Software fix for blown headgasket?
by CaptainHazelwood - 01/25/20 02:01 PM
EB Oil Drain Plug
by BlueOvalFitter - 01/25/20 01:59 PM
Grease for Blend Door Actuator
by TheLawnRanger - 01/25/20 01:05 PM
waterpump fan clutch and thermostat now overheating
by HyundaiAbuser - 01/25/20 12:43 PM
2020 Ford F250 w/Tremor package and 7.3 L
by tenderloin - 01/25/20 12:34 PM
Genesis GV80 SUV
by tenderloin - 01/25/20 12:33 PM
What kind of mixed drink do you like?
by 53' Stude - 01/25/20 12:11 PM
F150s with the 6.2L
by ford46guy - 01/25/20 12:09 PM
Generator - Gas or Not
by coopns - 01/25/20 11:18 AM
Oil Recommendations For Leaks?
by shurguywutt - 01/25/20 10:59 AM
'12 Odyssey EX-L trans filter
by shortlid - 01/25/20 10:57 AM
06 Explorer v8
by ford46guy - 01/25/20 10:31 AM
Heard this today ­čĄú
by JLTD - 01/25/20 10:18 AM
Has anyone tinted a dash cluster?
by Vern_in_IL - 01/25/20 08:40 AM
Coolant flush machines
by Donald - 01/25/20 08:24 AM
How do you scratch the new car itch?
by supton - 01/25/20 08:07 AM
2019 f550 6.7
by ame299 - 01/25/20 07:49 AM
unthinkable problem after oil change
by NH73 - 01/25/20 07:37 AM
M635_Guy, ame299, Whoop, coondog, steelbeams
70523 Registered Users
87 registered members (53' Stude, ARCOgraphite, 2EHA, 97prizm, 928, 15 invisible), 3,310 guests, and 20 spiders.
Topics300,542
Posts5,178,032
Members70,523
Is Wss-m2c921-a spec not produced anymore? #5263195 11/10/19 09:47 AM
U
Umit Offline OP
U
Hi
This is Range rove 3.6tdv8 spec on manual.
But i cant find any oil in this spec.
Is it overdue?
Re: Is Wss-m2c921-a spec not produced anymore? [Re: Umit] #5263381 11/10/19 02:09 PM
Danno Offline
https://prodepc.blob.core.windows.net/epcblobstorage/GPCDOC_GTDS_Shell_Rimula_R3_FX_10W-30_(en)_TDS_v1.pdf
Try to find this oil.
2019 Jeep Grand Cherokee Summit 5.7L Hemi
2019 RAV4 Limited Hybrid
2016 Sorento SX V6 AWD
2010 Mazda 3 2.0L
Re: Is Wss-m2c921-a spec not produced anymore? [Re: Umit] #5263479 11/10/19 04:42 PM
dave1251 Offline
It's still an active specification for use in high sulphur diesels if I recall correctly. The last time I checked Turkey doesn't sell high sulfur diesel so you should be ok using the correct grade or thicker HDEO.
don't use.
Re: Is Wss-m2c921-a spec not produced anymore? [Re: Umit] #5263687 11/10/19 09:35 PM
E
earlyre Offline
E
looking up that model in the castrol uk (and Turkish)sites, it basically recommends a 5w30 A5 oil..
well.. for the TDV8 3.6...5w30 A5
for the TDV8 3.6 DPF, 5w30 C1...
so it looks like, 5w30... and a C1 oil if you have a DPF(Diesel Particulate Filter) system, an A5 if you Don't....
that's my say anyway...
Mine:
13 Ford C-MAX hybrid: Havoline syn 5w20,& Napa Gold 1348
Re: Is Wss-m2c921-a spec not produced anymore? [Re: Danno] #5264793 11/12/19 07:38 AM
U
Umit Offline OP
U
Yes but manual recommends 5w30.
Found rimula 5w30 but in 20lt packages...
Re: Is Wss-m2c921-a spec not produced anymore? [Re: dave1251] #5264795 11/12/19 07:39 AM
U
Umit Offline OP
U
Yes exactly low sulphur here checked again.
Re: Is Wss-m2c921-a spec not produced anymore? [Re: dave1251] #5264796 11/12/19 07:39 AM
U
Umit Offline OP
U
Yes low sulphur here.Thanks
Re: Is Wss-m2c921-a spec not produced anymore? [Re: earlyre] #5264799 11/12/19 07:45 AM
U
Umit Offline OP
U
Yes non dpf and a5 then...
Re: Is Wss-m2c921-a spec not produced anymore? [Re: Umit] #5264821 11/12/19 08:24 AM
U
Umit Offline OP
U
Another point is the manual suggests semi synthetic.
Is there an advantage of semi or is it for low service intervals?
Re: Is Wss-m2c921-a spec not produced anymore? [Re: Umit] #5265693 11/13/19 05:28 AM
W
weasley Offline
W
The 921-A sec is essentially a heavy duty engine oil spec, requiring ACEA E5 and API CH-4 - intended for use with fuel sulphur >3,000 ppm. It is specifically a 10W-30 spec, so you can't have a 5W-30 921-A oil. It has a HTHS minimum of 3.5cP so strictly C1 and A5/B5 are too thin, but oil recommendations often change over time as fuel and duty cycles change (and experience in the market).
What oil does a local JLR dealer recommend?
2017 SEAT Leon 1.4 EcoTSI 150 FR Technology DSG
2018 Volvo XC60 D4
2011 KTM 990 SMT
Re: Is Wss-m2c921-a spec not produced anymore? [Re: weasley] #5265698 11/13/19 05:40 AM
U
Umit Offline OP
U
[Linked Image]
Actally recommends non existing oil i gues:)
Re: Is Wss-m2c921-a spec not produced anymore? [Re: Umit] #5265723 11/13/19 06:51 AM
W
weasley Offline
W
Very odd! Current recommendations do appear to centre on A5/B5 5W-30 though
2018 Volvo XC60 D4
2011 KTM 990 SMT
Re: Is Wss-m2c921-a spec not produced anymore? [Re: weasley] #5265787 11/13/19 08:21 AM
dave1251 Offline
You are off the spec is a 5W30.
don't use.
Re: Is Wss-m2c921-a spec not produced anymore? [Re: Umit] #5265794 11/13/19 08:27 AM
W
weasley Offline
W
Not according to the Ford specification document I am looking at, entitled:
Quote
OIL, ENGINE, DEVELOPING MARKET, INITIAL AND SERVICE FILL, SAE 10W-30 API CH-4, ACEA E5-99
2018 Volvo XC60 D4
2011 KTM 990 SMT
Re: Is Wss-m2c921-a spec not produced anymore? [Re: weasley] #5266627 11/14/19 03:22 AM
U
Umit Offline OP
U
Quote
Interesting,all RR Tdv8 s use 5w30 as i know from RR forums...
I guess manual is wrong about spec.
