"Im not an expert and this is just one UOA"
Then you have Blackstone theories and conclusions about 5w40s being superior to 30ws in iron wear...
Running TDT in a gasser v6....Considering potential return policies as a factor for choosing an oil in case you change your mind...
Where to start? This thread is a mess and your logic and conclusions are flawed.
Run another UOA with 5w30 SuperTech and look at the results. I would bet it's almost exactly the same. You're dealing with parts per MILLION and nobody learned anything from this data, including you.
