Volvo T6 (SI6) oil
by posaune - 12/05/19 12:59 PM
Strange VRLA AGM battery issue
by pschnahc - 12/05/19 12:20 PM
Slight whining on power pump.
by Umit - 12/05/19 12:15 PM
Mobil 1 video
by njohnson - 12/05/19 12:06 PM
F150 Syn 3 map updates, finally!
by wallyuwl - 12/05/19 11:49 AM
Visom and GTL Question
by Doublehaul - 12/05/19 10:42 AM
SuperTech 5-30 HM Full Synthetic 5qt. $14.37
by mbz321 - 12/05/19 10:09 AM
Mechanics and come backs
by motor_oil_madman - 12/05/19 08:33 AM
Camping World Labor Rate
by Redright9 - 12/05/19 08:09 AM
Best Batt Maintainer
by Smoky14 - 12/05/19 07:30 AM
MOPAR OEM floor mats
by OVERKILL - 12/05/19 07:22 AM
Pressing Index Finger on Forehead
by Gebo - 12/05/19 06:39 AM
Drove a 6spd manual yesterday...don't miss it
by wemay - 12/05/19 06:20 AM
Walmart Beef
by Duffyjr - 12/05/19 05:45 AM
Bilstein B6 = Made in Mexico
by The Critic - 12/05/19 04:02 AM
Repsol Elite Multivalvulas 10W-40
by FordCapriDriver - 12/05/19 01:21 AM
Harbor Freight coming to town
by Malo83 - 12/04/19 11:57 PM
Huge oil leak repair: 2001 Blazer 4x4
by 14Accent - 12/04/19 10:44 PM
Ronparise, DrPcFix, benny88, Blazs, UnderDawgAl
70041 Registered Users
119 registered members (apollo18, 94astro, Anduril, aquariuscsm, 28oz, 10 invisible), 2,344 guests, and 56 spiders.
Topics298,323
Posts5,133,004
Members70,041
Most Online3,589
Nov 2nd, 2019
2019 i30 Nline 1.6T and first service (1500km) #5267660 11/14/19 10:11 PM
R
rov137 Offline OP
R
Hi all
Not sure if this is posted in the right place but happy to move if need be. This is my first post here but I’ve been reading for a while.
My i30 Nline 1.6T (petrol) is due for its first service soon (1500km) and I have decided to do an oil change. Happy to hear from people who think this is waste.
Oddly enough, the service using their oil is $159, but the service using my own oil is $143. Firstly, is $159 decent for an interim service (oil+oil filter) change plus the little inspection they do at 1500km? It makes no sense to supply my own oil (which I was hoping to do) if the difference is only $16 + cost of own oil. There is only one other Hyundai Dealer in Canberra, (Aus) but I really don’t want to look into that as they were terrible when I visited during the buying process so I’d prefer to stick to the dealer I bought the car new from as they were quite good (service means a lot to me). For the actual first service (1yr/10k kms intervals) they minus $60 if I provide my own oil which is more like it.
Secondly, I’ve been doing a great deal of research regarding which oil would be best for this car. I’ve read most of the threads here and a bit elsewhere but it is just so confusing! The manual as well as a sticker on the engine says Hyundai Recommends Shell Ultra. But, the manual also states that for the 1.6T that ACEA A5/B5 is best (which Shell Ultra is not). The 5w30 (also rec in the manual) is C3, whereas the 5w40 is ACEA A3/B4, A3/B3. I’ve sent emails to both Shell and Hyundai to see what they suggest. The manual does say there when A5/B5 isn’t available in your country you can use A3/B4. Just odd they recommend and oil that doesn’t fit the ACEA rating that they also recommend. Has anyone got any updated experience or suggestion with this? In terms of API the manual doesn’t say a thing. The Shell Ultra 5w30 is API SN and the 5w40 is API SM/CF. I understand you can use C3 where ACEA A3/B4 is allowed – so the 5w30 does meet requirements but not preference, which is just odd.
Anyway, seems as the first service is only $16 less if I provide my own oil I might just stick with their oil which the service department informed me is Valvoline SynPower FE 5W-30. Seems to fit the ACEA A5/B5 in the manual but is API SL/CF which is ILSAC GF-3. Does anyone have any thoughts or experience with this oil? It looks like a decent oil from what I can see. I did read that Valvoline is not great for extended drain periods?
SAE 5W-30, API SL/CF, ACEA A5/B5, Ford WSS-M2C-913 C, B, A, Fiat 9.55535.G1
https://www.valvoline.com/en-austra...l/synpower-synthetic-engine-oil-fe-5w-30
Seems this Valvoline oil used extensively by FORD. Service department said this is the oil the turbos get at Hyundai.
Would love to hear peoples thoughts on all of this.
Thanks!
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: rov137] #5267697 11/14/19 11:21 PM
1
14Accent Offline
1
Can't help much on the oil choice, but $158 for an oil and filter change??!! I'm assuming that's in AUS, but still that's $108 US! And here I am thinking prices in MN are high...
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: rov137] #5267708 11/14/19 11:56 PM
G
geeman789 Offline
G
Wow, that is some serious ALPHABET SOUP goin' on ... here is some more .
