508.00-509.00 oil for Honda K24Z3?
by allepunta - 12/08/19 01:36 AM
2020 Toyota Sequoia TRD Pro
by john_pifer - 12/08/19 01:26 AM
Liqui moly viscoplus
by Toh1 - 12/07/19 10:14 PM
Bought me a lemon 15 focus
by gabriel9766 - 12/07/19 10:12 PM
New axle fixed steering pull?
by Chris142 - 12/07/19 09:52 PM
E-core super tech vs Fram orange can 10k
by Doublehaul - 12/07/19 09:01 PM
Interesting trend at my local walmarts
by N Heat - 12/07/19 08:39 PM
Stp S2 oil filter come with silicone ADBV for $4.99
by MetalSlug - 12/07/19 07:50 PM
RATS
by MrQuackers - 12/07/19 07:46 PM
First Day of Summer in New Zealand.
by Silk - 12/07/19 07:02 PM
Gumout Regane Complete 6pk for $22.79
by volk06 - 12/07/19 06:15 PM
Basement sewer smell/Plumbers info req'd.
by irv - 12/07/19 06:03 PM
Project Farm tests car batteries
by cwilliamsws6 - 12/07/19 05:59 PM
Is this normal?
by TurboLuver - 12/07/19 05:12 PM
Any Scooter Riders?
by Passport1 - 12/07/19 03:20 PM
High Performance Lubricants
by wwillson - 12/07/19 02:27 PM
Student laptop needed.
by irv - 12/07/19 01:13 PM
4 unifi AP
by BeerCan - 12/07/19 12:25 PM
Another OCD battery ?
by Gebo - 12/07/19 11:45 AM
smlobx, bithebay87, Keelin, professor229, MxTale
70063 Registered Users
36 registered members (ArrestMeRedZ, 4WD, bbhero, adams355, carlprop, allepunta, 3 invisible), 1,081 guests, and 61 spiders.
Topics298,430
Posts5,135,262
Members70,063
Most Online3,589
Nov 2nd, 2019
Mercedes coolant mixed #5267087 11/14/19 12:49 PM
R
Rohan Offline OP
R
Last year I had a coolant drain at the independent mercede shop n I only used blue coolant Mercedes with distilled water. After that I told him don’t we need to bleed the system. He said no because it a self bleeding so I said okay. 1 years later I had a coolant light came on so I didn’t have a blue coolant and they didn’t have one either. They told me to use zerex green coolant so now I have green with Mercedes blue coolant. I’m worried now do I need to change it to blue? Before I changed it I’m going to check for leak. There’s no way that mercede is self bleeding because couple day ago while adding the green coolant I left the cap off and after 40 mins I saw 3 bubbles and that it. Fan never came on unless I missed it (because went back to the house because it was to cold outside).
2011 e350 v6 m272
122k mileages
Re: Mercedes coolant mixed [Re: Rohan] #5267098 11/14/19 12:55 PM
W
Wolf359 Offline
W
Yeah, it's basically self bleeding. A few bubbles doesn't mean otherwise. I just use Zerex G-05 in it.
Re: Mercedes coolant mixed [Re: Rohan] #5267126 11/14/19 01:16 PM
N
nthach Offline
N
Mercedes switched over to G-48 for the pre-2014 cars a few years ago and they do say it's OK for older cars. Zerex green is a old school silicated-phosphated IAT with some qualities of a OAT.
I'd flush out and fill up with G-05 or G-48.
Re: Mercedes coolant mixed [Re: nthach] #5267166 11/14/19 01:47 PM
P
Pelican Offline
P
Good advice! MB mistakes always morph into big $$$$ bills.
Re: Mercedes coolant mixed [Re: Rohan] #5267168 11/14/19 01:48 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I’ve never had issues bleeding my Mercedes cars, but they do need to be filled slow.
I wouldn’t want green in there. G-05 was an appropriate tip up if G-48 wasn’t available. Wouldn’t touch anything else besides straight distilled in a pinch.
G-48 is ubiquitous so you should be able to find it.
I’d do a couple drains and refills and then worry about something else.
Re: Mercedes coolant mixed [Re: Rohan] #5267238 11/14/19 02:59 PM
A
atikovi Offline
A
Never mix coolants of different chemistries. Why didn't you just add straight water if you couldn't get the Mercedes coolant at the time?
Re: Mercedes coolant mixed [Re: Rohan] #5267252 11/14/19 03:16 PM
R
Rohan Offline OP
R
Thank you everyone for reply. I’m heading to mecredes to buy 2 gallon of coolant and buy 1 gallon of distilled water(buying extra gallon for backup for future). For now I’m going to drain the coolant and add the coolant with distilled water until weather warm up. Because I don’t want to drive with water because chances of cracking the motor. Weather down here dropping low.
Is mercede really a self bleeding? I was thinking of bleeding like we do it normally or do I need to buy air purge tool kit?
Leave the cap off n let it run until fan come with heated running.
Do I set the heater blower to highest setting ?
I know temperature need to be 90 degrees.
Re: Mercedes coolant mixed [Re: Rohan] #5267277 11/14/19 03:46 PM
F
Fotoflame Offline
F
I don't have a W212, but I do have a W210 E Class and can tell you that the system in my car is self bleeding. My car doesn't have a cap on the radiator. Only way to fill coolant is through the reservoir. I would guess yours is the same way.
If so, fill the car with coolant and get to operating temperature with reservoir cap closed. Do have the heater on high to make sure the coolant flows through the heater core. Check for leaks. Adjust coolant level as necessary. Drive on!
Re: Mercedes coolant mixed [Re: Rohan] #5267300 11/14/19 04:20 PM
CharlieBauer Offline
Since you mixed in green with G48 blue, you should do a thorough flush as they don't mix.
Note that pink G40 is now the standard coolant for Mercedes. But it doesn't mix with G48 or G05.
I would think the dealer will give you the blue G48 though. Or just get the Zerex g48 from somewhere else eg Napa, Pep Boys.
It ain't what you don't know that gets you into trouble. It's what you know for sure that ain't so.
- mistakenly attributed to Mark Twain
Re: Mercedes coolant mixed [Re: Fotoflame] #5267789 11/15/19 05:56 AM
R
Rohan Offline OP
R
I just google on what type of reservoir you have and mine look like that. So can I leave the cap off then start the car?
When u said heater on high is that mean fan need to on the highest setting? I know temperature need to be high anyway.
Re: Mercedes coolant mixed [Re: Rohan] #5267791 11/15/19 05:57 AM
R
Rohan Offline OP
R
I’m going to end up buying the g48 coolant since it already pro-mixed
Re: Mercedes coolant mixed [Re: Rohan] #5267928 11/15/19 09:06 AM
F
Fotoflame Offline
F
I think it's ok to have the cap off so long as you are starting the car cold. If it's hot and you open the cap, you run the risk of hot coolant spraying.
I have automatic climate control so I set it to where the temperature setting reads "HI" instead of a number. When it's set like that, the heat and fan are at max. So yes I would have the fan on hi so that the car keeps sending hot coolant through the heater core.
Re: Mercedes coolant mixed [Re: Rohan] #5268174 11/15/19 01:32 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
I’d drain and refill the radiator a few times. Especially if you only do this, bleeding will be easy.
I find on MB you’re best off to point the nose up slightly, then just add very slowly.
Re: Mercedes coolant mixed [Re: Rohan] #5271002 11/18/19 04:32 PM
R
Rohan Offline OP
R
Sorry for late reply was busy over the weekend. I had a chance to drain the coolant first time and drove around the city for 5 min then came back home and shut it off after 40 min (idling) while filling up the air on tires. My question is I want to do 2nd drain but not today (tomorrow) the reason is that it to cold outside. Can I do it tomorrow? Cold temperature won’t crack the motor by itself. Right?I’m not going to crank the motor at all when weather is cold.
Re: Mercedes coolant mixed [Re: Rohan] #5271009 11/18/19 04:36 PM
R
Rohan Offline OP
R
I was also thinking of purchasing AMSOIL low toxic coolant (white bottle) with amsoil dominator coolant boost. Worth it?
