Any recommendations on best steps for tuning carburetor ?
Found several excellent videos on valve adjustment and had no trouble performing same on this powerhead.
Did find generic Stihl Carburetor Adjustment.
In pictures below, see H, L and LA (Idle)
Online directions are like this:
How to Adjust the Carburetor on a Stihl Weed Eater
Turn the high-speed screw, marked 'H' counterclockwise until it stops.
Tighten the 'L' screw all the way, then turn it one turn counterclockwise to open it.
Start up the engine and allow it to warm up. The cutting tool will rotate. ...
Press the trigger of the machine to rev the engine. Adjust the 'H' screw until the engine does not cut out or sputter.
Heh .... someone just emailed this... a good one
