508.00-509.00 oil for Honda K24Z3?
by allepunta - 12/08/19 01:36 AM
2020 Toyota Sequoia TRD Pro
by john_pifer - 12/08/19 01:26 AM
Liqui moly viscoplus
by Toh1 - 12/07/19 10:14 PM
Bought me a lemon 15 focus
by gabriel9766 - 12/07/19 10:12 PM
New axle fixed steering pull?
by Chris142 - 12/07/19 09:52 PM
E-core super tech vs Fram orange can 10k
by Doublehaul - 12/07/19 09:01 PM
Interesting trend at my local walmarts
by N Heat - 12/07/19 08:39 PM
Stp S2 oil filter come with silicone ADBV for $4.99
by MetalSlug - 12/07/19 07:50 PM
RATS
by MrQuackers - 12/07/19 07:46 PM
First Day of Summer in New Zealand.
by Silk - 12/07/19 07:02 PM
Gumout Regane Complete 6pk for $22.79
by volk06 - 12/07/19 06:15 PM
Basement sewer smell/Plumbers info req'd.
by irv - 12/07/19 06:03 PM
Project Farm tests car batteries
by cwilliamsws6 - 12/07/19 05:59 PM
Is this normal?
by TurboLuver - 12/07/19 05:12 PM
Any Scooter Riders?
by Passport1 - 12/07/19 03:20 PM
High Performance Lubricants
by wwillson - 12/07/19 02:27 PM
Student laptop needed.
by irv - 12/07/19 01:13 PM
4 unifi AP
by BeerCan - 12/07/19 12:25 PM
Another OCD battery ?
by Gebo - 12/07/19 11:45 AM
smlobx, bithebay87, Keelin, professor229, MxTale
70063 Registered Users
37 registered members (4WD, bbhero, adams355, carlprop, allepunta, bdcardinal, 3 invisible), 1,050 guests, and 62 spiders.
Topics298,430
Posts5,135,262
Members70,063
Most Online3,589
Nov 2nd, 2019
VOA for QSAD 10w-40? #5269134 11/16/19 12:02 PM
N
natas Offline OP
N
Non-energy conversing oil weights usually seem to have a lower Moly content than their thinner kin. For my application (m/c) this is good. However, I am trying to find a VOA
for Quaker State Advanced Durability in 10w-40. If anyone has, please post. It seems most SN oils have around double digits of Moly, so for wet clutch operation would be ok, but still wanted to look at the numbers if anyone has it Thanks.
Re: VOA for QSAD 10w-40? [Re: natas] #5269161 11/16/19 12:47 PM
M
Mad_Hatter Offline
M
It's all about oil film thickness my friend.
Re: VOA for QSAD 10w-40? [Re: natas] #5269172 11/16/19 01:21 PM
PimTac Offline
Non energy conversing oil weights. I hadn’t heard that before.
The easiest way to search for this is to do it in your favorite search browser. Adding BITOG will include this site.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: VOA for QSAD 10w-40? [Re: PimTac] #5269184 11/16/19 01:41 PM
N
natas Offline OP
N
I have tried. My google-fu is pretty good. Tried searching for QSAD, Quaker State 10w-40, Quaker State Advanced Durability with and without quotes around the terms. Also checked pqiamerica.com..and anything that even comes close 5w-30 or 10w-30. So I checked known 10w-40s of other brands, and I think with exception of chevron supreme 10w-40--which is just a known good quality high moly oil, and for the most part the moly is down the thicker the operating weight (5w-30 will have more moly than 10w-40 for given brand ** edit: or maybe not?..lol). Havoline 10w-40 which is supposed to be the same as Chevron, actually has a lower moly content, which is weird--I always thought it was the same stuff. Anyway, so was hoping to get a VOA of Quaker State in that weight cuz I just cannot find it. If you can, awesome. I tried. Actually you can use 'inurl:bobistheoilguy.com' as well, which I did.
http://www.pqiadata.org/ChevronSupreme10W40.html
http://www.pqiadata.org/ChevronHavoline10W40.html
Non-energy conserving is any oil that doesnt say that on the API Ring. Usually lower weights (ex. 5w-30) will say "energy conserving" or "resource conserving" [friction modifiers/or too many of] which will cause a wet clutch to slip, and if your bike calls for SAE oil API specification SE, SF, or SG, SN is supposed to supersede all those (SE,SF,SG) BUT, I want to be careful w/ respect to anything in a particular brand's SN formula that would be bad for wet clutches (like too much moly, for example). I wanted to compare Kawasaki motorcycle oil to QSAD 10w-40 and Rotella T4 15w-40, to get an ideal "eyeball" of which oil would be best for the bike.
Re: VOA for QSAD 10w-40? [Re: natas] #5269229 11/16/19 02:35 PM
PimTac Offline
Sometimes the voa just isn’t out there. I’ve run across that before. 10w40 is not a commonly used grade like it used to be. A 5w30 voa might be as close as you will find.
I think the spellcheck played with you on your original comment. I was kidding with you a bit there.
2017 Mazda CX5
Roki OEM filter.
Re: VOA for QSAD 10w-40? [Re: PimTac] #5269238 11/16/19 02:51 PM
N
natas Offline OP
N
:facepalm:..hahah u got me.
Re: VOA for QSAD 10w-40? [Re: natas] #5269361 11/16/19 05:39 PM
M
Mad_Hatter Offline
M
You could do a VOA and treat us all to it. Consider it a Xmas gift to BITOG'ers..😉
Go with an SL oil. IIRC that's pre phos/zinc limits, so mfgs could load up on the phos/zinc in lieu of the more expensive moly. Or look at HDEO's.. they're usually higher in zinc/phos and typically low/to no moly as the thicker oil films are better at maintaining hydrodynamic lubrication.
Re: VOA for QSAD 10w-40? [Re: Mad_Hatter] #5269547 11/16/19 10:48 PM
N
natas Offline OP
N
Yeah, I'm thinking about it. Only $28 bucks, and the other oils have already been posted.I might.
Re: VOA for QSAD 10w-40? [Re: natas] #5270626 11/18/19 09:02 AM
A
aquariuscsm Offline
A
All current QSUD weights will have in the 170ppm moly range.
1996 Nissan 300ZX 5-speed,Arctic Pearl(#175 of 300)
Quaker State Ultimate Durability 10W30
2012 Honda Accord Coupe EX-L 2.4,auto,San Marino Red
Quaker State Ultimate Durability 0W20
Re: VOA for QSAD 10w-40? [Re: PimTac] #5270876 11/18/19 01:47 PM
B
Benzadmiral Offline
B
Non energy conversing oil weights. I hadn’t heard that before. . . .
"I talk and talk, and the oil just avoids the subject of energy!"
-- Paul W. (The Benzadmiral)
('16 Buick LaCrosse Premium, 3.6L, deep garnet/light neutral)
http://benzadmiral-uncle.blogspot.com/
Re: VOA for QSAD 10w-40? [Re: aquariuscsm] #5271256 11/18/19 08:17 PM
N
natas Offline OP
N
Or more. http://www.pqiamerica.com/June%202014/quakerstate.htm http://www.pqiadata.org/QuakerState5W30dexos.html
Tho this one had a lower moly: http://www.pqiamerica.com/March2013PCMO/quakerstatesyn.htm
