Old rationing video
by 53' Stude - 01/21/20 03:32 PM
Are the plastic battery trays necessary?
by littlehulkster - 01/21/20 03:18 PM
Amsoil ATV/UTV Powertrain Fluid
by IowaFord - 01/21/20 02:13 PM
Motorcraft FL500s 3,630 miles.
by mpgo4th - 01/21/20 01:36 PM
Xcel Class Action Suit
by John_K - 01/21/20 12:33 PM
RV Freightliner Cummins ISB 6.7 oil question
by 1978elcamino - 01/21/20 11:48 AM
Why I became a pilot and not a doctor...
by jetman - 01/21/20 10:52 AM
Wrong oil or not ?
by M119 - 01/21/20 10:48 AM
30 monograde
by mpack88 - 01/21/20 10:15 AM
Extended life destroys copper?
by mpack88 - 01/21/20 09:49 AM
Project Farm Lucas transmission additive video
by 1978elcamino - 01/21/20 09:43 AM
1.8t 0w40, plus a situation.
by WMNN1988 - 01/21/20 09:25 AM
Mobil 1™ ESP X2 0W-20 US Availability
by TheIceStormof06 - 01/21/20 08:46 AM
Wire harness/connector
by Redright9 - 01/21/20 07:58 AM
Will You Jump Someone Else's Car?
by Gebo - 01/21/20 07:08 AM
NAPA Edge $20 A/R
by dblshock - 01/21/20 04:54 AM
8 Utes on test.
by Silk - 01/21/20 03:03 AM
Magnetic Socket Rails
by The Critic - 01/21/20 01:19 AM
IowaFord, Origami99, reylafo, PastPresMike, RedBeard83
70497 Registered Users
124 registered members (53' Stude, 2015_PSD, 90crvtec, 72te27, 10 invisible), 2,417 guests, and 36 spiders.
Topics300,399
Posts5,174,944
Members70,497
Garage door lack of signal/reception issue #5264443 11/11/19 06:05 PM
dja4260 Online Content OP
OP Online Content
I just installed a RYOBI 2hp garage door opener in my detached all metal workshop.
I love the opener and have an awesome 30ft extension cord attachment. With that said, my outside key pad doesn't work and I need to be 5 feet away from the door for an opener (clicker) to work....
Do I have any options to increase the range of this unit? I didn't think signal would be this poor......
2013 Hyundai Elantra Gt Hatch 6 spd
2005 Toyota Highlander V6
1997 HD Sportster
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264445 11/11/19 06:09 PM
Skippy722 Online Happy
Online Happy
Are there any LED’s near the key pad or garage door opener? I had a wonky led that was giving off interference if it was on.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264448 11/11/19 06:11 PM
K
KevGuy Offline
K
After spending a few summers while in school helping repair or install garage door openers, the only opener I would go with is Chamberlain.
Do not fear the orange can.
Re: Garage door lack of signal/reception issue [Re: KevGuy] #5264451 11/11/19 06:14 PM
R
redbone3 Offline
R
I had a similar problem. I poked a hole in the ceiling of the garage and pushed a pice of really stiff steel wire through the hole. I attached the wire with a screw to the ceiling and attached the antenna wire to it. Works great now. (Problem is trying to get a signal through a metal garage door, this puts the antenna above the metal).
2014 Passat Wolfsburg, 1995 Miata.
Re: Garage door lack of signal/reception issue [Re: redbone3] #5264461 11/11/19 06:30 PM
spasm3 Online Happy
Online Happy
So you basically made the whole building the antenna!
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Garage door lack of signal/reception issue [Re: Skippy722] #5264477 11/11/19 07:01 PM
OP Online Content
I have 6, 4 ft LED shop lights directly overhead.....
1997 HD Sportster
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264536 11/11/19 08:00 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Are they on when you're having signal problems?
Re: Garage door lack of signal/reception issue [Re: Kestas] #5264563 11/11/19 08:41 PM
OP Online Content
No, signal is basically nonexistent with the lights off as well.
1997 HD Sportster
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264613 11/11/19 09:51 PM
Donald Offline
How about when the door is open and you wan to close it? With remote outside but door open? Is that any better?
2015 Ford F-250 w/Powerstroke
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264689 11/12/19 12:55 AM
sxg6 Offline
Reading through some reviews online it looks like Ryobi might be able to send you a larger antenna if you contact them, worth a try.
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264698 11/12/19 01:36 AM
B
billt460 Offline
B
How about any CFL's? I put a CFL in my opener light socket, and the remote quit working. The manual pad worked fine.
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264739 11/12/19 05:56 AM
F
Fawteen Offline
F
Sounds like the opener is in vacation mode (disables the outdoor keypad and the remotes).
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264803 11/12/19 07:49 AM
M
MasterSolenoid Offline
M
I would read over the Owners Manual again looking for solutions.
Try some of the suggestions others have listed here.
Then, call Ryobi's Customer Service.
2002 Ford Ranger / bought new
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264809 11/12/19 07:58 AM
6
64bawagon Offline
6
As crazy as it sounds I had an HD TV antenna with a booster in my barn that would mess with the opener. I moved it to the back of the barn.
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: Garage door lack of signal/reception issue [Re: 64bawagon] #5264847 11/12/19 08:58 AM
M
M
I had a 'dimmer' Light Switch in Dining Room that would interfere with (over-air signal) TV in Living Room.
2 Wheel Drive
3.0 Liter Engine
