Price jacked up on Chevron Supreme at WM?
by Whammo - 12/12/19 11:23 PM
valvoline durablend 5w-30 in yaris, ok?
by jstert - 12/12/19 11:02 PM
Outsmarting RA’s Shipping Lunacy
by The_Nuke - 12/12/19 11:00 PM
Odd Ball!??
by miden851 - 12/12/19 09:40 PM
fedex lost package . how does it work?
by WhyMe - 12/12/19 09:39 PM
RTG 5W-20
by kstanf150 - 12/12/19 09:12 PM
First time running synthetic in my truck
by leeaspell - 12/12/19 09:05 PM
2007 Honda Accord Transmission
by maverickfhs - 12/12/19 07:59 PM
Detriot Axle brake kit review
by 14Accent - 12/12/19 07:51 PM
PQIA Issues An Alert!
by Jackson_Slugger - 12/12/19 06:36 PM
Late night commotion outside.
by LeakySeals - 12/12/19 06:27 PM
Help with Dewalt tools
by henni - 12/12/19 06:19 PM
Educate me on USB drives, devices
by 53' Stude - 12/12/19 05:55 PM
9012 bulb lasted 2 yrs... good?
by mclasser - 12/12/19 05:43 PM
2020 YUGO
by Malo83 - 12/12/19 04:53 PM
Ice on inside of windshield
by JLawrence08648 - 12/12/19 04:41 PM
AC DELCO PF 63E CUT OPEN
by 53' Stude - 12/12/19 04:10 PM
Does old adhesive need to be removed for vinyl planking?
by JLawrence08648 - 12/12/19 04:06 PM
mb20music, Jaglenn, kalima, Powertool1994, lutvi20
70115 Registered Users
50 registered members (BusyLittleShop, boulderdentist, alcyon, Blaze, alchargo, 1WildPig, 4 invisible), 1,084 guests, and 32 spiders.
Topics298,666
Posts5,140,043
Members70,115
Most Online3,589
Nov 2nd, 2019
Air Compressor Stalling #5264575 11/11/19 08:57 PM
spasm3 Offline OP
I have a Kobalt single stage 60 gallon cast iron oil compressor. Couple of years old. I don't know if lowes even sells this model now.
It will run fine with no load. It will run fine till it hits 80psi, then it slows down until it tries to slip the belt. It should pump the tank to 150psi or so.
I don't know a lot about compressors. does this sound like something i can diagnose and repair?
Thanks.
[Linked Image from ecx.images-amazon.com]
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Air Compressor Stalling [Re: spasm3] #5264580 11/11/19 09:04 PM
Propflux01 Offline
When it slows down, does it seem like the compressor itself is slowing it down, or just the electric motor seems like it just cant handle the load?
2014 Hyundai Elantra
2014 Hyundai Elantra GT
A 55 Gallon Drum And A Shovel Can Solve A lot of Life's Little "Problems"
Re: Air Compressor Stalling [Re: spasm3] #5264583 11/11/19 09:08 PM
clinebarger Online Content
Online Content
Check the belt first.....It won't squeal like a V-belt on a vehicle. Glazing of the belt traction surface is pretty easy to spot.
2001 Chevy Camaro L92/4L80E
Re: Air Compressor Stalling [Re: spasm3] #5264603 11/11/19 09:32 PM
spasm3 Offline OP
It sounds like the electric motor is trying to turn the compressor to the point of slipping the belt. Almost like the compressor is seizing up. Its always at 80psi when it starts. The electric motor tries to keep turning the compressor until the belt squeels.
Its never been run low on oil and really has not been run that much.
Runs flawless to 80psi, but won't pump past that. The electic bogs down and it squeels right before it trips the breaker.
Re: Air Compressor Stalling [Re: spasm3] #5264626 11/11/19 10:05 PM
R
Rand Offline
R
Most likely some kind of issue with the motor. Bad bearing? bad winding/wiring etc.
