I picked up a 2013 Polaris Ranger 500 EFI recently. I will be plowing with it this winter and would like to add a LED light bar in the front and either a smaller one in the rear or pod/flood lights.
My question is: is there a wattage limit I need to be concerned about when looking at the cheap Amazon light bars? I just want to be sure I will not be causing any overloading issues to the battery or electrical system.
Per the manual:
Alternator Max Output
350 watts @ 3000 RPM
Battery / Model / Amp Hr
Yuasa Conventional 14 Amp Hr. / 12 Volt
Per the manual:
