that they were out of IAT / green.
[Re: rubberchicken]
#5269593
11/17/19 01:21 AM
user52165
Posts: 1,891 |
Dont know it's future availabilty but you can get at almost every place that sells AF. And it lasts longer than the old green stuff I am not sure what product you are referencing (Prestone Corguard ?) - but this is one of the reasons I am asking. Two recent visits to two different Autozone's showed that they were out of classic IAT / green coolant. They only stocked 2 variants, 1 of which was 50/50 mix. I was buying Dexcool-type products but happened to note that they were out of IAT / green. I'll bet green coolant will still be here when AZ is gone. Actually it is a race between AZ, Pep Boys, and O'Reilly's to see which is gone first.
[Re: rubberchicken]
#5269601
11/17/19 01:53 AM
FordCapriDriver
Posts: 3,278 |
As other have said, G-05 is a great replacement for old school Green.
1975 Ford Capri II Ghia 3000 V6 - Repsol Elite Super 20W-50 1988 Ford Escort XR3i Cabrio - Shell Rimula R4X 15W-40 HDEO
[Re: rubberchicken]
#5269650
11/17/19 06:47 AM
BigD1
Posts: 3,378 |
All the automotive stores around here still stock original green. I get mine at Rural King because it's cheaper, and it's made by Peak.
Right now a jug of full strength at Rural King is $8.99 plus a $3 rebate, and the rebate is paid by Peak. A gallon of 50/50 is $6.49.
One thing is for sure though. I have not seen the original green in a Walmart store in 10 years or more. From all the research I have done, G-05 is what I would use as others have recommended. NAPA has some very good sales periodically on G-05.
1992 Toyota Pickup--AmazonBasics Conventional--10W-30--Toyota 90915YZZD1
[Re: rubberchicken]
#5269655
11/17/19 07:00 AM
ofelas
Posts: 444 |
I use the Mopar 3yr IAT green concentrate for $9 per gallon jug. Mopar 5yr HOAT looks too similar to my windshield washer fluid. ![[Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2019/11/full-65669-38256-img_3541.jpeg)
R12 in the summer, Webasto in the winter, and cassette tapes all year.
[Re: rubberchicken]
#5269905
11/17/19 12:04 PM
Vern_in_IL
Posts: 2,317 |
There is not such thing as "original green" it was modified in '14 they added a bunch of crap to the mix.
