Alignment questions: is camber/caster not usually touched?
by FordBroncoVWJeta - 01/26/20 10:47 PM
Pricing used tires
by PumpPusher - 01/26/20 10:21 PM
STP Motor Oil at HF
by kstanf150 - 01/26/20 10:07 PM
9 years for the 4 cylinder Eco-boost
by Snagglefoot - 01/26/20 09:39 PM
So I picked this up..
by Mad_Hatter - 01/26/20 08:49 PM
New here and question about oil.
by Sunstealth - 01/26/20 08:42 PM
Looking for a car for $4k or less
by SVTCobra - 01/26/20 08:09 PM
I'm looking for a 2017 Camry LE in Pgh. PA area
by JimPghPA - 01/26/20 07:59 PM
just bought a lift!
by agarb - 01/26/20 07:54 PM
09 Mercury Grand Marqyus fix or dump?
by John_K - 01/26/20 07:14 PM
Any Castrol Edge EP Users ?
by ChrisD46 - 01/26/20 07:06 PM
Good inexpensive smart charger?
by dvancleve - 01/26/20 06:12 PM
top fuel flames.
by red7404 - 01/26/20 05:24 PM
What say you?
by Mad_Hatter - 01/26/20 05:18 PM
2006 Cadillac CTS: worth looking into or run away?
by 53' Stude - 01/26/20 04:07 PM
2012 Elantra battery running at 11.7 volts
by schuylkill - 01/26/20 03:31 PM
Chevron Supreme no longer at Costco
by OilUzer - 01/26/20 03:18 PM
tampasaint, rdmjone, BigGeo, apham8, Sunstealth
70535 Registered Users
34 registered members (2009Caraman, ArrestMeRedZ, Ag76, bbhero, asiancivicmaniac, 4 invisible), 1,652 guests, and 16 spiders.
Topics300,617
Posts5,179,392
Members70,535
Gifted a 2007 Impala #5265626 11/12/19 11:02 PM
1
14Accent Offline OP
1
Well, I've been handed another basket case. This time, it's a family heirloom!
My parents purchased this particular car in the spring of 2008 as a CPO with something like 23k miles on it. My mother drove it for the next 9 years or so, and my aunt has been driving it until now. I'm the only one who's serviced the car it's whole life up until my aunt got it, she took it to a small, reputable shop.
Well, I've got a bit of a project on my hands. It's currently sitting at 180k miles, and it needs some love. The rear brakes were metal on metal when I got it, that's been handled with some cheap rotors and semi-metallics. The front rotors pulsate, both outer tie rods are shot, and the right front bearing is humming. The transmission is definitely showing it's age, however once you get moving it feels fine. I'm going to do a suck and fill with Trans Tune, run a couple hundred miles, then do another suck and fill. It'll either kill it or refresh it, either way I'm not too worried about it. It's got a vibration at idle in gear, I'm pretty sure the oil pan leak has finally taken out the motor mount on that side. Again, oh well.
Aside from that, everything seems to be in order. The CEL is on, I haven't scanned it yet. I plan on doing that tomorrow when I throw the winter wheels on it. I want to get that figured out, as the remote start doesn't work if there are errors in the PCM.
Other than that, it's a... well it's a 2007 Impala LT. It's about what you would expect, all things considered. I find it incredible that the W-body has been around as long as it has and still just works. Talk about solid, if not boring, transportation.
2013 Chevrolet Volt - Saves enough in fuel to pay for itself!
2007 Chevrolet Impala LT
Re: Gifted a 2007 Impala [Re: 14Accent] #5265639 11/12/19 11:39 PM
daves87rs Offline
They do make great beater cars...friend;s son just got a 2009 as his first car.....
2020 Chevrolet Trax LS
2019 Chevrolet Equinox LS
2006 Chevrolet Cobalt LS
2004 Chevrolet Cavalier
Too much GM.. ;-)
Re: Gifted a 2007 Impala [Re: 14Accent] #5265641 11/12/19 11:42 PM
P
pitzel Offline
P
Yeah I still drive a 28-year-old W-body. Other than just being a terribly old car, and a little bit of rocker rust, its proven to be very reliable and economical to operate. Definitely get those codes. Probably something trivial like an oxygen sensor or spark plugs on a vehicle that age. Or plugged up IAC passages, especially if it was serviced frequently with dino oils.
The factory engine mount on my W-body spent 20+ years soaking in an oil drip, and it was still good when I had it apart a few years ago to replace the oil pan gasket. So I wouldn't assume that the factory mount went bad just because of the oil exposure.
