Fed ex
by Chris142 - 12/15/19 05:53 PM
65 registered members (alarmguy, Astro_Guy, askani79705, 750IX, AZjeff, 2015_PSD, 4 invisible),
1,003
guests, and 20
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,857
Posts5,142,701
Members70,138
Most Online3,589 Nov 2nd, 2019
2012 Grand Caravan: Coolant thoughts and questions
#5266972
11/14/19 11:10 AM
Caydel
OP
OP
Posts: 2 |
Hi all. I have a 2012 Grand Caravan that I bought new.
This week, it started throwing a P0128, and I confirmed that the coolant temp isn't getting about maybe 160 degrees, so I'll need to change the thermostat, and this will require me to add some extra coolant.
I know it would have come with a factory HOAT fill. However, back in 2016-ish, I got upsold on a radiator flush at the local Mr Lube. At the time, I had no idea that there was a model year break in the coolant used, so I assumed it was refilled with HOAT.
However, now I'm not so sure anymore. The coolant in the overflow jug is very clean and bright orange - like a melted orange popsicle orange. I want to believe that it's a proper HOAT fill, but I would expect that to be yellow if it's coming aftermarket. I read somewhere that aftermarket Dexcool fills are often also Orange, which makes the think the kid who did the flush was as clueless as I at the time, and filled it with Dexcool.
So, my million dollar questions are such:
1. Is there a definitive way I can tell what kind of coolant is in there? 2. Is it common for Dexcool to be orange in an aftermarket fill?
Unfortunately, the paperwork that reflects that coolant flush disappeared when I moved a few years back.
I'd rather not pay for a full rad flush right now, but I need a solution, and I'd appreciate any thoughts!
2012 Dodge Grand Caravan 2007 Hyundai Elantra 1983 Mercedes 500SEC 1988 Ford F250 (7.3 IDI)
Re: 2012 Grand Caravan: Coolant thoughts and questions
[Re: Caydel]
#5267005
11/14/19 11:37 AM
sloinker
Posts: 1,072 |
Orange is the wrong color for Mopar fills of that vintage which run from pink to purple. You could do a complete drain followed with a couple flushes and the correct coolant from the dealer along with your repair.
'16 Tiguan TSI Ravenol VST 5W40 '15 VW Golf TDI Ravenol VMP 5W30 '15 VW Golf Sportwagen TDI VMP 5W30 '14 Dodge Grand Caravan 3.6 Red Line Blue Label 5W20 '64 Plymouth Fury440 Red Line Blue Label 10W40
[Re: sloinker]
#5267018
11/14/19 11:51 AM
Caydel
OP
OP
Posts: 2 |
Orange is the wrong color for Mopar fills of that vintage which run from pink to purple. You could do a complete drain followed with a couple flushes and the correct coolant from the dealer along with your repair. Actually, the factory HOAT fill is supposed to be orange. I just don't know what the aftermarket fill is... PEAK's orange coolant is their Dexcool-compatible OAT, as is Prestone's. As are a few other generics that I looked at are also orange. I'm starting to think that the refill is definitely Dexcool - the person doing the flush probably saw the orange factory HOAT fill, and refilled with what they knew as orange (generic Dexcool).
[Re: Caydel]
#5267025
11/14/19 12:00 PM
Sayjac
Posts: 14,010 |
Chrysler/Mopar G-05 HOAT did come as an Orange-ish tint AF from the factory. The dealer part for subsequent use was/is more red-ish in tint. Unfortunately there's no way using color alone to know what's in there now. DexCool does have a "similar" tint to Mopar G-05, so you're going to have to decide how comfortable you are with not being certain. One of the best Mopar AF color posts is in the link. Scroll to Ivoryring post #47 to see pics of Mopar HOAT tint (left side). https://www.wranglerforum.com/f274/2013-coolant-is-orange-pink-should-be-purple-297057-2.html
[Re: Caydel]
#5267082
11/14/19 12:45 PM
JC1
Posts: 4,130 |
My 2015 Caravan is pink in color (it's never been changed).
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter 1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
[Re: Caydel]
#5267291
11/14/19 04:04 PM
sloinker
Posts: 1,072 |
Every OE coolant from 2012 to present in 3.6L pentastar engines I have personally seen, and I have seen a bunch, has been pink to purple in shade. The replacement from the dealer is also pink to purple in shade. Perhaps prior to the Pentastar with the 3.3/3,8 there was an orange antifreeze but it seems in my recollection they were also pink. I'm guessing that if it is orange than it has been contaminated or isn't Mopar OE coolant. While the cited Mopar color choices are interesting and does show an orange in the mix, I would be extremely wary and do the flush and add the Purple OE coolant as specified for that vehicle and eliminate the possibility of plugging the system with sludge.
[Re: Caydel]
#5267351
11/14/19 05:09 PM
doitmyself
Posts: 7,170 |
All of the literature suggests that the new pink/purple coolant was introduced in the 2013 model year: http://www.wk2jeeps.com/tsb/tsb_wk2_0700412a.pdfDepending on production date, his 2012 may or may not be considered a 2013.
[Re: Caydel]
#5267379
11/14/19 05:31 PM
spk2000
Posts: 1,522 |
Be careful on that engine to bleed the air out of coolant. If there is air still in it then you can overheat and ruin it.
96 Grand Marquis 203,000 mi 01 Sable LS Wagon 163,000 mi 02 Montero 191,000 mi 03 Sable LS Sedan 73,000 mi
[Re: Caydel]
#5267506
11/14/19 07:31 PM
92saturnsl2
Posts: 1,993 |
All the Chrysler vehicles I've had in that era had ORANGE coolant which was G05 HOAT. All aftermarket Dexcool coolants I've ever used have also been orange. So short of expensive chemical analysis, I think you have a mystery on your hands.
How long have you been driving it with the questionable coolant? If there's no issues, I'd just schedule the next coolant service interval a bit early and keep a watchful eye on it. If you want extra piece of mind, coolant is cheap-- just do a thorough flush and put the correct G05 coolant in it.
Most people just grab a bottle of coolant off the shelf and put it in whatever they have in there already-- I'm certain that aftermarket Dexcool has been mixed with likely every possible coolant chemistry on the planet by now, and I don't hear of many horror stories resulting from it. I don't think anything awful is going to happen by leaving it in there, but personally it would bother me to have potentially mixed-up fluid.
96 Grand Prix SE (project car) 04 Odyssey EX 200k Philips Shield Choice 10w-30 96 Maxima GLE 275k Shell Rotella T5 10w-30 07 Chrysler Pacifica Limited 4.0L 145k Mobil1 EP 0w-20
