Grease plus Gear Oil
by PumpPusher - 12/15/19 12:59 AM
Costco/Kirkland 5qt-2pack synthetic $29.99
by wgtoys - 12/14/19 10:31 PM
Mercedes delays EV release
by JeffKeryk - 12/14/19 09:33 PM
Retired. Dreams are of work...
by rekit - 12/14/19 08:19 PM
Silly to charge a brand new battery?
by jayjr1105 - 12/14/19 08:06 PM
Help me pick a tire for our Volvo
by Ddub - 12/14/19 07:10 PM
Porter Cable 12V Batteries
by bcossa2001 - 12/14/19 06:52 PM
LG Red and Bio EP at Amazon
by demarpaint - 12/14/19 06:51 PM
2-stroke oil choices
by dnewton3 - 12/14/19 05:29 PM
Do cats like potato chips?
by atikovi - 12/14/19 03:45 PM
Buying a cheap, beater bicycle
by Oldtom - 12/14/19 03:14 PM
Metabo/Hitachi Impact driver $50
by Deere John - 12/14/19 03:03 PM
Ate up camshaft.pics
by Chris142 - 12/14/19 02:57 PM
Caprice cam swap. :)
by ls1mike - 12/14/19 02:55 PM
Electric boiler seems expensive to run
by ram_man - 12/14/19 01:42 PM
01 Crown Vic Bucking/Stumbling Uphill
by Gasbuggy - 12/14/19 01:20 PM
Where and how do you sleep?
by 53' Stude - 12/14/19 01:01 PM
Headlight Condensation
by rrretiree7 - 12/14/19 12:59 PM
Moving To Phoenix, Suggestions?
by knerml - 12/14/19 12:57 PM
Subaru Forester with rusty brakes
by Donald - 12/14/19 12:55 PM
Maik, Pluckster, DerekPho, mikinko, merrittgene
70129 Registered Users
33 registered members (adams355, berlinbai, 928, BlakeB, bbhero, 3 invisible), 739 guests, and 16 spiders.
Topics298,818
Posts5,141,862
Members70,129
Most Online3,589
Nov 2nd, 2019
Mix and match wheel cylinder brands? #5265012 11/12/19 12:45 PM
R
RocketUSA Offline OP
R
Long story short, I'm replacing the wheel cylinders on rear drums, and I ordered two Wagner wheel cylinders. I received one, but the second one is on back order until January. That's not going to work with my schedule. I'd like to get this job done on Saturday, which is 4 days from now. Do I need to stick with the same brand on each side? The specs say same bore size, for what it's worth.
I could get another Wagner brand here in 9 days ($20). I could get parts-store brand now ($20) or get a Raybestos or Beck Arnley from Amazon for $15-16 in a couple of days. Your thoughts appreciated.
Re: Mix and match wheel cylinder brands? [Re: RocketUSA] #5265025 11/12/19 12:57 PM
W
WondrousBread Offline
W
In my opinion, no.
Unless someone else can think of something I'm missing, they should perform exactly the same if they're the same size.
Re: Mix and match wheel cylinder brands? [Re: RocketUSA] #5265028 11/12/19 12:59 PM
J
JC1 Offline
J
I would think it wouldn't be an issue, but I've never replaced wheel cylinders.
What vehicle is this on? Are they leaking or are you just doing preventative maintenance?
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Mix and match wheel cylinder brands? [Re: RocketUSA] #5265057 11/12/19 01:23 PM
N
nthach Offline
N
I don't think it's an issue, unlike disc brakes where both calipers should be replaced to maintain brake balance.
I wouldn't be surprised if the same Chinese wheel cylinder was supplied under different boxes.
Re: Mix and match wheel cylinder brands? [Re: RocketUSA] #5265067 11/12/19 01:29 PM
A
atikovi Offline
A
It's only an issue if you have OCD.
