55 registered members (adams355, alchargo, A_User55555, bdcardinal, 2strokeNorthstar, 2 invisible),
1,180
guests, and 29
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,666
Posts5,140,033
Members70,115
Most Online3,589 Nov 2nd, 2019
Need Spring Compressor OTC 6494?
#5264688
11/12/19 12:48 AM
Wolf359
OP
OP
Posts: 7,605 |
Need a spring compressor for my Mercedes, no quick struts so I need to buy the OEM springs. Don't really trust those hook compressors, the OTC is a little pricey though a tad under $200. Any other suggestions?
This is for a 2008/2011 E350.
Re: Need Spring Compressor OTC 6494?
[Re: Wolf359]
#5264716
11/12/19 03:47 AM
The Critic
Posts: 21,364 |
For a while, pep boys would do the spring swap for $20/strut. See if that service is still available.
2011 Toyota Prius 1.8L - 200K - Valvoline Premium Blue Restore 10W-30 2007 Honda Accord 2.4L - 142K - Valvoline Premium Blue Restore 10W-30
[Re: Wolf359]
#5264743
11/12/19 06:05 AM
EricG
Posts: 216 |
11 F150 4x4 5.0 11 Cadillac SRX 03 Century l
[Re: Wolf359]
#5264752
11/12/19 06:33 AM
Imp4
Posts: 1,304 |
2001 Mitsubishi Galant 2.4 - 165k+ Grandma's creampuff...
[Re: The Critic]
#5264790
11/12/19 07:33 AM
Lubener
Posts: 3,449 |
For a while, pep boys would do the spring swap for $20/strut. See if that service is still available. Do the parts stores offer the compressor on loan?
The "thinking" man's friend.
[Re: Wolf359]
#5264905
11/12/19 10:31 AM
joegreen
Posts: 1,215 |
Im not sure your spring setup but mercedes has this special spring compressor tool.
https://www.amazon.com/EWK-Compressor-Mercedes-Macpherson-Compression/dp/B00H99582U/ref=sr_1_5?crid=VNKOJWQ5I8R2&keywords=mercedes+spring+compressor&qid=1573575989&sprefix=mercedes+spring%2Caps%2C138&sr=8-5
1978 Chevrolet k20 Engine: Delo 10w30xle Transmission: Castrol transmax dex/merc
1984 Mercedes-Benz 300 turbo diesel Engine: Delo 400 15w40le
[Re: Wolf359]
#5264980
11/12/19 12:03 PM
spavel6
Posts: 360 |
Autozone, Oreilly's and AAP all have compressors for rent. Esentially making them free..
The quality of these rental tools are actually quite good - better than the cheaper stuff you can buy online.
The Mercedes springs are significantly compressed, so be careful!
2003 VW Jetta Wagon TDI 198k M1 5W40 TDT 2001 VW GTI VR6 250k T6 5W40 2001 VW Passat Wagon V6 4motion 110k PP 5W30
[Re: joegreen]
#5264983
11/12/19 12:07 PM
atikovi
Posts: 3,284 |
https://www.amazon.com/EWK-Compressor-Mercedes-Macpherson-Compression/dp/B00H99582U/ref=sr_1_5?crid=VNKOJWQ5I8R2&keywords=mercedes+spring+compressor&qid=1573575989&sprefix=mercedes+spring%2Caps%2C138&sr=8-5 Or https://www.ebay.com/itm/5-Spring-C...47675&_trksid=p2047675.c100005.m1851 But doesn't say it works on the 211 and 212 series he has.
[Re: atikovi]
#5265373
11/12/19 06:44 PM
Wolf359
OP
OP
Posts: 7,605 |
https://www.amazon.com/EWK-Compressor-Mercedes-Macpherson-Compression/dp/B00H99582U/ref=sr_1_5?crid=VNKOJWQ5I8R2&keywords=mercedes+spring+compressor&qid=1573575989&sprefix=mercedes+spring%2Caps%2C138&sr=8-5 Or https://www.ebay.com/itm/5-Spring-C...-Telescopic-Repair-Tool-Kit/382764544149 But doesn't say it works on the 211 and 212 series he has. Yes, that's the problem. I've also seen them for the W210 which was the older model of the W211. Even the strut/spring is different between the W211 and W212 so I don't want to guess. The problem with the parts stores is that they usually just have the hook style compressors which can be dangerous if they let go. Don't want to take it someplace because that means driving to a place a waiting for it to be done. No quick struts and there's a few other parts there in addition to the spring and strut like the bumper stop, dust cover and a couple other little parts which would add over $100 to the cost of each strut so I can't just buy all the parts in advance and build my own quick strut.
[Re: atikovi]
#5265458
11/12/19 07:44 PM
Wolf359
OP
OP
Posts: 7,605 |
[Re: Wolf359]
#5265517
11/12/19 08:46 PM
atikovi
Posts: 3,284 |
[Re: Wolf359]
#5265807
11/13/19 08:47 AM
bmwpowere36m3
Posts: 822 |
The specialty compressor is for older MBs that had inboard springs and does not work for macpherson struts, which I suspect is what's up front on the E350. For macpherson struts, the compressor styles are (in order of price): Threaded Rod: ![[Linked Image from shop.harborfreight.com]](https://shop.harborfreight.com/media/catalog/product/cache/1/image/9df78eab33525d08d6e5fb8d27136e95/i/m/image_26663.jpg) Clamshell (what we use in the shop): ![[Linked Image from toolsource.com]](https://www.toolsource.com/images/prod_images/OTC6494_1200Wx1200H.jpg) Fixtured: ![[Linked Image from images-na.ssl-images-amazon.com]](https://images-na.ssl-images-amazon.com/images/I/71LmFhHL7SL._SY879_.jpg)
[Re: Wolf359]
#5265810
11/13/19 08:49 AM
JHZR2
Global Moderator
Global Moderator
Posts: 43,392 |
I’m not sure about your model, but typically Mercedes springs are quite long and much more dangerous to compress than the spring on a strut or smaller springs on lighter cars. At least on older Mercedes, the only appropriate way was to use a plate style compressor with an internal shaft. Klann makes the correct one, and they can sometimes be found at low cost from ex-Chrysler techs.
Using an incorrect or insufficient compressor can have major safety ramifications.
At some point they moved to macpherson struts and then a broader range of compressors can be used.
