Straight 30W [Briggs & Stratton] @ Amazon
by SlavaB - 04/05/20 10:56 PM
Bosch 3323 Premium Filter Cut Open
by TrainingPolicy - 04/05/20 10:29 PM
CARQUEST Premium Oil filter 84341 Cut Open
by TrainingPolicy - 04/05/20 10:12 PM
C-1706 SAKURA Cut Open
by QuangTeo - 04/05/20 10:07 PM
Had to smile
by AZjeff - 04/05/20 10:04 PM
Childhood friend dies
by Marco620 - 04/05/20 10:00 PM
Leftover 100LL in vehicle
by PantherFan88 - 04/05/20 09:42 PM
The good old days.:)
by A310 - 04/05/20 09:04 PM
Harvest king switched suppliers confirmed.
by Micahmcmeen - 04/05/20 08:15 PM
Mobile 1 Synthetic 15w/50 - Not what it used to be?
by NorCalHD - 04/05/20 06:21 PM
Bad Rear Brakes- Not obvious
by ford46guy - 04/05/20 05:03 PM
Move car w/ NO coolant?
by SavagePatch - 04/05/20 04:39 PM
VIRGIN BOSCH 3400 CUT OPEN
by 53' Stude - 04/05/20 04:18 PM
First vehicle you ever purchased?
by 53' Stude - 04/05/20 03:56 PM
Recommendation for a high mileage engine
by khouan - 04/05/20 03:36 PM
My dog did not make it.
by Chris142 - 04/05/20 03:02 PM
Pennzoil Platinum
by tiger862 - 04/05/20 02:40 PM
Grease for bicycles?
by JTK - 04/05/20 01:28 PM
F7daved, khouan, daniell, carguy1701, London
71106 Registered Users
67 registered members (53' Stude, alphadog, 4WD, ae101, alchargo, 928, 5 invisible), 1,688 guests, and 19 spiders.
Topics303,655
Posts5,239,222
Members71,106
Duramax Rear Differential 12,000 on fluid/25,000 total miles #5267287 11/14/19 04:58 PM
wwillson Offline OP
Administrator
Administrator
This is a 50/50 mix of SuperTech 75w-90/75w-140 run for 12,000 miles mostly pulling the truck has a total of 25,000 miles.
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: wwillson] #5267401 11/14/19 06:56 PM
JohnnyJohnson Offline
I'm not used to looking at UOA for Rear Differentials. But that FE seems really high to me? Am I wrong? Was the Lubricant very discolored? Its been 20,000 miles plus for my Duramax now. I was thinking next summer to get it done. Did you use OEM Lube or something else?
2004 Corolla 139604
Out: Havoline Pro DS 10w-30 Purolator PureOne 10-29-19 136457
In: Pennzoil Platinum HM 5W-20 ST 4386
2006 Duramax 77060
Out: T6 5W-40 XG9100 73909
In: Rotella Dino PH9100 11-3-19
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: wwillson] #5267412 11/14/19 07:05 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
The teeth of hypoid gears experience more sliding wear than many other gear designs. I would expect Fe content to be high.
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: wwillson] #5267433 11/14/19 07:29 PM
N
N Heat Offline
N
Are you staying with 12k OCI or extending further?
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: wwillson] #5267455 11/14/19 07:48 PM
B
BISCUT Offline
B
I'm all in on the early drain and fill. What do you plan on for the next drain fill? Meaning mileage? I did my F150 at 25k and will do it again at 100k. Just wondering what you plan. I also did my Subaru at 30k and will do again at 100k. And then again at 200k and then never again til she is put down.
2015 F150 Lariat M1 5-30 EP FRAM Ultra(44k)
2017 Sub OB M1 5-30 EP FRAM Ultra(74k)
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: wwillson] #5267661 11/14/19 11:13 PM
wwillson Offline OP
Administrator
Administrator
Biscut,
I will probably go to 25,000 for the next interval. Does anyone know what GM recommends? I can't find it in my manuals.
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: wwillson] #5267682 11/14/19 11:46 PM
P
PiperOne Offline
P
A quality 75W90 (we use Chevron Delo stuff) will easily go 500,000 miles in a AAM or Dana rear axle on a GM. We do it, and have had ZERO failures. We dump the factory oil at the first service (usually around 10k miles) it's usually kinda nasty, and put in the Chevron and forget about it.
HDEO in Diesel Engines. No spark plugs here.
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: wwillson] #5267724 11/15/19 01:39 AM
L
LubeFiner Offline
L
I was always recommended M1 75W90 in my gm’s. I used RP Max-Gear 75W90 in my Express 2500HD van. That diff was smooth as butter along with being as quiet as a mouse. I realized the highest fuel economy with RP products also.
2008 Jeep Patriot Sport FWD 2.4L 246K QSUD 5w20 Fram UG
2000 Ford Expedition AWD 4.6L Cleveland 298K STech FS HM 5W30 FL-820S
1998 Dodge Grand Caravan FWD 3.8L V-6 163K Car Heaven
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: JohnnyJohnson] #5267808 11/15/19 07:34 AM
2015_PSD Offline
No, it is not high. My 2015 F250 had 339PPM of FE with only 8,600 miles on the first OC. The vast majority of axle wear occurs in the first 15,000 miles or so and despite longer and longer runs the wear metals will continue to drop.
2019 o)|||||(o Rubicon Wrangler Unlimited 3.6L V6 [Castrol Edge + Hastings]
2018 Mercedes Benz C300 2.0L Turbo [Pennzoil Platinum + Mann filter]
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: 2015_PSD] #5267817 11/15/19 07:57 AM
4WD Online Confused
Online Confused
Yep
First 17k of 2017 Tahoe
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: wwillson] #5267834 11/15/19 08:33 AM
Snagglefoot Offline
Biscut,
You won’t like this Dubya.
From the 2018 Duramax Supplemental manual it does not suggest a differential oil change, at least not in the first 150,000 miles. Same for the 2020 Silverado manual.
From my 2008 owners manual on my 3/4 ton Chev, it does not suggest differential fluid change as well. I did one at 100,000 miles using AC Delco 75W90 Synthetic and another at 175,000 miles using Motomaster 75w90 Synthetic.
It runs perfectly with 180,000 miles on it.
For the transfer case it suggests 50,000 miles but I do it every two years. It’s as easy as an oil change.
YRMV. smile
If you want the job done right......do it yourself.
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: wwillson] #5267874 11/15/19 09:10 AM
Snagglefoot Offline
AC Delco 75W90 Synthetic after 75,000 miles with some towing. 10-3/4 inch 14 bolt in a Chev 3/4 ton with 175,000 miles. smile
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: Snagglefoot] #5267876 11/15/19 09:10 AM
4WD Online Confused
Online Confused
Same here … AAM builds the axle and there is nothing in my manuals …
Just thinking 50k still works after an early change
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: wwillson] #5268237 11/15/19 03:34 PM
U
userfriendly Offline
U
I find that GM under fills their differentials in my opinion. I like about 1.5 inches below the fill hole. I'm slowly switching everything to 80W140 Chevron & Petro-Canada.
Re: Duramax Rear Differential 12,000 on fluid/25,000 total miles [Re: userfriendly] #5268306 11/15/19 04:43 PM
B
BlakeB Offline
B
Spec is 17-21 mm (0.6-0.8 inches) below fill hole.
