Does old adhesive need to be removed for vinyl planking?
by JLawrence08648 - 12/12/19 04:06 PM
How straight does a oscillating saw cut?
by JLawrence08648 - 12/12/19 03:58 PM
Hastings filter efficiency ratings.
by mpgo4th - 12/12/19 03:12 PM
5w50 in the stash
by cptbarkey - 12/12/19 03:07 PM
Jingle Bells...
by GumbyJarvis - 12/12/19 02:38 PM
Meguiar's M305
by sohccammer427 - 12/12/19 02:29 PM
Will it fit?
by Bettez88 - 12/12/19 12:58 PM
Diagnosis Confirmatioin
by Gebo - 12/12/19 12:58 PM
Mercury 25hp PCMO
by SimpleGuy48 - 12/12/19 12:50 PM
IIHS Pushing for Better Headlights
by SubLGT - 12/12/19 11:58 AM
My favorite flight ever
by Astro14 - 12/12/19 11:31 AM
Does anybody else have reactions to MSG?
by Chris142 - 12/12/19 10:35 AM
injecter cleaner?
by ernied - 12/12/19 09:27 AM
Which would you use for 5k
by Bettez88 - 12/12/19 09:08 AM
Effective ways to reduce humidity inside the car
by MoneyJohn - 12/12/19 08:21 AM
Stupid regulations- Diesel Cap Color
by Rmay635703 - 12/12/19 08:20 AM
Help a not-so-noob: shear stability theory.
by OilStasher - 12/12/19 08:03 AM
Latest oil purchase for Lawnmowers
by Snagglefoot - 12/12/19 07:44 AM
kalima, Powertool1994, lutvi20, Bazik, Lamasuna
70113 Registered Users
102 registered members (andyd, Aichiguy, 53' Stude, 2002 Maxima SE, 2003f7, allepunta, 7 invisible), 1,922 guests, and 23 spiders.
Topics298,636
Posts5,139,635
Members70,113
Most Online3,589
Nov 2nd, 2019
"Medallion ATF" for Toyota WS #5268177 11/15/19 01:37 PM
T
TmanP Offline OP
T
Hello All,
The Camry is fast-approaching 60k and I wanted to change out the tranny fluid (just because; it's specced as a lifetime fluid). The Camry has a sealed transmission with no dipstick.
It shifts well; it sometimes has one strange shift when cold, but nothing other than that. Anyway, I wanted to be proactive on maintenance.
Essentially every shop I called wanted to flush it, in addition to adding all manner of strange chemicals (conditioner, "cleaner", etc.)
They were looking to charge $250-300 to do so, including the dealers (none of whom wanted to or recommended doing this piece of maintenance).
I did find a smaller shop that was willing to do the work and only bid $60 for the first change, and about $100 if I wanted to do two.
(The guy said that doing it twice wouldn't be necessary but would depend on the condition of the fluid.) He uses "Medallion ATF" in bulk from a local distributor:
https://medallion-plus.com/user/products/pds/to-14-01-29-18.pdf
It lists Toyota WS as one of its "approvals" but I can't find much out about it.
Any concern letting him do so with that fluid? Or should I bring WS or some other ATF in bottles? He said that it'd cost $45 or $85 for the two changes if I brought fluid.
(If I bring fluid, should I bring Maxlife or some alternative, or stick with WS?)
2012 Toyota Camry 2.5 30,000 mi
2015 Chevy Silverado LT Z71 5.3 V8 30,000 mi
2010 Toyota Sienna 3.5 V6 150,000 mi
Re: "Medallion ATF" for Toyota WS [Re: TmanP] #5268217 11/15/19 02:18 PM
MolaKule Offline
Global Moderator
Global Moderator
Originally Posted by TmanP
Hello All,
The Camry is fast-approaching 60k and I wanted to change out the tranny fluid (just because; it's specced as a lifetime fluid)...
Let's make a distinction between "approvals" and advertised, "List of Suitable For Use Applications."
They are not the same. An approval would be listed with the OEM's licensing number. List of Suitable For Use Applications is the additive manf. list of applications they believe applies.
The ATF is blended by PetroChoice of King of Prussia, Pa.
Other than that, I have no information as to quality of the product.
"Dr. Larry Fleinhardt:
You know that it's considered unsolvable?
Charlie Eppes:
Well, certainly people who have failed to solve it might think that." From NUMB3RS
Re: "Medallion ATF" for Toyota WS [Re: MolaKule] #5268229 11/15/19 02:27 PM
T
TmanP Offline OP
T
Sure, that's why I used the quotation marks around "approvals" - just guidelines, I suppose. I can't see any list anywhere of what Toyota does happen to approve for the cars, except genuine WS fluid.
Is this a non-starter?
Re: "Medallion ATF" for Toyota WS [Re: TmanP] #5268242 11/15/19 02:38 PM
J
Jetsfan421 Offline
J
Many folks on this fine forum use maxlife atf in place of ws with great results. WS is a lv fluid and many dexron vi containers say ws compatible. You could always buy the genuine ws and have the mechanic of your choice install it. I know I would put any fluid a customer brought in, it is their car. Just charge the labor. Hope this helps.
Re: "Medallion ATF" for Toyota WS [Re: TmanP] #5268265 11/15/19 03:09 PM
G
Gebo Online Content
Online Content
G
If you want to keep your car for a long time, bring him some Toyota WS. It's not expensive. It's a lot cheaper than a transmission repair down the road.
Read MolaKule's post very carefully. And then read it again. His message is almost subliminal operating below the threshold of consciousness.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
Shell Gas and Truck & Pennzoil Full Syn HM
Toyota ATF's and Coolant
Amsoil Gear Oil and Grease
Re: "Medallion ATF" for Toyota WS [Re: TmanP] #5268342 11/15/19 04:10 PM
J
Joephu Offline
J
I'm going through this decision now for my 2016 Lexus ES 350 V6. Make sure the mechanic is familiar with the Toyota drain plug vs plastic overflow tube below the drain plug. The reason most mechanics don't want to touch it is because you have to get the fluid level perfectly. The right temperature range is critical for ensuring this. Check out this video that does a good job of going through the process. Personally, I would not trust a mechanics unless he/she could describe the step they will take to perform a drain and fill.
https://www.youtube.com/watch?v=CAxjhSphZBg&t=7s
Re: "Medallion ATF" for Toyota WS [Re: TmanP] #5269302 11/16/19 03:48 PM
G
Gebo Online Content
Online Content
G
I purchased the scan tool to check the AT fluid level as all my rides are Toyotas. It's easy when you find the appropriate temps to check the levels. I have a temp sheet if you need that info.
'98 LEX LS400 300K
'02 4Runner 245K
'05 Lex LS430 85K
'07 Lex GX470 65K
