Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Went shopping
by MrQuackers - 12/15/19 12:31 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Electric boiler seems expensive to run
by ram_man - 12/14/19 01:42 PM
01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Moving To Phoenix, Suggestions?
by knerml - 12/14/19 12:57 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
36 registered members (carlprop, Alex_Cocco, bdcardinal, clinebarger, Bert_c, Bailes1992, 5 invisible), 880 guests, and 19 spiders.
Topics298,818
Posts5,141,856
Members70,129
Most Online3,589
Nov 2nd, 2019
Stihl KM110R Carburetor Adjustment #5265040 11/12/19 01:10 PM
H
henni Offline OP
H
Any recommendations on best steps for tuning carburetor ?
Found several excellent videos on valve adjustment and had no trouble performing same on this powerhead.
Did find generic Stihl Carburetor Adjustment.
In pictures below, see H, L and LA (Idle)
Online directions are like this:
How to Adjust the Carburetor on a Stihl Weed Eater
Turn the high-speed screw, marked 'H' counterclockwise until it stops.
Tighten the 'L' screw all the way, then turn it one turn counterclockwise to open it.
Start up the engine and allow it to warm up. The cutting tool will rotate. ...
Press the trigger of the machine to rev the engine. Adjust the 'H' screw until the engine does not cut out or sputter.
Heh .... someone just emailed this... a good one
Re: Stihl KM110R Carburetor Adjustment [Re: henni] #5265080 11/12/19 01:37 PM
K
Kamele0N Offline
K
And where do you have a problem? smile
2008 Toyota Yaris 1ND-TV 1.4 D4-D Tech9 5W30 C3 VW 504/507
1997 Toyota Landcruiser KZJ95 3.0 TD Elf Evolution NF900 5W40
Re: Stihl KM110R Carburetor Adjustment [Re: henni] #5265097 11/12/19 01:53 PM
H
henni Offline OP
H
Surprised the video had trimmer head attached but carburetor fully exposed (no cover, no filter).
Re: Stihl KM110R Carburetor Adjustment [Re: henni] #5265145 11/12/19 02:46 PM
M
mk378 Offline
M
I hope that Old Milwaukee is paying him.
Always tune with the string head installed and strings out at normal cutting length. The air filter doesn't make much difference unless it is clogged. You always want to be running a little on the rich side anyway.
Re: Stihl KM110R Carburetor Adjustment [Re: henni] #5265407 11/12/19 07:05 PM
doitmyself Offline
Quote
The OP instructions don't make sense. Here's the owner's manual version: https://www.stihlusa.com/webcontent.../stihl_km-110-130_instruction-manual.pdf ... see page 20.
Initial adjustment before tweaking:
"- Carefully turn both adjusting screws counterclockwise as far as stop:
- The high speed screw (H) is 3/4 turn open.
-The low speed screw (L) is 3/4 turn open.
- Start and warm up the engine.
-Adjust idle speed with the idle speed screw (LA) so that the cutting attachment does not move.
Think of it this way: The L screw (needle) adjusts the fuel/air mixture at idle and early/low throttle engagement. As the throttle opens more, the H screw (needle) takes over and adjusts the fuel/air mix for wide open throttle. If you have poor acceleration/sputter when pulling the throttle quickly at idle, you adjust the L screw (not the H in the OP). The LA screw adjusts the idle speed. When you adjust the H or L screws, you may need to tweek the LA screw and vice versa.
On chainsaws you adjust the H screw open (rich) until the engine starts to "flutter" under no load. Under load that flutter will settle into smooth, high power cutting. I'm not sure about tweaking a weed trimmer H screw beyond the stated 3/4 -1 turn out from closed.
