105 registered members (14Accent, 4WD, alchargo, Aero540T, 28oz, 4 invisible),
2,542
guests, and 41
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,328
Posts5,133,079
Members70,041
Most Online3,589 Nov 2nd, 2019
Garbage Disposal Replacement
#5267650
11/14/19 09:58 PM
bunnspecial
OP
OP
Posts: 1,079 |
My garbage disposal quit working a months ago, and along the way I also noticed that the disposal side of the sink(2 basin) seemed very slow to drain. This past week, my dishwasher also started overflowing(primarily out the overflow, but on one occasion out the front-that was accompanied by the disposal side of the sink filling up with water also). I finally buckled down this evening and pulled the disposal off. AFAIK, it's original to when the townhome was built in 2006, and it's pretty nasty and crusty(and totally seized up). I capped off the drain on that side of the sink, and filling the disposal with water it's VERY slow to drain out-I'm guessing this is the source of both my dishwasher and slow basin drain(the dishwasher drain is connected to the disposal). Given that there's no wiring to speak of involved(it has a standard GFCI outlet under the sink that the disposal plugs into) I can't imagine that replacing it is beyond my capabilities. Aside from cleaning up the flange in the drain and putting some fresh plumber's putty around it, it looks like a bolt-on job. What I just pulled out is a Badger 1 1/3 HP. It seems to be the same as this https://www.lowes.com/pd/InSinkErator-Badger-1-1-3-HP-Continuous-Feed-Garbage-Disposal/1267193That seems the obvious replacement since-assuming it hasn't changed in ~13 years-it should bolt right on without any plumbing configuration. For obvious reasons, that gets a strong nod. With that said, I'm wondering if it's worth an upgrade. I'm going to be moving/selling in the next year. I hate to kick the problem to the next owner, but at the same time longevity isn't a huge concern for me. My single biggest use for it is to dispose of the remains of the couple of apples a week I eat, and it rarely sees much beyond other fruit(oranges, peaches, and the like). Is it worthwhile to step up to a 1/2 HP unit? What about a different brand? There again, I'm trying to avoid a plumber bill(I'm still hurting from a water heater two weeks ago, which was extra expensive since whatever moron designed the place thought a closet 8 ft in the air was a good location) and would prefer something ideally that's as close to plug and play as I can make it. FWIW, the current plumbing configuration has a rubber flex hose coming in for the dishwasher drain, and then a PVC attached out the side using what looks like a distributor clamp on an engine. It's about a foot of straight PVC pipe over to where it Ts with the drain from the right basin, and then the combined ones run down into the trap and from there out of the cabinet. Any thoughts on this?
2010 Lincoln MKZ-Mobil 1 5W-30 1970 MG MGB Roadster-Valvoline VR-1 20W-50 1974 Austin Marina GT VR-1 20W-50
Re: Garbage Disposal Replacement
[Re: bunnspecial]
#5267669
11/14/19 10:25 PM
dafish
Posts: 22 |
When i bought our first home 30 years ago my wife started destroying the things. After three minor upgrades i put in the biggest baddest unit available. I believe that disposal is still going (i know the folks that bought it). 16 years ago i built this house and did the same thing. And again I’ve never thought about it again.
Last year my son started homeownership and history repeated itself. Young housewives, I expect, are part of the problem.
In any event, I’m about 1hp, auto-reverse, stainless steel baskets and shafts and etc.
Yes its overkill. But i do most things like that, and i get a premium for things i sell, so it works out. All 3 of mine have been insinkerators...
[Re: bunnspecial]
#5267687
11/14/19 10:56 PM
JohnnyJohnson
Posts: 5,626 |
For two apple cores a week save yourself some money and just put them in the garbage.
