Originally Posted By: lubricatosaurus
Originally Posted By: MolaKule
Phosphorodithioic acid, mixed O, : 1 - 3 % 84605-29-8 283-392-8 ----- 01-2119493626-26 Xi; R38-41N; R51-53 O-bis(1,3-dimethylbutyl and isoPr)esters, zinc = ZDDP and nothing else.
The 1% ZDDP then is 10,000 ppm. Thats incredibly high levels of ZDDP, or the MSDS is lying.
For GVX, that same chemical line on it's MSDS was a more sensible 1000 ppm.
The specification is for phosphorus, which is only about 6% of ZDDP. Therefore the ZDDP needs to be dosed at >1% to deliver the spec quantity of phosphorus.
Each company has its own formulation philosophy. Some seek the lowest cost formula that just skinnies by the specs, while others formulate for maximum performance, or for specific properties that will support a differentiating marketing claim.
The use of expensive base oils is sometimes a clue that the company is more performance oriented, but not necessarily if the PAO is required for a given spec. The use of PAO does not significantly reduce additive cost, at least not as much as the PAO raises cost. Some companies actually use more additives with their synthetic offerings because these oils are intended to be their best foot forward. In addition, the cost difference between the synthetic base oils and additives is less, thus reducing the net treat cost.
Of course these corporate philosophies and practices are invisible to consumers, and the few clues we get are insufficient to determine relative performance. We need to rely on specifications met and the company's reputation. Fortunately the specification bar is set high and all oils certified against SN or GF-5 will provide adequate engine protection.
Tom NJ