Re: Mix and match wheel cylinder brands? [Re: RocketUSA] #5265071 11/12/19 01:32 PM
Chris142 Offline
I don't think different brands will matter at all. It's the springs that control how fast the shoes retract and the line pressure how fast they expand.
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Mix and match wheel cylinder brands? [Re: atikovi] #5265085 11/12/19 01:40 PM
Scuder Offline
I'd want the piston size to be the same, at least if it's not an anti-lock system. On slick surfaces, or in a panic stop, a piston larger than the other could cause that wheel to lock up, reducing braking on that wheel to zero.
Measure the one you have, and see if the parts store one matches, or is at least close. If it's 1/4" or more different, I'd pass.
Re: Mix and match wheel cylinder brands? [Re: RocketUSA] #5265106 11/12/19 02:08 PM
A
alchargo Offline
A
I went through this same situation a few months ago when I was replacing the original factory rear wheel cylinders on a 1989 Pontiac Bonneville. I got a little overzealous with the bleeder on one of the Wagner replacements and had to settle for a Dorman parts store replacement. It was a slightly different shape than the Wagner but same piston size. I've had no issues
Re: Mix and match wheel cylinder brands? [Re: RocketUSA] #5265113 11/12/19 02:14 PM
J
john_pifer Offline
J
I did it recently on my Tacoma when I tore the boot of the OEM wheel cyl. on the right side while taking the drum off (it was my first time removing and replacing drum brakes and components, so I didn’t know what I was doing).
I replaced it with an Auto Zone unit. No issues in the few months since.
07 Tacoma V6 - M1 EP 5W-30, Fram Ultra, 10K OCIs, 223K
18 Civic HB 1.5T 6MT (Fiancee's) - Castrol Edge 0W-20, OEM filter
07 Yamaha R1 - Rotella T6 5W-40, Bosch 3300
07 Yamaha YZ-250, Klotz, Rotella
Re: Mix and match wheel cylinder brands? [Re: RocketUSA] #5265215 11/12/19 04:11 PM
R
ragtoplvr Online Content
Online Content
R
for what it is worth,
I have replaced one rotor. I have replaced a leaking caliper with a loaded caliper after cleaning the rotor, and did not touch the other side. I have even reversed symmetrical pads to equalize wear. Never had a problem with pulling, confused the abs or any problem. Never even really noticed a difference. I do not race my car, I just drive it.
Rod
Re: Mix and match wheel cylinder brands? [Re: atikovi] #5265294 11/12/19 05:17 PM
R
R
So you're telling me it's gonna be an issue....*sigh*
Otherwise, thank you for the feedback! I'm going to go with with mixed brands. Replacing them on a 1999 Toyota Sienna. I'm doing the wheel cylinders as part of the process of replacing the rear brakes due to my personal experience. Long ago, I changed just the shoes (different car), and the cylinders failed a few days later, nullifying my work. I read that as the bores are pushed back into their original positions, any corrosion that took place while the bore was exposed could score the seals. So in my mind, not worth the risk.
Re: Mix and match wheel cylinder brands? [Re: RocketUSA] #5265316 11/12/19 05:43 PM
A
atikovi Offline
A
Not going to be an issue but some people have anxiety over stuff like that. Not having the same brand of tires on their car, not having the same color refrigerator and oven in their kitchen, not having the same socks on their feet.
Re: Mix and match wheel cylinder brands? [Re: RocketUSA] #5265386 11/12/19 06:55 PM
slacktide_bitog Offline
They probably all come from the same Chinese factory anyway ontome
Re: Mix and match wheel cylinder brands? [Re: RocketUSA] #5265703 11/13/19 06:04 AM
another Todd Offline
As long as the internal bore is the same diameter there is no issue at all with different brands.
2015 Ford F250 Diesel Crew Cab FX4
2017 Ford Escape 2.0
2002 GMC Yukon
2015 Hyundai Accent
2008 Yamaha Rhino 700 FI
