RA code
by Koncrete_Cam - 05/26/20 12:12 PM
best alternative to a group 79? hopefully more cca
by apollo18 - 05/26/20 11:25 AM
Gas Prices Are Going Up
by BlueOvalFitter - 05/26/20 10:49 AM
One way to "fix" a loud vehicle exhaust
by ZZman - 05/26/20 10:01 AM
Limited slip rear end in Tacoma
by taintedtattoo - 05/26/20 09:45 AM
Best Ball Joint and Pitman Arm Grease?
by 2015_PSD - 05/26/20 09:31 AM
12 volt air compressor
by John_Conrad - 05/26/20 08:42 AM
Battery Charging Compatibility
by cb450sc - 05/26/20 07:11 AM
Techron With GDI Engines Intake Vale Cleaning ?
by ChrisD46 - 05/26/20 06:58 AM
Current produced by 3 AA batteries
by MoneyJohn - 05/26/20 06:21 AM
I need advice on Toyota V6 timing belt
by michaelluscher - 05/26/20 06:13 AM
Ignition Wire Suggestions?
by GemStater - 05/26/20 02:22 AM
Calling Prius Owners
by rrretiree7 - 05/26/20 02:12 AM
Environmentally friendly gas can rant
by IMSA_Racing_Fan - 05/26/20 12:58 AM
Left Hand Drillbits
by Snagglefoot - 05/25/20 10:32 PM
Turtle Wax Ice Spray Wax use tips.
by JimPghPA - 05/25/20 08:53 PM
Best oil on the market?
by sloinker - 05/25/20 08:47 PM
Xfinity Race in Charlotte
by kstanf150 - 05/25/20 08:12 PM
Purolator PBL14610 C&P
by FordBroncoVWJeta - 05/25/20 08:00 PM
JDXer, Ivan30, mikespine, Typerguy, showtyme1958
71530 Registered Users
92 registered members (apollo18, Aredeeem, 53' Stude, 123GO, 2015_PSD, 11 invisible), 2,538 guests, and 25 spiders.
Topics305,898
Posts5,282,347
Members71,530
Page 1 of 3 1 2 3
*NEW* DELO 600 ADF #5264523 11/11/19 08:48 PM
SavagePatch Offline OP
Re: *NEW* DELO 600 ADF [Re: SavagePatch] #5264532 11/11/19 08:56 PM
B
BillyE Offline
B
I think the predominant thought is that this oil was probably not suitable for everyone and was probably designed with some next gen engine in mind.
Re: *NEW* DELO 600 ADF [Re: SavagePatch] #5264564 11/11/19 09:42 PM
J
John_Conrad Offline
J
if u need it for your application, use, change it on time and move on.
its not rocket science any oil that meets what you need will work.
do u have a specific question?
Safety doesn't happen by accident.--author unknown
Re: *NEW* DELO 600 ADF [Re: SavagePatch] #5264578 11/11/19 10:00 PM
RDY4WAR Offline
I feel like they may be using Molyvan 855 in a pretty high concentration to make up the anti-wear. I can't wait to see how it does in Sequence IVA. That'll be the real test.
"He who is without oil, shall throw the first rod." - Compressions 9:1
Re: *NEW* DELO 600 ADF [Re: SavagePatch] #5264594 11/11/19 10:18 PM
J
JHZR2 Offline
Global Moderator
Global Moderator
J
OP, you mean this:
https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/5262966/1
Have to wonder how this would work in deposit-prone DI engines too.
Re: *NEW* DELO 600 ADF [Re: JHZR2] #5264607 11/11/19 10:37 PM
Originally Posted by JHZR2
OP, you mean this:
Yes, thank you! Doh! Sorry, I was looking in the HDEO forum. Please feel free to delete this thread.
Re: *NEW* DELO 600 ADF [Re: SavagePatch] #5264667 11/12/19 12:54 AM
SteveG4 Offline
It's a new CK-4 rated diesel engine oil...
