keeping a water well from freezing in the south
by danez_yoda - 12/16/19 06:39 AM
Altimax RT43 snow review
by Skippy722 - 12/16/19 04:59 AM
New TV Audio Question
by Toros - 12/16/19 01:25 AM
is on car rotor cutting the best method?
by WhyMe - 12/16/19 12:37 AM
Found a Good deal!!!
by GuinnessGuy - 12/15/19 11:28 PM
Serpentine Belt Change
by Propflux01 - 12/15/19 08:59 PM
QS HM 10W-40
by kstanf150 - 12/15/19 08:29 PM
4.5" Angle Grinder
by TheLawnRanger - 12/15/19 07:51 PM
Cooper CS5 Ultra Touring
by Warstud - 12/15/19 07:39 PM
Highway power loss
by HyundaiAbuser - 12/15/19 07:21 PM
General truck tires
by spasm3 - 12/15/19 07:18 PM
Alternative uses for CVT fluid?
by stroo - 12/15/19 05:57 PM
CANbus mileage editor
by cwilliamsws6 - 12/15/19 05:56 PM
Fed ex
by Chris142 - 12/15/19 05:53 PM
New oil treatment from Colgin
by qball16 - 12/15/19 05:36 PM
Discount Tire Direct $80 Flash Sale
by BePrepared - 12/15/19 05:16 PM
Bleed and refill?
by cwilliamsws6 - 12/15/19 04:19 PM
bjonga, theman5142, 750IX, Tzam, tjl5709
70138 Registered Users
72 registered members (adams355, 69Torino, 2002 Maxima SE, aquariuscsm, AndyB, alarmguy, 6 invisible), 1,230 guests, and 23 spiders.
Topics298,858
Posts5,142,746
Members70,138
Most Online3,589
Nov 2nd, 2019
Lug bolts failing #5264963 11/12/19 11:43 AM
N
Ndx Offline OP
N
Hi Guys,
I was putting winter on and 95% of lug bolts have cracks in collar or are failing.
Always torqued down to 118ft lb
I will replace my torque wrench and order some lug bolts, OE
[Linked Image from i.ibb.co] [Linked Image from i.ibb.co] [Linked Image from i.ibb.co] [Linked Image from i.ibb.co] [Linked Image from i.ibb.co]
Re: Lug bolts failing [Re: Ndx] #5264965 11/12/19 11:46 AM
J
jeepman3071 Online Content
Online Content
J
What car are these on? Are they OEM bolts?
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (53k) - Castrol Edge Euro 0w40, MANN HU816X
Re: Lug bolts failing [Re: Ndx] #5264976 11/12/19 12:00 PM
J
JC1 Offline
J
How old are they? Look like they were hammered on with a impact gun a few times too many.
Doesn't surprise me. My OEM Caravan lugs deformed a bit after 3 years. Went and bought a cheap set of lugs from Costco. Quality isn't there for some of these parts. If you wanted quality I'm sure a good set of lug nuts would probably be more than $50 a set.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Lug bolts failing [Re: Ndx] #5265003 11/12/19 12:33 PM
G
Gimpy1 Offline
G
Go out and spend the &&& for quality aftermarket or OE lugs. Anything safety related in a vehicle, is not a place to skimp on quality. You may save a few bucks with junk parts, but what happens when the lug fails, or strips a stud, are the $3 bucks you saved really worth it? Look up Gorilla the make quality products, just make sure you are using the right lug nut for your rims. Why are you buying a new torque wrench instead of getting it calibrated?
Re: Lug bolts failing [Re: Ndx] #5265007 11/12/19 12:38 PM
N
Ndx Offline OP
N
Those are OE! Made probably in Germany
Never torqued down with impact myself , always torqued by hand ..but now thinking I had some swaps done by tire shops, I'm sure they abused them
I will replace them with same OE from dealer.
, I trust OE quality, I posted this because it was interesting.
Not sending for calibration, because I want to replace clicker with Split Beam
And FYI guys that anodized colar is aluminum... Weak link
Re: Lug bolts failing [Re: Ndx] #5265134 11/12/19 02:31 PM
Donald Online Content
Online Content
I have seen the tire shops pound on impact sockets with a BFH. They were probably rusty but still. They make some special .5mm larger sockets for chrome plated lug nuts that rust under the chrome.
If they were heated they could have lost temper.
2015 Ford F250 w/Powerstroke
Re: Lug bolts failing [Re: Donald] #5265151 11/12/19 02:54 PM
B
bullwinkle Offline
B
I would be pretty shocked if they heated them with a torch, there's a hundred ways that could go south, but lug nuts/bolts seem to be a wear item any more, they're too critical to take a chance on them failing.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 18 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(XG2)
Re: Lug bolts failing [Re: Ndx] #5265156 11/12/19 03:01 PM
J
JOD Offline
J
With a an aluminum seat, I don't think there's anyone to "blame" here, it's just a function of the design. Those are designed to be replaced.
Re: Lug bolts failing [Re: JOD] #5265157 11/12/19 03:02 PM
N
Ndx Offline OP
N
Exactly !
Re: Lug bolts failing [Re: Ndx] #5265224 11/12/19 04:18 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Is there any chance rust grew on the inside of the collar?
Re: Lug bolts failing [Re: Ndx] #5265257 11/12/19 04:40 PM
G
GSCJR Offline
G
I noticed that today on a Panamera while doing a winter wheel install. Torque spec on those was 133ft/lbs.
07 3.5L VQ35DE NAPA FS 5w-30 ProSelect 21358 150KM
10 3.5L 2GR-FE NAPA FS 5w-20 ProSelect 27047 175KM
Re: Lug bolts failing [Re: GSCJR] #5265279 11/12/19 05:03 PM
N
Ndx Offline OP
N
Hi Kestas I mean maybe inside inside but not visible on mating surfaces, I'm in rust belt so it's always possible
Yup this is Porsche as well.... Tomorrow I will have new 20 nuts from dealer, I will eliminate security ones as it's annoying...
OE nuts are actually pretty cheap... Less then 5$ each
Re: Lug bolts failing [Re: GSCJR] #5265323 11/12/19 05:52 PM
E
edwardh1 Offline
E
is that a lot?
whats toyota spec for same weight car?
These products are all new every year?? They are a revolution!!! Razor blades, mens shirts, TVs, wiper blades, gutter guards, hearing aids... according to the ads. But also all new last year
Re: Lug bolts failing [Re: Ndx] #5265360 11/12/19 06:35 PM
J
JimPghPA Offline
J
A couple of years ago I noticed one bad lug-nut when changing from summer to winter set of tires. The next day I went up to local NAPA and had them order replacements for all the lug-nuts on all 4 wheels, and replaced all of them as soon as they came in.
Boy will I be happy when ALL vehicles on public roads are autonomous.
JimPghPa
Re: Lug bolts failing [Re: JC1] #5265362 11/12/19 06:38 PM
slacktide_bitog Offline
is that a lot?
Most Toyotas spec 75-80 lb ft for their lug nuts smile
This is why I HATE most tire shops, why I usually get tires from Walmart despite the 4-hr wait time, and why I wish DT would open some stores in the northeast: because they seem to be the ONLY places that don't zip it down with an air gun and strip lug nuts/studs/bolts mad
