Any major brand oil with a pour temperature below - 39 should work and keep it soft and pliable. Will repel water and Icey buildup. Good luck some left over top off full Synthetic oil should work just fine.
MMO? smells minty? Also can multi-use on a sewing machine....
For you beard sporting folks, what is your beard care in the frizzy dry cold weather?
Thank you
Wasn't aware of it changing with the weather... I trim it the same, wash it the same (bar of soap), shave the neck the same (right after showing, Gillette contraption, no cream).
I know in summer I have scrub the rest of me harder to get sunscreen off me, that I think is my only change in habit due to season.
