Honda Oil Filter
GA
After 5k oil and filter change
God forbid
I've inspected it closely and it is very sturdy and super clean; ill go for 10K next time
Originally Posted by miden851
God forbid
Looks ok. Thanks for c&p and what oil and filter went back in and on?
They are fine. Filtration isn't their specialty in terms of a high particle count, but they do the job without failing.And they're cheap if you buy in 6-packs.
yes; I bought them about 12pcs at a discount price Online
the same filter got on and M1 0W-20 extended performance oil in
The elusive A01! Better constructed than the A02 but i believe they share the same specs. Looks good. Probably could've went 10K with no issue, or just follow the maintenance minder
