Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Went shopping
by MrQuackers - 12/15/19 12:31 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Electric boiler seems expensive to run
by ram_man - 12/14/19 01:42 PM
01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Moving To Phoenix, Suggestions?
by knerml - 12/14/19 12:57 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
37 registered members (carlprop, Alex_Cocco, bdcardinal, clinebarger, Bert_c, Bailes1992, 5 invisible), 864 guests, and 19 spiders.
Topics298,818
Posts5,141,856
Members70,129
Most Online3,589
Nov 2nd, 2019
TDS review #5266630 11/14/19 03:30 AM
E
Espada Offline OP
E
Hello i wanna know if the TDS of the oil i am using is good for my 98 Mitsubishi lancer
Re: TDS review [Re: Espada] #5266633 11/14/19 03:53 AM
P
pitzel Online Content
Online Content
P
20W-50 itself wouldn't be a problem in Egypt.
Only meeting API SJ means that it would be considered a fairly old product by global standards.
Not sure what engine your Mitsubishi Lancer has, as there are number of engines that have been sold in that car globally. Most posters here would likely prefer a full synthetic motor oil for a low-displacement 4-cylinder engine. If it has a turbocharger, then synthetic lubricants are pretty much considered mandatory.
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: TDS review [Re: pitzel] #5266635 11/14/19 04:02 AM
E
Espada Offline OP
E
Nah it has no turbo, its a pretty standard 1.3 motor don't know the exact type but its a 4 cylinders 1.3, and 20w50 is fine but is the tds good for a motor oil or should i look for something else
Re: TDS review [Re: Espada] #5266729 11/14/19 07:37 AM
Quattro Pete Offline
If it truly meets ACEA A3/B4, then I'd consider it pretty decent.
2002 530i   2015 Q5 3.0T   2018 Charger SRT
Re: TDS review [Re: Espada] #5267006 11/14/19 11:38 AM
O
OilUzer Offline
O
KV100 = 71 shocked2
Is that a typical range for 20W50? Thickies must love that!
Don't recall seeing KV100 that high with any of the bitog oils but I guess not many may run 20W50 here.
Also flash & pour points are shocked2
On the surface, looks too thick! What is the recommendation in the owner's manual?
Re: TDS review [Re: Espada] #5267742 11/15/19 02:40 AM
B
berniedd Offline
B
The numbers in the IP and ASTM columns are, I believe, identifiers of the test methods used, not the figures the test results came up with. Here is a product description of a Mag1 20W-50 oil:
https://mag1.com/products/passenger...oil/mag-1-conventional-20w-50-motor-oil/
In your hot climate, a 1998 engine will do OK with 20W-50 oil. A 15W-40 will do well also. I used both in the past in my 1998 Honda CRV.
