New Mercedes Ute
by Shannow - 01/25/20 03:04 AM
A decent battery charger for sub $50?
by michaelluscher - 01/25/20 02:03 AM
Temperature swing affects on oil
by leeaspell - 01/25/20 12:58 AM
Coefficient of Friction
by jrommelt - 01/24/20 11:46 PM
2017 Chevy Cruze Diesel Oil
by Ponch - 01/24/20 11:03 PM
electric motor amp rating
by motor_oil_madman - 01/24/20 10:42 PM
Radio, Instrument panel, display, AC cutting off
by DrDanger - 01/24/20 09:39 PM
Filter Brand Quality Change?
by BBDartCA - 01/24/20 09:21 PM
Autozone $7 off $30
by GMguy84 - 01/24/20 09:17 PM
Honda Power Steering Fluid
by shortlid - 01/24/20 09:14 PM
Autozone Clearance 2020 M1EP
by GMguy84 - 01/24/20 09:11 PM
Spark Plugs
by A_Spruce - 01/24/20 09:00 PM
Flank drive wrenches
by spasm3 - 01/24/20 08:39 PM
Auto assembly and mfg. logistics
by P10crew - 01/24/20 08:26 PM
Kodiak
by P10crew - 01/24/20 08:05 PM
yet another black eye for the 2,4 ecotec
by super20dan - 01/24/20 07:52 PM
New incentive for 0w20
by Snagglefoot - 01/24/20 06:43 PM
Pete44, Connie7, 2020XT, 4strokes, Perseus
70518 Registered Users
26 registered members (Black_Thunder, Bighorn2500, bbhero, d00df00d, Char Baby, ctechbob, 3 invisible), 1,532 guests, and 20 spiders.
Topics300,519
Posts5,177,614
Members70,518
You ever spray paint inside the house? #5266883 11/14/19 09:48 AM
A
atikovi Offline OP
A
Spray can says to spray only above 60F but it won't get above 40 for a few days. Need to do a set of wheel covers. Will have to do it down in the basement. Quickly and holding my breath as long as possible. Any other options?
Re: You ever spray paint inside the house? [Re: atikovi] #5266896 11/14/19 09:53 AM
J
JC1 Offline
J
Wear a respirator or dust mask? I spray painted my Sienna door handle inside during the winter. Get lots of drop cloths or cardboard.
What about going to an underground garage to get this done? Get on the lowest level you can. It should be warmer than 40 degrees inside.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: You ever spray paint inside the house? [Re: atikovi] #5266923 11/14/19 10:13 AM
M
MasterSolenoid Offline
M
What about quickly painting outside and then 'immediatly' bringing the Wheel Covers inside ?
If you paint in the basement, make some type of spray-booth out of cardboard and use plenty of 'plastic' drop-cloths.
Last time I spray painted in the basement, it gave my Furnace a yellow flame (should be blue).
A few days later, the fumes dissipated and flame returned to blue.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: You ever spray paint inside the house? [Re: MasterSolenoid] #5266929 11/14/19 10:20 AM
A
atikovi Offline OP
A
Spraying 2-3 coats of paint and then another of clear would be pain for just one let alone four.
Re: You ever spray paint inside the house? [Re: atikovi] #5266931 11/14/19 10:23 AM
A
atikovi Offline OP
A
How does a respirator mask work? Aren't you breathing in the same air you just exhaled if that thing is over your face? Or is there a mouthpiece you suck on when exhaling?
Re: You ever spray paint inside the house? [Re: atikovi] #5266944 11/14/19 10:37 AM
K
kschachn Offline
K
No, there is a one-way valve in the face piece that allows you to exhale. Any incoming air passes through the absorbent material in the canisters.
1994 BMW 530i, 251K
1996 Honda Accord, 280K
1999 Toyota Sienna, 430K
2000 Toyota ECHO, 284K
Re: You ever spray paint inside the house? [Re: atikovi] #5266971 11/14/19 11:10 AM
I
IronMaidenRules Offline
I
You 100% without a doubt need a respirator. They're like $15-20 online or at Home Depot. And prepare for the whole house to smell like paint for several days. There's no possible way to keep the smell contained to just the basement. I only say this because if you live with other people, they WILL complain. smile
"BITOG - You will never find a more wretched hive of scum and virginity." - Obi-wan Kenobi
Re: You ever spray paint inside the house? [Re: atikovi] #5266982 11/14/19 11:16 AM
A
atikovi Offline OP
A
Yea, I know the place will smell like a meth lab. Not the first time doing it, or baking calipers in the oven for that matter.
Re: You ever spray paint inside the house? [Re: atikovi] #5266985 11/14/19 11:17 AM
F
Fawteen Offline
F
I would never spray aerosol paint inside the house. We don't have a basement, but it sounds like the perfect way to see your name on a darwin awards website. Much like driving with your eyes closed, it only takes once to realize what a bad idea it was.
Re: You ever spray paint inside the house? [Re: atikovi] #5267030 11/14/19 12:02 PM
R
ragtoplvr Offline
R
do you have a shop vac. Make spray booth out of box. Hose in back to shop vac sitting outside.
Wear respirator. Harbor freight sells pretty decent one for $30 ish with coupon.
Rod
Re: You ever spray paint inside the house? [Re: atikovi] #5267031 11/14/19 12:03 PM
supton Offline
I've sprayed a few things outdoors, then brought inside where it was warmer. Rarely though. IMO I'm not interested in any amount of financial gain that requires me to smell spraypaint for days on end.
If you have a garage then try it out there. Otherwise... wait for spring or the next warm day. Or maybe you have a friend's garage (or house or basement) that you could do this in?
2011 Toyota Camry, base, 2.5L/6MT, 200k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 157k, ours
1999 Toyota Camry LE, 2.2L/4AT, 220k, his
Re: You ever spray paint inside the house? [Re: atikovi] #5267078 11/14/19 12:42 PM
Z
zzyzzx Offline
Z
You can bring everything outside for a few minutes just to spray paint it (so your paint and objects to be painted are warm enough). That's only part of the problem. The off gassing from the painted objects will still stink up your basement. Now if your basement is big enough, and the objects are small enough, sure.
Re: You ever spray paint inside the house? [Re: atikovi] #5267094 11/14/19 12:54 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Can you create a spray space in the bathroom? You could turn on the vent fan.
Probably not. The spray mist would likely get everywhere.
Re: You ever spray paint inside the house? [Re: atikovi] #5267096 11/14/19 12:54 PM
N
nthach Offline
N
I've sprayed on SprayMax 2K clear in the garage a while ago. Not ideal, certainly won't do it again without some kind of forced air(isocyanates). Maybe next time when I get my scuba certification, I'll wear a pony bottle and my regs since I have a feeling I need to restore my headlights in the spring.
The problem with consumer level aerosols is all the overspray and they have a sucky transfer ratio compared to a real spray gun. The SprayMax and U-Pol aerosols due to a spray gun-like fan tip and higher pressurization spray almost like an HVLP spray gun.
Rust-Oleum is now coming out with their "turbo" spray can which promises spray gun like results but the can looks unwieldy. I saw one at Home Depot filled with Zinsser primer. https://www.rustoleum.com/pages/turbo-spray
Re: You ever spray paint inside the house? [Re: atikovi] #5267296 11/14/19 04:13 PM
E
ET16 Offline
E
You'll still get a few warm days. You'll just need to wait. Remember a few weeks ago when it was 75?