The i30 has a direct injection turbo, so LSPI may be a consideration in oil choice. Look for SN + .
A/B: Gasoline and Diesel Engine Oils – “High SAPS”
A1/B1 Category is removed with these Oil Sequences.
A3/B3 Stable, stay-in-grade Engine Oil intended for use in Passenger Car & Light Duty Van Gasoline & Diesel Engines with extended drain intervals where specified by the Engine Manufacturer, and for severe operating conditions as defined by the Engine Manufacturer.
A3/B4 Stable, stay-in-grade Engine Oil intended for use at extended Drain Intervals in Passenger Car & Light Duty Van Gasoline & DI Diesel Engines, but also suitable for applications described under A3/B3.
A5/B5 Stable, stay-in-grade Engine Oil intended for use at extended Drain Intervals in Passenger Car & Light Duty Van Gasoline & Diesel Engines designed to be capable of using Low Viscosity Oils with HTHS Viscosity of 2.9 to 3.5 mPas. These Oils are unsuitable for use in certain Engines - consult vehicle-OEM’s owner’s manual/handbook in case of doubt.
C: Catalyst & GPF/DPF compatible Engine Oils for Gasoline & Diesel Engines – “Low SAPS”
Note: These Oils will increase the DPF/GPF and TWC life and maintain the Vehicle’s Fuel Economy.
Warning: Some of these Categories may be unsuitable for use in certain Engine Types – consult the vehicle- OEM’s owner’s manual/handbook in case of doubt.
C1 Stable, stay-in-grade Engine Oil with Lowest SAPS-Level, intended for use as catalyst compatible Oil at extended Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable of using Low Viscosity Oils with a minimum HTHS Viscosity of 2.9 mPas.
C2 Stable, stay-in-grade Engine Oil with Mid SAPS-Level, intended for use as catalyst compatible Oil at extended Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable of using Low Viscosity Oils with a minimum HTHS Viscosity of 2.9 mPas.
C3 Stable, stay-in-grade Engine Oil with Mid SAPS-Level, intended for use as catalyst compatible Oil at extended Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable of using Oils with a minimum HTHS Viscosity of 3.5 mPas.
C4 Stable, stay-in-grade Engine Oil with Low SAPS-Level, intended for use as catalyst compatible Oil at extended Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable of using Oils with a minimum HTHS Viscosity of 3.5 mPas.
C5 Stable, stay-in-grade Engine Oil with Mid SAPS-Level, for further improved Fuel Economy, intended for use as catalyst compatible Oil at extended Drain Intervals in Vehicles with all Types of modern Aftertreatment Systems and High Performance Passenger Car & Light Duty Van Gasoline & DI Diesel Engines that are designed to be capable and OEM-approved for use of Low Viscosity Oils with a minimum HTHS Viscosity of 2.6 mPas.
SAPS: Sulphated Ash, Phosphorus, Sulphur
HTHS: High Temperature High Shear Viscosity
DI: Direct Injection
DPF: Diesel Particle Filter
GPF: Gasoline Particle Filter TWC: Three-Way Catalyst
2011 SUBARU Impreza 5-door manual / 2016 HONDA Pilot / 2011 MAZDA 2 auto
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: geeman789] #5267728 11/15/19 12:52 AM
R
rov137 Offline OP
R
Yeah I know very expensive!
Wow so much info! I’ve been trying to decipher this stuff for the last day or so!
Hmm that’s interesting re the direct injection turbo and LSPI.
Would you say based on that the API rating is more important to ACEA? so the Shell Ultra which is C3 but SN would be superior to the Valvoline which is A5/B5 but only SL?
Just odd the owners manual says nothing about API rating and it only states that the car requires A5/B5. The saga Continues...
Any comments on dropping the oil at 1500km?
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: rov137] #5267743 11/15/19 02:52 AM
P
Panos Offline
P
C3 SN being "newer spec" does not mean it has superiority over A5/B5 SL.Its is in theory a different application spec
I am currently on the second run using Motul 913D specific which is Ford wss 913D approved and is SL and A5 also being (in theory) the best manufacturer approved solution even today in my Ford fiesta (which specced 913B certification nowobsolete after 913C and 913D).
The Valvoline FE 5W30 is Ford WSS-M2C-913D Approved, Jaguar Land Rover STJLR 03.5003 Approved.So basically the same thing as I use.If you trust the Ford way use that.
I cannot think about a reason not to change the oil at 1500km
Surely does not harm anything.
Ford Fiesta 1.6 '05 - Motul specific 913D/Motul Gear 300 180K+ Kms
Kawasaki Ninja 250R '08 - Shell Advance Ultra 4T 10w40 75K+ Kms
Honda CBR600F pc41 '14 - Motul 7100 10w30 25K+ Kms
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: rov137] #5267755 11/15/19 04:17 AM
PimTac Offline
Changing out the oil early on with a new vehicle is a personal decision. You will get answers both ways on that. For me personally, I change it out early. It gives me peace of mind.
In Australia I would use the A5-B5 rating. Shell Helix is available as I understand.
2017 Mazda CX5
Havoline Pro DS 0w20
Roki OEM filter.