Its 240v?
Re: Air Compressor Stalling [Re: Rand] #5264636 11/11/19 10:23 PM
spasm3 Offline OP
Its 240v?
Yes 240
Re: Air Compressor Stalling [Re: spasm3] #5264655 11/11/19 11:29 PM
Chris142 Offline
Have you tried tightening the belt?
87 F250 Valvoline 15w40
Z400 castrol T 10w40
Can am Maveric edge 5w40
57 case tractor Chevron sae30
Re: Air Compressor Stalling [Re: spasm3] #5264697 11/12/19 01:34 AM
CDX825 Offline
Had the same problem with a friends air compressor and it was the valves. We got a rebuild kit and for it with new valves and that solved the problem.
1984 Ford F250 6.9 Diesel C6 2WD Rotella T 15W40 NTZ Bypass Filter
1992 Mazda B2600 4x4 Amsoil Series 3000 5W30
1998 Ford Ranger 4x4 Pennzoil Platinum 5W30
Re: Air Compressor Stalling [Re: spasm3] #5264724 11/12/19 04:50 AM
demarpaint Offline
As mentioned I'd check the belt. Did it start doing this with the cold weather? I have that compressor and a small Craftsman belt driven compressor that gave me a similar problem in cold weather. Believe it or not I changed that machine over to a synthetic compressor oil and haven't had the problem since.
God Bless Our Troops
Re: Air Compressor Stalling [Re: spasm3] #5264767 11/12/19 07:02 AM
Donald Offline
Check belt. There are still places that rebuild electric motors and would probably check yours at no cost? If its the compressor itself then there maybe rebuild kits available, or a new compressor. Kobalt did not make the unit but had a company put it together with available parts.
You almost certainly have a good tank and either a good motor or compressor.
Stop by your local indy shop, ask them who services their compressor and ask that company for advice.
2015 Ford F250 w/Powerstroke
Re: Air Compressor Stalling [Re: spasm3] #5264771 11/12/19 07:03 AM
Z
zzyzzx Offline
Z
Are you sure that you have a good electrical connection? For all I know, you are only getting one leg on your 240V circuit. Unlikely, but really easy to check.
Re: Air Compressor Stalling [Re: demarpaint] #5264801 11/12/19 07:48 AM
J
JC1 Offline
J
+1 on using synthetic oil in your compressor. The past two weeks as the temperature dipped down my compressor runs slower for the first 5 minutes then by the time it warms up it's running normally. Even if Lowe's no longer sells that model, most Air compressors have the same basic design.
2015 Grand Caravan SXT Plus 0w-20 Pennzoil Ultra/Fram Ultra Filter
1997 Honda Civic CX 5w-30 PPPP/Fram Ultra Filter
Re: Air Compressor Stalling [Re: spasm3] #5264877 11/12/19 09:52 AM
F
Fitter30 Offline
F
If you remove the air fi!ter and block the intake for a few seconds this will unload the compressor and then if it starts knocking it could be a mechanical issue.
Re: Air Compressor Stalling [Re: spasm3] #5264883 11/12/19 09:59 AM
W
wag123 Offline
W
Check/Replace the motor run capacitor. This is something that will cause this kind of problem and a part that commonly fails (because most of them are low quality Chinese parts now days) .
Re: Air Compressor Stalling [Re: spasm3] #5264967 11/12/19 11:49 AM
R
ragtoplvr Offline
R
Replace motor run capacitor first if it has one. Most, but not all 150 PSI compressors are 2 stage. One big lower pressure piston and one smaller high pressure. If the high pressure one has a valve problem, then the big one is attempting to pump up to 150, and it is too big and too much work. This compressor may be reed valve, and it is not uncommon for a discharge reed valve to break. easy fix. If it is disk valve, they sometimes get some rust and seize in the bore. Either way off with the head. New gaskets are recommended.
Rod