Change your thinking...not your oil!
Turn your mind....not your rotors!
Re: Gifted a 2007 Impala [Re: pitzel] #5265663 11/13/19 01:21 AM
1
14Accent Offline OP
1
I'll see what I come up with tomorrow. I've fought EVAP vent valve codes on this car before, so I'm half expecting it to be that.
Surprisingly enough, the car has never had dino. It got full synthetic 5w30 from 22k-130k or thereabouts and has since run a steady died of HM 5w30. 4-5k oil changes, almost religiously. My mother is not one to let a vehicle be destroyed. The funny thing is, I've done almost nothing to keep the thing on the road over the years. I used the snot out of the CPO warranty at the beginning (several wheel bearings, 2 steering racks, and a few other nit-pick things) but otherwise all it's gotten it tires and oil changes.
Come to think of it, it's still got it's original plugs and coolant. I should probably add those to the list. That being said, it's still on the original radiator, water pump, alternator, and it's only recently had the original belt replaced. It's almost shocking how many original parts are still on this thing.
Re: Gifted a 2007 Impala [Re: 14Accent] #5265676 11/13/19 03:19 AM
Snagglefoot Offline
Same observation on my 2008 Burb except I changed the coolant at 5 years. Gotta love that Dexcool! It probably came with AC Delco Iridiums. Mine came out at 180,000 miles still looking fully functional.
“She’s got a Cop engine, a cop suspension and cop brakes” LOL
If you want the job done right......do it yourself.
Re: Gifted a 2007 Impala [Re: 14Accent] #5265679 11/13/19 03:30 AM
MrQuackers Offline
Master the 1000 yard stare
coffeeMobil 1 USA
Re: Gifted a 2007 Impala [Re: 14Accent] #5265720 11/13/19 06:37 AM
Donald Offline
What is the rust situation? The sprays like CarWell and FF and Krown will not fix rust but they pretty much stop it in its place.
2015 Ford F-250 w/Powerstroke
Re: Gifted a 2007 Impala [Re: 14Accent] #5265753 11/13/19 07:47 AM
Drosselmier Offline
What is a CPO car? I've seen it mentioned several times on this forum.
Re: Gifted a 2007 Impala [Re: Drosselmier] #5265756 11/13/19 07:49 AM
P
paoester Offline
P
"certified pre-owned" car. Means they inspect it to death, and only take decent used cars, and probably have a warranty of some kind on it.
Re: Gifted a 2007 Impala [Re: Donald] #5265814 11/13/19 08:55 AM
1
14Accent Offline OP
1
It's actually not bad at all. The pinch welds are getting a little crusty, but other than that it's "clean". The hood is a little crunched from a hit and run years ago, the left rear tail light is busted, and there's scratches all over but overall it's fine for what it is.
Re: Gifted a 2007 Impala [Re: 14Accent] #5265834 11/13/19 09:33 AM
P
panthermike Offline
P
Nice, wife had a '10 Impala for awhile. Minimal repairs, very boring indeed but easy at the same time. Niece is driving it now, and seems to like it!
'17 Armada Platinum; RGT 0w20, 52K
'19 Ram 1500; RGT 5w20, 15K
'70 F100; Valvoline 15w40
Biotech For All
Re: Gifted a 2007 Impala [Re: 14Accent] #5265914 11/13/19 10:56 AM
A
atikovi Offline
A
The Camry of American cars. A bit bland but fairly trouble free and reliable.
Re: Gifted a 2007 Impala [Re: 14Accent] #5266175 11/13/19 03:17 PM
A
ad244 Offline
A
Post up some pics, I wanna see this vehicle
Re: Gifted a 2007 Impala [Re: 14Accent] #5266337 11/13/19 06:39 PM
2
2010Civic Offline
2
Mother in law has a base model 2008 impala. It works but is such a lame excuse for a car.
2010 Honda Civic LX
Valvoline SynPower 5w-20 - Napa Gold oil filter
59,992 miles
Re: Gifted a 2007 Impala [Re: ad244] #5266386 11/13/19 07:21 PM
1
14Accent Offline OP
1
I know! I'm slacking on the pictures. I'll try and remember to get some tomorrow, there really isn't much to see. It's a dark maroon Impala, just like all the other rental specials.
I did throw the snow's on it today, I have to say it looks pretty cool on steelies. Unfortunately the factory 9C1 center caps won't fit these aftermarket wheels, but it still looks neat.