Given its radically different chemistry, I wonder how it is going to be measured against other HDEOs up to this point? Anyone care to comment?
Should be interesting!
Somewhere between Alaska and Wisconsin...
2006 4WD Silverado LT Crew Cab & 2013 AWD Equinox
Re: *NEW* DELO 600 ADF [Re: SteveG4] #5264829 11/12/19 09:35 AM
K
krismoriah72 Offline
K
When CK-4 first came out everyone hoarded up CJ4 because of the lower ZDDP...and the fear that engine wear would increase. Now there is an oil with no zddp..
So it begins again.
Re: *NEW* DELO 600 ADF [Re: SavagePatch] #5265017 11/12/19 01:50 PM
L
loneryder Offline
L
They are reducing SA .6% to reduce DPF clogging. Is that a problem and how widespread is it??? I don't hear about it from the trucking industry. They used a lot of CJ oil with DPF's. Like to hear from those in the trucking industry.
Re: *NEW* DELO 600 ADF [Re: krismoriah72] #5265483 11/12/19 09:13 PM
SteveG4 Offline
So it begins again.
Cannot argue that!
Most of us fear change. Though it appears that Chevron has been working on this new oil for several (many) years.
I'm sure NDA's were signed early on, and that engine and truck mfgrs haven't been left out of the loop.
We'll find out soon enough I suppose.
Re: *NEW* DELO 600 ADF [Re: loneryder] #5265570 11/12/19 10:43 PM
T
tundraotto Offline
T
DPF systems are not anymore a 'problem', but they are a high expense....
to have them, cost of parts, engineering etc.
to maintain them, DPF regen cycles (more fuel burned, lost power, nevermind the idiocy of burning more fuel to burn off the residue of burned fuel)
breakdowns from them and their systems
Anything that can minimize DPF regens etc should be a welcome development.....whether this is it....we'll see i guess.
Re: *NEW* DELO 600 ADF [Re: SavagePatch] #5265671 11/13/19 03:43 AM
B
BillyE Offline
B
This has nothing to do with regens.
Re: *NEW* DELO 600 ADF [Re: BillyE] #5265701 11/13/19 06:58 AM
dnewton3 Offline
Global Moderator
Global Moderator
Actually, it does, per this article where Chevron reps made specific indications regarding regens and DPFs
https://www.trucknews.com/transportation/chevron-unveils-a-lubricants-game-changer/1003095061/
If this lube product, along with things like FBCs (fuel borne catalysts) aimed at reducing PM (particulate matter) from the combustion process, all work towards lowering the ash and soot content in the exhaust stream, they could induce a significant improvement in reduced regen cycles. That in turn has implications such as greater fuel savings, and also the potential to make the DPF smaller (lighter and less costly) for any given expectation of performance and lifespan.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters.
- under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan
- over maintaining something has never been proven to be anything but a waste of time and money
Re: *NEW* DELO 600 ADF [Re: SavagePatch] #5266068 11/13/19 02:07 PM
P
PiperOne Offline
P
Anything to help with DPF lifespan and operational improvements is very welcome news. I wonder if the current Delo CK-4 oils were a bit of a test bed given the lower metallic additive levels they have. Either way, it appears Chevron has figured out something new to provide what diesel engines need without traditional chemistry. Will be watching closely for fleet test results when they happen.
HDEO in Diesel Engines. No spark plugs here.
Re: *NEW* DELO 600 ADF [Re: loneryder] #5266079 11/13/19 02:14 PM
P
PiperOne Offline
P
Full on clogging isn't widespread, but excessive active re-gens that waste fuel are a problem for most, and these can be a restricted DPF and usually get blamed on something else operator based (excessive idling etc) to prevent any kind of warranty claim. Not having to remove the DPF for a mid life clean and bake (which Chevron claims may not be needed) is a cost saving as well.
Page 1 of 3 1 2 3