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: rov137] #5267795 11/15/19 06:09 AM
K
ka9mnx Offline
K
Wow! Manufacturer says you can use A5 or A3. There is a big difference between those 2 oil specs. Being a new vehicle, I would concentrate on using the A5.
2005 Ranger 3.0 - SuperTech Syn 5w-30/Motorcraft
2000 4Runner 3.4 - SuperTech Syn 5w-30/Toyota
1997 B2500 Van 3.9 - M1 HM 10w-30/Mopar
1993 F150 4.9 - SuperTech Syn 5w-30/Motorcraft
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: rov137] #5267798 11/15/19 06:14 AM
DuckRyder Offline
FWIW, there is apparently an A5/B5 Helix Ultra, but it only seems to be available in bulk quantities...
Quote
Helix Ultra Professional AF 5W-30
Fully synthetic motor oil Tailored to meet engine manufacturers special requirements. Shell Helix Ultra Professional AF 5W-30 is designed to meet the demanding requirements of particular high-performance engines, including Ford and those requiring ACEA A5/B5. Shell and Ford have local relationships in many countries, and Shell is a major supplier to Ford in India and the USA. Passes an extensive range of performance tests to meet engine oil specification WSS-M2C913-C/D. Specifications: API SL, ACEA A5/B5; Ford WSS-M2C913-C/D; Jaguar Land Rover STJLR.03.5003. Available in 20L, 209L
Robert
  • 2019 Volkswagen Jetta R-Line
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: rov137] #5267809 11/15/19 06:38 AM
R
rov137 Offline OP
R
Thanks for all the responses much appreciated!
Seems like the general consensus here is to meet the ACEA (A5/b5) spec before anything else - guess it was just confusing that my manual states that A5 is preferred but so is helix which I cannot access easily.
Interesting to learn you can buy an A5 helix it in bulk! Would be perfect if the Helix Ultra professional A5/b5 was available in a 5L or something. Sounds like the A5/b5 valvoline that the service department would be ok for me and not such a bad oil.
I was looking at this Penrite oil earlier but it’s 5w40. It says that where A5/b5 is needed for fuel economy.. which is a bit weird - https://www.supercheapauto.com.au/p/penrite-penrite-hpr-5-engine-oil---5w-40-6-litre/518961.html?vid=Y0JJTSANQGugMGLQh8qEpA%3D%3D&cgid=SCA01070403
Any thoughts on 5w30 vs 5w40. From what I can understand 5w30 is more applicable to me and a bit better?
Yeah it is odd you can use either A5 or a3 - but only if A5 isn’t in your country it says - which it is.
Maybe I’ll check the oil before the 1500km service and see if it is still a golden honey color.
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: ka9mnx] #5267887 11/15/19 08:20 AM
donnyj08 Offline
Hyundai Manuals recommend changing the oil the first time at 2k miles. At least our 1.6T Tucson Manual says this. 5k normal following and 3k for severe service.
OP,
Find a 5w30 meeting A5 and preferably SN+ if you can.
2008 Silverado Z71 LT 99k PP 10w30
2016 Tucson Limited 1.6T AWD 29k M1 5w30 AP
2016 Yamaha XSR900 13k, Spectro 10w40, Yamaha Filter.
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: rov137] #5267927 11/15/19 09:06 AM
Smokescreen Offline
...and how much to drain the oil and replace it with fresh..on your own?
13 Civic Si 2.4L-105Kkms(66Kmi)-QSUD,Wix
05 LeSabre 3.8L-294Kkms(184Kmi)-QSUD,Wix
03 Sierra 2500 6.0L-209Kkms(130Kmi)-QSUD,Wix
All with mpg > EPA
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: rov137] #5268011 11/15/19 10:17 AM
K
ka9mnx Offline
K
Vanilla Mobil1 5w-30, available at WalMart, is A5/B5, API SN, SN+ and dexos 1 gen 2. I would stick with 5w-30.
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: ka9mnx] #5268022 11/15/19 10:31 AM
W
wemay Offline
W
Great choice but he's in Australia.
2018 KIA Sportage LX AWD
Shell RGT 5W30, STP S2808
2013 Hyundai Santa Fe Sport 2.0T
M1AP 5W30, M1-104
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: rov137] #5268282 11/15/19 03:27 PM
R
rov137 Offline OP
R
My manual says nothing about an oil change until the first proper service at 10, 000km. Even the service department said I’m the only one who has asked to have the oil changed at the 1500km inspection.
I think I’d feel more comfortable having it done given it’s a turbo car.
That Vanilla Mobil1 oil looks perfect.. but yeah not available here in Aus. I’ll keep looking for a 5w30 A5/b5 SN+ oil but failing that I guess A5/b5 takes preference?
Edit
This seems to fit A5 and SN+. It is very expensive though!! Worth it?
https://www.m1oils.com.au/product/mobil-1-5w-30/
Re: 2019 i30 Nline 1.6T and first service (1500km) [Re: rov137] #5268319 11/15/19 03:52 PM
PimTac Offline
Find out what the service department uses.
2017 Mazda CX5
Roki OEM filter.
