Jingle Bells...
by GumbyJarvis - 12/12/19 02:38 PM
Meguiar's M305
by sohccammer427 - 12/12/19 02:29 PM
Will it fit?
by Bettez88 - 12/12/19 12:58 PM
Diagnosis Confirmatioin
by Gebo - 12/12/19 12:58 PM
Mercury 25hp PCMO
by SimpleGuy48 - 12/12/19 12:50 PM
IIHS Pushing for Better Headlights
by SubLGT - 12/12/19 11:58 AM
My favorite flight ever
by Astro14 - 12/12/19 11:31 AM
Does anybody else have reactions to MSG?
by Chris142 - 12/12/19 10:35 AM
injecter cleaner?
by ernied - 12/12/19 09:27 AM
Which would you use for 5k
by Bettez88 - 12/12/19 09:08 AM
Effective ways to reduce humidity inside the car
by MoneyJohn - 12/12/19 08:21 AM
Stupid regulations- Diesel Cap Color
by Rmay635703 - 12/12/19 08:20 AM
Help a not-so-noob: shear stability theory.
by OilStasher - 12/12/19 08:03 AM
Latest oil purchase for Lawnmowers
by Snagglefoot - 12/12/19 07:44 AM
Old school bra
by whizbyu - 12/12/19 07:10 AM
Tricky flight ticket change fees
by Superflan - 12/12/19 07:10 AM
2019 Jeep Rubicon F&R Axle UOAs [5,000 Miles]
by 2015_PSD - 12/12/19 06:58 AM
kalima, Powertool1994, lutvi20, Bazik, Lamasuna
70113 Registered Users
96 registered members (4WD, 53' Stude, 77GrandPrix, alchargo, 8 invisible), 1,949 guests, and 21 spiders.
Topics298,632
Posts5,139,575
Members70,113
Most Online3,589
Nov 2nd, 2019
Toyota 1MZ-FE burning lots of oil #5266566 11/13/19 11:27 PM
Speedinsweede Offline OP
A family member has got a 2002 Toyota highlander with the 3.0 V6. When I saw it last I noticed it was low on oil, like real low, not even on the dipstick. At this point she was about 6 months and 4000km into her last oil change. She religiously follows the oil change sticker, and was about to get one anyways, so I offered to do it for her. I drained just over a liter of oil out of her pan, the car takes about 5. What could be causing such high consumption?
The car has 250k km. Doesn't really smoke. Looks very dry from underneath and is not leaking. I checked the pcv valve and it seems to be operating properly. She has receipts from the previous owner, so I know that the engine was well maintained. Oil changes were done on time, and all but three were done at a Toyota dealership (including the one I did). The dealer has never told her that they barely got any oil out of it. I know this engine has a history of sludging, but given the service history, I imagine that wouldn't be a problem. However, isn't unlikely if the engine is running on small quantities of oil.
Anybody familiar with the engine have any recommendations on what we should do? Would It be a good idea to start running a high mileage synthetic?
I put in some Motomaster 5w30, in case anyone is wondering.
Re: Toyota 1MZ-FE burning lots of oil [Re: Speedinsweede] #5266580 11/13/19 11:58 PM
clinebarger Offline
We're going to assume the oil was actually changed 3000 miles ago & full? Change the oil & monitor consumption.
2001 Chevy Camaro L92/4L80E
Re: Toyota 1MZ-FE burning lots of oil [Re: clinebarger] #5266586 11/14/19 12:11 AM
The local dealer is pretty large operation and has one of the express drive through oil changes. I do believe they change it, if anything they may have under filled. I'd like to give them the benefit of the doubt. I did change the oil and will be monitoring the situation, but assuming the worst.
Re: Toyota 1MZ-FE burning lots of oil [Re: Speedinsweede] #5266596 11/14/19 12:43 AM
Ded Mazai Offline
Stuck/worn piston rings. I doubt you can do anything about it. Oils or oil system flushes are useless in this case.
Re: Toyota 1MZ-FE burning lots of oil [Re: Ded Mazai] #5266606 11/14/19 01:06 AM
slacktide_bitog Offline
The 1MZ is one of those engines where a 3k OCI on synthetic is a good idea, anyway crzy
Does the car leak any oil? Valve cover gaskets can go bad over time, and they are impossible to replace in the 1MZ, and you can't see anything under the oil cap because they put a baffle there mad
If that is the case, an Italian tuneup might work drive ontome
Re: Toyota 1MZ-FE burning lots of oil [Re: Speedinsweede] #5266680 11/14/19 06:34 AM
danez_yoda Offline
How about a piston soak with Kreen or Berymans B12 to maybe loosen the piston ring crud. Do this right before an oil change.
Some toyota engines on the mid 2000s had anew piston design that was prone to piston slap and eventually burning oil.
The supposing part was no oil light when it was that low. My niece has a Sion that was burning so much oil that the oil light would come on at about 1500 miles. She didn't know any better and just brought it into the dealership. They "changed" her oil (4qts of dino) and aired up the tires for $40 and sent her on her way. That's when I taught her to buy some cheap oil (super tech or Chevron) and keep in the trunk. Every fillup check the oil and add a little bit if it is low.
She got scared when she went the actual 5000 miles on the OCI and the maintenance required light came on because she never saw it before. smile She was always seeing the oil can light thinking it was telling her it needed an oil change when it was really just low.
Re: Toyota 1MZ-FE burning lots of oil [Re: Speedinsweede] #5266699 11/14/19 07:11 AM
R
Rolla07 Offline
R
Id change the PCV valve out anyways. Its under 10$. But id highly suspect a bigger issue as others have mentionned. Id give it some HM oil and a new PCV and check on it in 1000km.
Show her how to check and add oil...seems to be a lost art.
2007 Corolla Red Pearl 155k miles
PP 0w20 & ST 4967
2015 Toyota Venza Parisian Blue Pearl 25k miles
TGMO 0W20 & OEM filter
Re: Toyota 1MZ-FE burning lots of oil [Re: Speedinsweede] #5266816 11/14/19 09:01 AM
supton Offline
Those 3.0's were oil drinkers. I believe low tension rings and/or undersized oil drain holes (which get clogged up if run on long OCI with conventional). I'd check the oil more often and just keep topping off.
Show her how to do it on a cold engine, like every Saturday or Sunday morning. Just pull the dipstick and check. Pretty easy to add oil! Do check the manual, i'm not sure if the bottom of range is a quart or not (but just dumping in a quart when it shows low is probably just fine, a bit over won't hurt anything).
2011 Toyota Camry, base, 2.5L/6MT, 196k, hers
2010 Toyota Tundra DC, 4.6L/6AT, 155k, ours
1999 Toyota Camry LE, 2.2L/4AT, 217k, his
Re: Toyota 1MZ-FE burning lots of oil [Re: Speedinsweede] #5267691 11/14/19 11:05 PM
clinebarger Offline
The 1MZ-FE engines I've been around never used much oil, Now they will definitely start leaking it! Cam seals & Valve Cover Gaskets being pretty common.
The drain back cavities are huge. Even the heavily sludged ones seem to drain quite well. I don't believe the MZ used low tension rings or had ring pack issues?
The Valve Covers can get clogged up (between the baffle & cover).....Around 2002-2003 is when the covers were redesigned, The easiest way to tell you have the update is the Screw-in PCV valve.
