My 7 mile commute to work in the morning consists of basically 35mph for the entire drive, and these past couple of weeks up in Michigan have been pretty cold. I'm finding that my car doesn't really get up to operating temp until the last mile or so of my commute, and the cabin doesn't really get comfortably warm until I'm pulling into the parking lot. I don't believe it's a thermostat issue, the coolant gets about 3/4 of the way to operating temp after a few miles, and then it seems like the thermostat opens and all of the cold coolant in the radiator over cools the engine and it takes the rest of the trip to get to operating temp.
When I used to drive 55 miles one way to work and my car sat in a garage all night, this was never a problem.
So I made a cover for the intake on the bottom of the bumper cover to block a lot of the airflow into the radiator. I left 1" open on each side for a little airflow. The top two grills appear to be non-functional. I tested it out this morning when it was 10 degrees out and the car reach operating temp after about 4-5 miles, which is an improvement especially considering that this was the coldest morning so far. I then drove around town for 30 minutes after work in 20 degree weather and the coolant temps looked fine.
So, bad idea or completely fine? I'm keeping some side cutters in the car just in case it warms up and I need to take it off.
