Oil for my 65 mustang.
by old1 - 01/25/20 04:12 PM
Carburetor Tuning with Wide Band O2 Sensor
by Oldswagon - 01/25/20 03:16 PM
Software fix for blown headgasket?
by CaptainHazelwood - 01/25/20 02:01 PM
EB Oil Drain Plug
by BlueOvalFitter - 01/25/20 01:59 PM
Grease for Blend Door Actuator
by TheLawnRanger - 01/25/20 01:05 PM
waterpump fan clutch and thermostat now overheating
by HyundaiAbuser - 01/25/20 12:43 PM
2020 Ford F250 w/Tremor package and 7.3 L
by tenderloin - 01/25/20 12:34 PM
Genesis GV80 SUV
by tenderloin - 01/25/20 12:33 PM
What kind of mixed drink do you like?
by 53' Stude - 01/25/20 12:11 PM
F150s with the 6.2L
by ford46guy - 01/25/20 12:09 PM
Generator - Gas or Not
by coopns - 01/25/20 11:18 AM
Oil Recommendations For Leaks?
by shurguywutt - 01/25/20 10:59 AM
'12 Odyssey EX-L trans filter
by shortlid - 01/25/20 10:57 AM
06 Explorer v8
by ford46guy - 01/25/20 10:31 AM
Heard this today 🤣
by JLTD - 01/25/20 10:18 AM
Has anyone tinted a dash cluster?
by Vern_in_IL - 01/25/20 08:40 AM
Coolant flush machines
by Donald - 01/25/20 08:24 AM
How do you scratch the new car itch?
by supton - 01/25/20 08:07 AM
M635_Guy, ame299, Whoop, coondog, steelbeams
70523 Registered Users
100 registered members (2EHA, atikovi, 99CentDinoMan, 55hambone, A_User55555, 2002 Maxima SE, 10 invisible), 3,029 guests, and 21 spiders.
Topics300,544
Posts5,178,102
Members70,523
How to fix exhaust broken at the flange? #5264643 11/11/19 10:53 PM
slacktide_bitog Offline OP
1996 I30 (Maxima)
The weld right after the flange on the resonator broke off and rusted. The flange from the cat and the flange from the resonator are rusted together. mad mad mad
I can't use the typical soup can method because it won't fit around the flanges. I tried Tiger Tape (an exhaust wrap), but it didn't work.
Is there anything string or wire-like I could wrap around it? Twine, some kind of wire, something like that I could use?
I don't want to spend too much money because I am dumping the car soon. A new Y-pipe and converter will cost too much, and a universal cat won't work because on this car, the oxygen sensor is mounted right after the cat, and it is an unusual size (not the typical 22mm nut and whatever large thread that is), but a smaller 14mm nut, and the sensor is only 3 wires rather than the typical four.
I grabbed this from a YT video to show you what my exhaust looks like. Right now, the green dotted line is where mine broke off. Both the flanges on one side, and the resonator and pipe are on the other side.
[Linked Image]
Re: How to fix exhaust broken at the flange? [Re: slacktide_bitog] #5264661 11/11/19 11:37 PM
rooflessVW Offline
Take it to an exhaust shop and have them weld on a new flange. Have them remove the flange entirely and weld it solid.
Could probably have it done for 50 bucks or so.
"Zed's dead baby, Zed's dead."
Re: How to fix exhaust broken at the flange? [Re: rooflessVW] #5264676 11/12/19 12:14 AM
c502cid Offline
^^^^This is the answer^^^^
16 F150 2.7 EB 4x4
15 Chev Trax AWD
02 GMC 3500 8.1/Ally DRW 4x4
00 Blazer 4.3 4x4
97/98 Civics
84 Chev K30 454EFI/T400/NP205 DRW 4x4
71 GMC Jimmy 502 RamJet/T400/NP205 4x4
08 Kawi Brute Force 750
Re: How to fix exhaust broken at the flange? [Re: rooflessVW] #5264745 11/12/19 06:24 AM
J
jeepman3071 Offline
J
+2
1998 Jeep Wrangler Sahara 4.0L/5MT (156k) - PHM 10w30, Wix 51085
2009 BMW 328i N51 (56k) - Castrol Edge Euro 0w40, MANN HU816X
Re: How to fix exhaust broken at the flange? [Re: slacktide_bitog] #5264884 11/12/19 09:59 AM
Scuder Offline
If there is enough left on the pipe, and hopefully even a little bit of the flare, you might try a split repair flange. Like it sounds, it is a two-piece flange, meant to replace a rusted or broken original. Some are a clamp style, meant to grip the pipe in the event there is no flare to hold it.
I had a flange fail at the converter, dropping the pipe on the road. It was a winter car on which I didn't want to spend a bunch replacing it cat back. Eight bucks, saved my bacon. Didn't know they existed until the knowledgeable counter man (remember them?) suggested one.
Google shows a few different types, and naturally they're more expensive now, but still a cheap alternative.
Good luck.
