508.00-509.00 oil for Honda K24Z3?
by allepunta - 12/08/19 01:36 AM
2020 Toyota Sequoia TRD Pro
by john_pifer - 12/08/19 01:26 AM
Liqui moly viscoplus
by Toh1 - 12/07/19 10:14 PM
Bought me a lemon 15 focus
by gabriel9766 - 12/07/19 10:12 PM
New axle fixed steering pull?
by Chris142 - 12/07/19 09:52 PM
E-core super tech vs Fram orange can 10k
by Doublehaul - 12/07/19 09:01 PM
Interesting trend at my local walmarts
by N Heat - 12/07/19 08:39 PM
Stp S2 oil filter come with silicone ADBV for $4.99
by MetalSlug - 12/07/19 07:50 PM
RATS
by MrQuackers - 12/07/19 07:46 PM
First Day of Summer in New Zealand.
by Silk - 12/07/19 07:02 PM
Gumout Regane Complete 6pk for $22.79
by volk06 - 12/07/19 06:15 PM
Basement sewer smell/Plumbers info req'd.
by irv - 12/07/19 06:03 PM
Project Farm tests car batteries
by cwilliamsws6 - 12/07/19 05:59 PM
Is this normal?
by TurboLuver - 12/07/19 05:12 PM
Any Scooter Riders?
by Passport1 - 12/07/19 03:20 PM
High Performance Lubricants
by wwillson - 12/07/19 02:27 PM
Student laptop needed.
by irv - 12/07/19 01:13 PM
4 unifi AP
by BeerCan - 12/07/19 12:25 PM
Another OCD battery ?
by Gebo - 12/07/19 11:45 AM
smlobx, bithebay87, Keelin, professor229, MxTale
70063 Registered Users
38 registered members (bbhero, adams355, Cdn17Sport6MT, carlprop, allepunta, bdcardinal, 4 invisible), 1,029 guests, and 56 spiders.
Topics298,430
Posts5,135,256
Members70,063
Most Online3,589
Nov 2nd, 2019
Garage door lack of signal/reception issue #5264443 11/11/19 06:05 PM
dja4260 Offline OP
I just installed a RYOBI 2hp garage door opener in my detached all metal workshop.
I love the opener and have an awesome 30ft extension cord attachment. With that said, my outside key pad doesn't work and I need to be 5 feet away from the door for an opener (clicker) to work....
Do I have any options to increase the range of this unit? I didn't think signal would be this poor......
2013 Hyundai Elantra Gt Hatch 6 spd
2005 Toyota Highlander V6
1997 HD Sportster
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264445 11/11/19 06:09 PM
Skippy722 Online Happy
Online Happy
Are there any LED’s near the key pad or garage door opener? I had a wonky led that was giving off interference if it was on.
2016 Chrysler 300S v6
2018 Dodge Grand Caravan GT
Slight Mopar obsession
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264448 11/11/19 06:11 PM
K
KevGuy Offline
K
After spending a few summers while in school helping repair or install garage door openers, the only opener I would go with is Chamberlain.
Do not fear the orange can.
Re: Garage door lack of signal/reception issue [Re: KevGuy] #5264451 11/11/19 06:14 PM
R
redbone3 Offline
R
I had a similar problem. I poked a hole in the ceiling of the garage and pushed a pice of really stiff steel wire through the hole. I attached the wire with a screw to the ceiling and attached the antenna wire to it. Works great now. (Problem is trying to get a signal through a metal garage door, this puts the antenna above the metal).
2014 Passat Wolfsburg, 1995 Miata.
Re: Garage door lack of signal/reception issue [Re: redbone3] #5264461 11/11/19 06:30 PM
spasm3 Offline
So you basically made the whole building the antenna!
13 elantra 81k 5w30 synpwr
17 mazda cx-5 17000 miles synpwr 5w30
Re: Garage door lack of signal/reception issue [Re: Skippy722] #5264477 11/11/19 07:01 PM
dja4260 Offline OP
I have 6, 4 ft LED shop lights directly overhead.....
1997 HD Sportster
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264536 11/11/19 08:00 PM
K
Kestas Offline
Global Moderator
Global Moderator
K
Are they on when you're having signal problems?
Re: Garage door lack of signal/reception issue [Re: Kestas] #5264563 11/11/19 08:41 PM
dja4260 Offline OP
No, signal is basically nonexistent with the lights off as well.
1997 HD Sportster
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264613 11/11/19 09:51 PM
Donald Offline
How about when the door is open and you wan to close it? With remote outside but door open? Is that any better?
2015 Ford F250 w/Powerstroke
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264689 11/12/19 12:55 AM
sxg6 Offline
Reading through some reviews online it looks like Ryobi might be able to send you a larger antenna if you contact them, worth a try.
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264698 11/12/19 01:36 AM
B
billt460 Offline
B
How about any CFL's? I put a CFL in my opener light socket, and the remote quit working. The manual pad worked fine.
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264739 11/12/19 05:56 AM
F
Fawteen Offline
F
Sounds like the opener is in vacation mode (disables the outdoor keypad and the remotes).
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264803 11/12/19 07:49 AM
M
MasterSolenoid Offline
M
I would read over the Owners Manual again looking for solutions.
Try some of the suggestions others have listed here.
Then, call Ryobi's Customer Service.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
Four basic premises of writing:
Clarity, Brevity, Simplicity, and Humanity.
Re: Garage door lack of signal/reception issue [Re: dja4260] #5264809 11/12/19 07:58 AM
6
64bawagon Offline
6
As crazy as it sounds I had an HD TV antenna with a booster in my barn that would mess with the opener. I moved it to the back of the barn.
64 Chevy wagon, 10 Jeep Wrangler, 18 Silverado 1/2 ton
Re: Garage door lack of signal/reception issue [Re: 64bawagon] #5264847 11/12/19 08:58 AM
M
M
I had a 'dimmer' Light Switch in Dining Room that would interfere with (over-air signal) TV in Living Room.
2002 Ford Ranger
2 Wheel Drive
3.0 Liter Engine
