Did Honda discontinue PSF
by iluvhonda - 12/08/19 02:44 PM
02 Silverado 5.3L LT Gas fill issue
by Gito - 12/08/19 02:30 PM
Quick Strut Advice
by coopns - 12/08/19 02:24 PM
Dq380/381 7sp wet clutch dsg
by SkodaPANDA - 12/08/19 02:18 PM
Christmas At Biltmore Estate
by gman2304 - 12/08/19 02:10 PM
K&n cabin filter
by jdw1222 - 12/08/19 01:37 PM
Max life
by Bettez88 - 12/08/19 01:20 PM
Looking for a used car under 10K
by dan_erickson - 12/08/19 01:13 PM
Intake vs Head gasket question.
by 007 - 12/08/19 12:40 PM
Wix vs Wix XP vs Amsoil oil filters
by pcowner1 - 12/08/19 10:46 AM
2011 Hyundai Sonata -- 3 cylinders dropped!!!
by BAJA_05 - 12/08/19 09:14 AM
Guidance on treating light rust on a undercarriage
by randytrish - 12/08/19 08:59 AM
Slow Dosage of Intake Cleaner in GDI Engines
by Boomer - 12/08/19 08:34 AM
carvana black friday purchase.
by JustinH - 12/08/19 08:27 AM
When to first use PEA additives?
by gfh77665 - 12/08/19 07:38 AM
Hastings LF636 cut open
by Tboss - 12/08/19 06:31 AM
Replaced kitchen faucet
by WyrTwister - 12/08/19 03:25 AM
508.00-509.00 oil for Honda K24Z3?
by allepunta - 12/08/19 01:36 AM
Jonas_K, slxgold, Dennisfly, AutopartsTester8, Wamanada
70069 Registered Users
125 registered members (911Don, 1960Elco, Audios, Astro_Guy, 4WD, asiancivicmaniac, 16 invisible), 2,215 guests, and 49 spiders.
Topics298,451
Posts5,135,680
Members70,069
Most Online3,589
Nov 2nd, 2019
Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 #5263992 11/11/19 09:00 AM
N
N Heat Offline OP
N
2004 CRV 145k
It calls for 5w20 and has seen mostly Havoline dino with stock filter. The ST 0w20 is so dang cheap, Im gonna switch and just probably change it once a year which will probably be about 8k a year. The stock Honda filter is tiny. Is there a larger one that will fit? Right now Im leaning towards Fram Ultra.
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: N Heat] #5264005 11/11/19 09:08 AM
P
paoester Offline
P
There might not be an oversized oil filter option, too little space. See https://www.bobistheoilguy.com/forums/ubbthreads.php/topics/4112959/Re:_oversized_version_of_xg731
Wait, that thread was for the smaller 1.8L honda engine, so check for some extra width space and use a
XG7317: 2.70 X 3.47"
XG3593A: 3.02 X 3.39"
Fram Ultra is very good choice. Can't think of better.
If you want to see where SuperTech was made, Warren in Iowa makes it: https://www.youtube.com/watch?v=4g89GGcEyzI
and it looks like they blend their purchased additive package and base oils very well. Good quality control !!
Once a year and 8,000 miles is about right. GM's own dexos1 0w20 applications spec 7,500 mile or 1 year with Direct Injection engines that produce too much carbon soot. Yours makes far less soot.
2019 VW Tiguan S 4Motion, Pennzoil Platinum 0w-20, VW Mann oil filter
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: N Heat] #5264006 11/11/19 09:09 AM
P
pbm Offline
P
I believe the Purolator 4459 sized filters still fit Hondas even though they went to the thimble sized filters....same with the 7317 sized Fram's. (room permitting).
PS: I just looked up your application on RA's site and it already calls for the Fram 7317....I had assumed it called for the 6607 sized thimble...I'd probably just stick with the 7317 size. The ST synthetic should work well with a quality filter like FU, Boss, Platinum etc....
'Journalism is Dead'
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: N Heat] #5264015 11/11/19 09:25 AM
B
BAJA_05 Offline
B
ST 0W20 FS is a great choice paired with a FU.
2017 VW Jetta SE TSI 1.4L Turbo (hers)
PP Euro 0W40 & FU (36K)
2008 Acura TL 3.2L PPPP 0W20 & FU (114K)
2005 Subaru Baja AWD 2.5L N/A 5spd.
T6 MV 5W30 & FU (103K)
2000 Ram 4X4 5.2L (93K) T6 MV 5W30 & FU
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: N Heat] #5264022 11/11/19 09:39 AM
I
Imp4 Online Content
Online Content
I
Either XG3593A or XG9688 are good oversized choices.
See here.
2001 Mitsubishi Galant 2.4 - 165k+
Grandma's creampuff...
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: Imp4] #5264026 11/11/19 09:45 AM
N
N Heat Offline OP
N
See here.
Awesome, thanks
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: N Heat] #5264040 11/11/19 09:57 AM
B
Bettez88 Offline
B
Originally Posted by N Heat
2004 CRV 145k
The stock Oem filter isn’t all that tiny unless you’re going by what Wal-Mart calls for with their supertech filters. The st6607 is really small but the Oem size is the same as the 7317 from fram. Fram makes Honda oil filters so I’d stick with something made by fram like the tough guard or ultra
2013 Honda Fit, QSUD 0W20 with Honda filters
2009 Toyota Corolla, QSUD 0W20 with Toyota filters
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: N Heat] #5264063 11/11/19 10:18 AM
K
krismoriah72 Offline
K
Ive used 7317 in my hondas..
With that being said why are you switching viscosities? Honda says its 'acceptable' which to me says not 'ideal'..
[Linked Image from di-uploads-pod20.dealerinspire.com]
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: N Heat] #5264122 11/11/19 11:35 AM
J
JeffKeryk Online Content
Online Content
J
I would run any good filter for 2 OCIs; the Fram UG is almost a no brainer nowadays.
I would not extend OCIs to past 6K; I like to keep my engines clean and happy.
I have had really good results with this practice.
I like fresh air filters as well.
2018 Lexus RX450h
2013 Lexus GS350 F Sport
2006 Acura TSX
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: krismoriah72] #5264152 11/11/19 12:08 PM
U
user52165 Offline
U
And that chart does not match the owners manual, 2007 Civic EX when published.
Note that the 2 highest performers - Civic Si and S2000 call for thickest oil.
"Ideal" for Honda which has to meet CAFE or Ideal for you?
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: krismoriah72] #5264360 11/11/19 04:11 PM
N
N Heat Offline OP
N
My parents have 2 Hondas that call for 0w20. I was just gonna switch mine over and just have 0w20 on hand. What conditions would make the 5w optimal vs the 0w?
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: N Heat] #5264370 11/11/19 04:27 PM
Z
ZeeOSix Offline
Z
[quote=krismoriah72]What conditions would make the 5w optimal vs the 0w?
None. 0w is still thicker cold than 20 is hot.
Re: Recommend a filter: 2004 CRV-switching to Supertech HM 0w 20 [Re: N Heat] #5264397 11/11/19 05:14 PM
DuckRyder Offline
an XG7317 is more than up to doing 2 intervals at 8K...
An EG7317, TG7317, A01 or A02 is fine for one...
Robert
  • 2019 Volkswagen Jetta R-Line
  • 2005 Honda Civic Sedan
  • 1972 F100 Ranger XLT (390/C6/9” 3.50 Truetrac)
  • 2002 Ford Ranger XLT 4D Supercab 3.0L
