76 registered members (4WD, bdcardinal, Bailes1992, AZjeff, Astro14, 5 invisible),
1,368
guests, and 30
spiders. |
Key:
Admin,
Global Mod,
Mod
Topics298,664
Posts5,140,017
Members70,115
Most Online3,589 Nov 2nd, 2019
*NEW* DELO 600 ADF
#5264523
11/11/19 07:48 PM
SavagePatch
OP
OP
Posts: 790 |
Re: *NEW* DELO 600 ADF
[Re: SavagePatch]
#5264532
11/11/19 07:56 PM
BillyE
Posts: 80 |
Was it deleted? I can’t imagine why, there wasn’t any ugliness that I saw. Regardless, I think the predominant thought was that this oil was probably not suitable for everyone and was probably designed with some next gen engine in mind.
[Re: SavagePatch]
#5264564
11/11/19 08:42 PM
John_Conrad
Posts: 1,275 |
if u need it for your application, use, change it on time and move on.
its not rocket science any oil that meets what you need will work.
do u have a specific question?
Safety doesn't happen by accident.--author unknown
[Re: SavagePatch]
#5264578
11/11/19 09:00 PM
RDY4WAR
Posts: 881 |
I feel like they may be using Molyvan 855 in a pretty high concentration to make up the anti-wear. I can't wait to see how it does in Sequence IVA. That'll be the real test.
"He who is without oil, shall throw the first rod." - Compressions 9:1
[Re: JHZR2]
#5264607
11/11/19 09:37 PM
SavagePatch
OP
OP
Posts: 790 |
Yes, thank you! Doh! Sorry, I was looking in the HDEO forum. Please feel free to delete this thread.
[Re: SavagePatch]
#5264667
11/11/19 11:54 PM
SteveG4
Posts: 306 |
It's a new CK-4 rated diesel engine oil...
Given its radically different chemistry, I wonder how it is going to be measured against other HDEOs up to this point? Anyone care to comment?
Should be interesting!
Somewhere between Alaska and Wisconsin... 2006 Silverado LT Crew Cab 4WD & 2013 Equinox AWD
[Re: SteveG4]
#5264829
11/12/19 08:35 AM
krismoriah72
Posts: 2,203 |
Should be interesting! When CK-4 first came out everyone hoarded up CJ4 because of the lower ZDDP...and the fear that engine wear would increase. Now there is an oil with no zddp.. So it begins again.
[Re: SavagePatch]
#5265017
11/12/19 12:50 PM
loneryder
Posts: 862 |
They are reducing SA .6% to reduce DPF clogging. Is that a problem and how widespread is it??? I don't hear about it from the trucking industry. They used a lot of CJ oil with DPF's. Like to hear from those in the trucking industry.
[Re: krismoriah72]
#5265483
11/12/19 08:13 PM
SteveG4
Posts: 306 |
Should be interesting! When CK-4 first came out everyone hoarded up CJ4 because of the lower ZDDP...and the fear that engine wear would increase. Now there is an oil with no zddp.. So it begins again. Cannot argue that! Most of us fear change. Though it appears that Chevron has been working on this new oil for several (many) years. I'm sure NDA's were signed early on, and that engine and truck mfgrs haven't been left out of the loop. We'll find out soon enough I suppose.
[Re: loneryder]
#5265570
11/12/19 09:43 PM
tundraotto
Posts: 320 |
They are reducing SA .6% to reduce DPF clogging. Is that a problem and how widespread is it??? I don't hear about it from the trucking industry. They used a lot of CJ oil with DPF's. Like to hear from those in the trucking industry. DPF systems are not anymore a 'problem', but they are a high expense.... to have them, cost of parts, engineering etc. to maintain them, DPF regen cycles (more fuel burned, lost power, nevermind the idiocy of burning more fuel to burn off the residue of burned fuel) breakdowns from them and their systems Anything that can minimize DPF regens etc should be a welcome development.....whether this is it....we'll see i guess.
[Re: SavagePatch]
#5265671
11/13/19 02:43 AM
BillyE
Posts: 80 |
This has nothing to do with regens.
[Re: BillyE]
#5265701
11/13/19 05:58 AM
dnewton3
Global Moderator
Global Moderator
Posts: 8,286 |
This has nothing to do with regens. Actually, it does, per this article where Chevron reps made specific indications regarding regens and DPFs https://www.trucknews.com/transportation/chevron-unveils-a-lubricants-game-changer/1003095061/If this lube product, along with things like FBCs (fuel borne catalysts) aimed at reducing PM (particulate matter) from the combustion process, all work towards lowering the ash and soot content in the exhaust stream, they could induce a significant improvement in reduced regen cycles. That in turn has implications such as greater fuel savings, and also the potential to make the DPF smaller (lighter and less costly) for any given expectation of performance and lifespan.
The act of preventative maintenance, in and of itself, is FAR MORE important than brand/grade/base choices among lubes and filters. - under maintaining something is akin to abuse/neglect; that can kill equipment by shortening the lifespan - over maintaining something has never been proven to be anything but a waste of time and money
[Re: SavagePatch]
#5266068
11/13/19 01:07 PM
PiperOne
Posts: 272 |
Anything to help with DPF lifespan and operational improvements is very welcome news. I wonder if the current Delo CK-4 oils were a bit of a test bed given the lower metallic additive levels they have. Either way, it appears Chevron has figured out something new to provide what diesel engines need without traditional chemistry. Will be watching closely for fleet test results when they happen.
HDEO in Diesel Engines. No spark plugs here.
[Re: loneryder]
#5266079
11/13/19 01:14 PM
PiperOne
Posts: 272 |
They are reducing SA .6% to reduce DPF clogging. Is that a problem and how widespread is it??? I don't hear about it from the trucking industry. They used a lot of CJ oil with DPF's. Like to hear from those in the trucking industry. Full on clogging isn't widespread, but excessive active re-gens that waste fuel are a problem for most, and these can be a restricted DPF and usually get blamed on something else operator based (excessive idling etc) to prevent any kind of warranty claim. Not having to remove the DPF for a mid life clean and bake (which Chevron claims may not be needed) is a cost saving as well.
