Makes me nervous to put in additives when "the experts" say things like: "Additives are combined into well-balanced, optimized packages allowing lubricants to meet specified performance criteria in a finished fluid."
https://www.stle.org/images/pdf/STL...unction%20of%20Lubricant%20Additives.pdf
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5262512/a-review-of-engine-oil-additives
You could use a Jaguar-LandRover approved 0w20, which also carries the highest performance 0w20 spec there is on planet earth, seriously, the VW 508 tests, the same my '19 Tiguan gets:
https://www.mobil.com/en-US/Passenger-Vehicle-Lube/pds/GL-XX-Mobil-1-ESP-x2-0W20
A little hard to find. When I need it later I'll probably have to order it from SunCoastParts.com unless somebody starts to carry it.