2004 Corolla 137331 Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457 In: Pennzoil Platinum HM 5W-20 ST 4386 2006 Duramax 76862 Out: T6 5W-40 XG9100 73705 In: Rotella Dino PH9100 11-3-19
[Re: bunnspecial]
#5267786
11/15/19 05:55 AM
danez_yoda
Posts: 1,132 |
I vote drop in tye same unit that came out. make sure the unit is physically the same so all your connections match. you got 13 years out of this one, cant complain about that for a $99 unit.
replacement is easy. i didn't bother changing the sink drain. just unbolt from the drain and pipes then bolt in the new on,
quick and easy and you are ready for another 10+ years, those badgers come in every new built home ive been in,
[Re: bunnspecial]
#5267800
11/15/19 06:16 AM
Fawteen
Posts: 542 |
With that said, I'm wondering if it's worth an upgrade. I'm going to be moving/selling in the next year. If you're selling soon then it's not worth the upgrade. If you were staying long term I'd make a case for a higher quality disposer, but not this time.
2014 Silverado 2014 Equinox 1972 Olds 442 Convertible 1918 Model T
[Re: bunnspecial]
#5267807
11/15/19 06:34 AM
PimTac
Posts: 11,642 |
If you are planning to move I would just delete the disposal and plumb it normally.
2017 Mazda CX5 Havoline Pro DS 0w20 Roki OEM filter.
[Re: PimTac]
#5267822
11/15/19 07:07 AM
SVTCobra
Posts: 889 |
If you are planning to move I would just delete the disposal and plumb it normally. Me too. Never understood the love for disposal units. Just throw the food in the trash.
Think twice, speak once.
[Re: bunnspecial]
#5267825
11/15/19 07:20 AM
Miller88
Posts: 13,735 |
My previous apartment had an insinkerator. Every year it would have to get replaced. It would either burn the motor up or start leaking. At one point it started leaking water out the power cord!
18 Forester 2.5I 6M 00 Jeep XJ 01 F-350 4x4 5M
[Re: SVTCobra]
#5267853
11/15/19 07:51 AM
BMWTurboDzl
Posts: 4,293 |
If you are planning to move I would just delete the disposal and plumb it normally. Me too. Never understood the love for disposal units. Just throw the food in the trash. Answer: People hate having to take out the trash. Consequently a "normal" size trash can/will start to stink before it's even full when you're dealing with a small household. Esp in the summer.
435i
[Re: bunnspecial]
#5267858
11/15/19 07:59 AM
WylieCoyote
Posts: 592 |
I upgraded (can't remember which one) a couple of months ago when our 9-year-old base-model Badger seized. Quite a bit larger in diameter, and a little taller, but man is it quiet in comparison. You could hear the badger from the other side of the house, but you have to turn off the faucet to hear this one running. Takes up more room under the sink, and I had to re-do most of the pipes because the output was lower. Not sure it's worth all that just to move away soon.
Install a high-end disposal in your new house. The quiet is worth it.
2015 GMC Canyon 3.6 2018 Mustang Ecoboost Convertible 2018 Mustang Ecoboost
[Re: bunnspecial]
#5267907
11/15/19 08:50 AM
JMJNet
Posts: 1,346 |
x2 for wasteking.
I put the 1 HP, at that time cost around $90, now a little more but with LT warranty. The previous one was Wasteking 1/2 HP and last me about 10 years.
The 1/2HP replaced an ISE and it was easy to replace. You can get the 1/2HP wasteking if you want cheap.
- 2017 Toyota Sienna
- 1995 GMC Suburban 6.5L Turbo Diesel
[Re: bunnspecial]
#5267919
11/15/19 09:01 AM
Chris Meutsch
Posts: 2,827 |
Replace with a like unit. Why spend more?
2005 Honda CR-V EX, 278k
[Re: bunnspecial]
#5267945
11/15/19 09:17 AM
JeffKeryk
Posts: 2,610 |
If an upgrade is in the budget, I would do it. I bought a couple from Costco as the price is generally pretty good.
2018 Tesla Model 3, Medium Range Battery 2018 Lexus RX450h 2013 Lexus GS350 F Sport 2006 Acura TSX 2001 Tundra Access Cab, 1998 Accord LX, 1968 Corvette L36 Roadster, 1965 Olds 4-4-2
